Radiator fans not working - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-16-2013, 09:23 PM   #11
cylenotkyle
Fan#: 107493
What I Drive: 2000 Red ZTS
FF Reputation: 1 cylenotkyle Good Standing Member
Originally Posted by BC_ZX3 View Post
This is an image of your battery junction box looking down from above for the 2000 model year. (It's from your owner's manual.) The relevant fuses are numbered 2 and 6. Check both. One is a 30 amp fuse; the other is 50 amps. R15 and R16 are the relay locations for the cooling fans.
2 isn't getting power. 6 is.
cylenotkyle is offline
Old 03-16-2013, 09:36 PM   #12
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
Fuse 6 supplies power to fuse 2 via relay 16. Check relay 16 for proper function.
BC_ZX3 is offline
Old 03-16-2013, 09:45 PM   #13
cylenotkyle
Fan#: 107493
I replaced relay 16 with a brand new relay.
Old 03-16-2013, 10:18 PM   #14
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Sorry, should have been clearer. Fuse 6 supplies power to relay 16. Power is interupted at the relay. Relays are simply electrical switches of sorts. When the relay is closed, current is passed to fuse 2. Fuse 2 is before the fan resistor in the circuit. Fuse 2 should not receive power unless engine cooling is required.
The PCM controls whether the relay is closed or not based on readings from the CHT (cylinder head temp) sensor. i.e. hot engine temps If you want to check wiring integrity to fuse 2/the resistor, you need to bypass the relay (in effect pretending to be the PCM and commanding the fans on.)
Would it be useful if I sent you a wiring schematic?
btw, when resistors fail they usually burn up a chunk of wiring with them. You didn't just substitute a new resistor (and nothing else) did you?
BC_ZX3 is offline
Old 03-16-2013, 10:28 PM   #15
cylenotkyle
Fan#: 107493
Yeah I replaced the resistor and the connector for it. Both were burnt up pretty bad. And I took wires and put them from my battery to the connection port going to the fans, the wire that splits off and goes to the resistor then each fan? There is a clip with a single prong in it. Touched the wires and both fans started up.
Old 03-16-2013, 10:50 PM   #16
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
OK, so the fans work, the resistor is new and the wiring is sound, correct? So you need to bypass the relay the PCM uses to command the fans on to confirm everythiing is in working order as far up the "chain" as you can go. Once you've done that and confirmed the system works "manually" then the probable causes become: 1) the temperature sensor not communicating correct info to the PCM 2) the PCM not being able to command on the fans 3) your failed AC somehow interfering with the process.
Based on the "fix tthe obvious first" rule, I would atttend to your AC.
BC_ZX3 is offline
Old 03-16-2013, 10:59 PM   #17
cylenotkyle
Fan#: 107493
How would I check the PCM?
Old 03-17-2013, 11:34 AM   #18
cylenotkyle
Fan#: 107493
I had someone look at it, he said the PCM is good. That their may be a wiring problem. He told me to get a Cooling temp sending unit? I have no idea where that is on the car or where to get one
(2000 Focus ZTS/2.0 Zetec)
Old 03-17-2013, 02:34 PM   #19
cylenotkyle
Fan#: 107493
The cooling sensor is good. I'm not getting power to the fans.
Old 03-17-2013, 03:39 PM   #20
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
How are you checking for voltage at the fans? The fans will not come on until the engine is at 115C. You can't test the fans without the engine being hot.
There should also be a fan diode. Diodes are tricky to diagnose. You can do a resistance test, but a diode will only show resistance in one direction. The purpose of a diode is to prevent electricity from flowing in one direction while allowing it to flow in the other direction. This is so that your fan motors don't push electricity into the system backwards. Find the fan diode, remove it, and test for resistance. If you don't get any, then test it with the leads swapped. If you still don't get it, then the diode is bad.
Now, that's probably not the problem. Since your AC doesn't work, let's assume it's due to a low charge. Unplug your AC clutch, and secure the connector somewhere out of the way so it won't get caught up in the belt. Now find your low pressure switch which should be on top of the accumulator which is in the fender under the passenger side headlight. Unplug the electrical connector to the low pressure switch- it should only be 2 wires. Now using some scrap wire, bridge the two points on the LP switch. That will trick your AC system into thinking that it has a charge. This is why removed the AC clutch connector because running a compressor while the system has no charge will kill the compressor. Now the engine cooling fan should come on with the AC if the cabin air fan is set to at least 1.
That's a temporary fix, but it will keep you cool. To continue to diagnose your problem, you will want to use the electronic odometer trick to check to be sure that the engine temp sensor is operating correctly. You can also check the thermostat operation if it's working correctly. Key off, press and hold the trip odometer reset button. Turn the key on, and continue to hold the reset button until the odometer reads [test]. Release the button, and you're in test mode. Every time you press and release the odo reset button you'll scroll through one of 30 test functions. Look for the one that reads [20 C], and that will be the temp sensor readout in C. Some cars might have this function in F. If so, then it will read [60 F] or whatever the ambient temperature is at the time on a cold engine. It will remain in test mode until you turn the key off again, so you can start the engine and see what the temp readout is doing. What you should see in normal operation is the temp slowly climb up to about 95 C or 197F, which is the thermostat temp. Then temp will drop down as the thermostat opens. Temp will continue this cycle until the temperature stays above the thermostat rating. The fans will come on once the engine temp reaches 115C or so.
Now if you were overheating while the car was moving, then your problem is either a stuck thermostat or a bad water pump. I haven't seen how this car behaves with a bad water pump. I would think that it would overheat quickly. A bad temp sensor will make the car appear to be overheating quickly, but when you watch the temp it will jump dramatically. On a normal operating engine, the temp moves slowly. With a bad temp sensor it will jump quickly up to hot and might get even ridiculously hot like 200C. It might also never move. In either of these cases, replace the temp sensor.
I hope that helps you diagnose your problem. Let us know what you find out.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
