Radiator fans not working - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-17-2013, 11:35 PM   #31
FocusRus
FocusRus's Avatar
Fan#: 109798
What I Drive: 2004 Silver Sedan SE
Points 356, Level 7
Points: 356, Level: 7 Points: 356, Level: 7 Points: 356, Level: 7
Level Up 12% Completed
FF Reputation: 3 FocusRus Good Standing Member
Buy-Sell-Trade Rating: (9)
look at fuse location F6....50A fuse....is it good or blown....check
SR#269 'I know where the 'zetec' kicks in....'
FocusRus is online now
Old 03-17-2013, 11:37 PM   #32
cylenotkyle
Fan#: 107493
What I Drive: 2000 Red ZTS
FF Reputation: 1 cylenotkyle Good Standing Member
It's good, so is the plug. But two has no response whatsoever. The fuse or the port.
cylenotkyle is offline
Old 03-17-2013, 11:38 PM   #33
cylenotkyle
Fan#: 107493
F2 that is
Old 03-17-2013, 11:39 PM   #34
FocusRus
FocusRus's Avatar
Fan#: 109798
Points 356, Level 7
Thats right...there is power at both fan relays R15 & 16.......but when the 30a fuse is removed from F2...you will get voltage on just one side.the fuse makes joins the circuit
Old 03-17-2013, 11:41 PM   #35
cylenotkyle
Fan#: 107493
I get no Voltage at all from the 30a fuse in f2. Even when I removed it.
Old 03-17-2013, 11:47 PM   #36
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
The AC clutch connector is the only electrical plug that goes to the AC compressor. It is right behind the pulley either on the top or the bottom, I don't know which because I don't have a Zetec.
I didn't say bridge that connector. You should disconnect it to prevent the AC compressor from turning. You should also find a way to move it back away from the pulley so that it doesn't get caught in the belt.
The connector you want to bridge is the low pressure switch. Your AC system is protected by 2 switches, one low pressure, and one high pressure. The high pressure switch won't open unless the pressure exceeds it's limit, but the low pressure switch only closes when the pressure is high enough in the system. That switch is located on top of the accumulator. Unplug the connector to the switch and bridge the connector.
Did you try the electronic odometer trick to verify that the temp sensor is working correctly? Drive the car around and see if the fans come on at 115C? Are you losing coolant?
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-17-2013, 11:52 PM   #37
cylenotkyle
Fan#: 107493
I did the odometer but the codes you have me weren't in the 30 listed on my car.
So I unplug the ac clutch and tuck it away.
Where are the two connectors I need to bridge?
Old 03-17-2013, 11:54 PM   #38
FocusRus
FocusRus's Avatar
Fan#: 109798
Points 356, Level 7
I didn't relize the time of night it twas.......hello whynotthinkwhynot
Old 03-17-2013, 11:59 PM   #39
FocusRus
FocusRus's Avatar
Fan#: 109798
Points 356, Level 7
F2 won't have any juice until the pcm grounds R15-or-R16
Old 03-18-2013, 12:05 AM   #40
cylenotkyle
Fan#: 107493
What do you mean?
