Radiator fans not working - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-18-2013, 12:07 AM   #41
FocusRus
FocusRus's Avatar
Fan#: 109798
What I Drive: 2004 Silver Sedan SE
Points 356, Level 7
Points: 356, Level: 7 Points: 356, Level: 7 Points: 356, Level: 7
Level Up 12% Completed
FF Reputation: 3 FocusRus Good Standing Member
Buy-Sell-Trade Rating: (9)
Cyle, do this; take a piece of wire, run from positive post @ battery to one of the female ports @ F2 with the fuse removed....the fans should activate
SR#269 'I know where the 'zetec' kicks in....'
FocusRus is offline
Old 03-18-2013, 12:08 AM   #42
cylenotkyle
Fan#: 107493
What I Drive: 2000 Red ZTS
FF Reputation: 1 cylenotkyle Good Standing Member
Ill check back in with results
If the fans don't activate what I do from there?
cylenotkyle is offline
Old 03-18-2013, 12:10 AM   #43
FocusRus
FocusRus's Avatar
Fan#: 109798
Points 356, Level 7
Originally Posted by cylenotkyle View Post
What do you mean?
F2 does not get any voltage until the pcm reads input from CHT that the coolant temp is say 230*....pcm grounds low speed fan relay R16 (I think)
fan activates
FocusRus is offline
Old 03-18-2013, 12:13 AM   #44
cylenotkyle
Fan#: 107493
fan activates
In a little less mechanical terms please. I'm more computer savoy and less mechanical.
Old 03-18-2013, 12:18 AM   #45
FocusRus
FocusRus's Avatar
Fan#: 109798
Points 356, Level 7
If you run 12 volts from battery to the top of the fuse at location F2, the fan should run. This means that the cooling fan electrical wiring is sound, or good. Did you run the engine until the water temp got to 230 degrees.....only then will the fans engage
FocusRus is offline
Old 03-18-2013, 12:27 AM   #46
cylenotkyle
Fan#: 107493
I ran my engine after I replaced the resistor and after about 15 minutes of being idol the temperature gage started to go to the red and the fans didn't kick on.
Old 03-18-2013, 12:27 AM   #47
FocusRus
FocusRus's Avatar
Fan#: 109798
Points 356, Level 7
If you disconnect the fan resistor connector, add power to the side that has the green/white wire.....you will have power at fuse 2 (F2).....if you do then the wiring is good
FocusRus is offline
Old 03-18-2013, 06:13 AM   #48
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,776, Level 98
Points: 27,776, Level: 98 Points: 27,776, Level: 98 Points: 27,776, Level: 98
Level Up 43% Completed
Forum Activity 4%
The accumulator is the place where you bridge the 2 wires. It's located in the passenger fender under the passenger headlight. It looks like a big canister with an electrical connector plugging into the top of it. Unplug that connector, then bridge the 2 points on that connector with some wire, and tape up. That will trick your AC system into thinking you have good pressure. If you don't unplug the compressor, you will KO the compressor.
As far as the test mode, the coolant temp readout is in there. It might not be the exact numbers that I quoted. It will be some number according to the temperature that it is reading at the time. If it was working properly, on a cold engine, it would read very close to the ambient temperature- the temperature of the outside world. If the car is warm when you do this, then it will read whatever the temp is in the engine. When this goes bad it tends to show higher temps than actually exist. Which is why we recommend testing it against readings taken with an infrared thermometer on the upper radiator hose. If you see it jump to a wacky temp like 200 C where your hoses would melt, then you know the sender is bad.
Well... if the temp goes up to red, the fans should be on, so something is wrong between the ECU and the fan wiring.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
Old 03-18-2013, 08:27 AM   #49
cylenotkyle
Fan#: 107493
So basically I'm unplugging this and putting wire in between it?
Old 05-11-2013, 07:23 PM   #50
sparkey
sparkey's Avatar
Fan#: 114510
What I Drive: 2000 zx3 black and 2007 rio
FF Reputation: 1 sparkey Good Standing Member
Ok I kinda have the same prob other then both fans only come
On with the ac on OR defrost on any ideas? The cooling fan resistor
And plug to it look ok(not burnt)
sparkey is offline
