Looking to purchase a Morimoto Elite HID system but have a question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-12-2013, 11:53 PM   #1
pmason718
Fan#: 53726
What I Drive: 2010 Coupe Blue Flame Metallic
Points 863, Level 15
Points: 863, Level: 15 Points: 863, Level: 15 Points: 863, Level: 15
Level Up 63% Completed
FF Reputation: 1 pmason718 Good Standing Member
1. There's 4300k, 5K and 6K is the 4300K closer to OEM pure white?
2. There are two types of harnesses which one is right for my car 2010 coupe
Moto control relay or Standalone can bus?
3. If I purchase this kit and decide to purchase the retro kit at a later date can this be done or will I need to purchase a whole different kit?
4. Should I go with the 50w vs 35w? I've always used 35w in my cars and 55w in the motorcycles
pmason718 is offline
Old 03-13-2013, 12:01 AM   #2
pmason718
Fan#: 53726
I just answered my own questions. Going to go with 4300K
http://www.theretrofitsource.com/trs_tech_q_and_a.php
Old 03-13-2013, 12:05 AM   #3
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
I have the 4300k morimoto kit and love it
Galatians 6:14
crice8 is offline
Old 03-13-2013, 12:16 AM   #4
pmason718
Fan#: 53726
Which harness did you require? Standalone can a bus or moto control relay? Also besides the standard plug in play items did you have to run and wires to the battery? And does the headlights have to come out to do this install?
Old 03-13-2013, 12:37 AM   #5
crice8
crice8's Avatar
Fan#: 84830
I bought mine from another member on here. It came with the morimoto heavy duty relay harness. and you connect it to the battery and a ground. And with and hid install on second gens you will have to remove the passenger side headlight to install its light. The drivers side does not have to be removed though.
Galatians 6:14
crice8 is offline
Old 03-13-2013, 12:54 AM   #6
pmason718
Fan#: 53726
Do you happen to have a picture of this connection going to the battery?
Old 03-13-2013, 12:59 AM   #7
crice8
crice8's Avatar
Fan#: 84830
I will take you a video in the morning and post it here
Galatians 6:14
crice8 is offline
Old 03-13-2013, 09:12 AM   #8
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 969, Level 16
Level Up 69% Completed
FF Reputation: 4 gtferrari Good Standing Member
Our cars do not require a special harness. I started out with the standard h13 relay but mine rusted out so i have replaced it with the morimoto black box.
I am running 50 watts and have never been given any trouble from the fuzz. You are taking a small light source and spreading it out over a large distance. You wont be as happy with the lights if you go 35w.
But you need projectors! This system rewires the lights to make the highbeams control a solenoid for the projectors. Sticking a xenon bulb in your stock housing is dangerous to everyone around you plus when it rains, snows, or you are driving in fog there will be so much kickback.
Unfortunately both lights must come out unless you have a cold air intake to install the harness. It can be installed from eother side. It just plugs into where the old bulb used to be. Depending on how long the power lead is you will most likely need to plug it into the driver side. Secure everything down because the ballasts and controller do not like the vibrations -may shorten the lifespan if you do not.
If you plan on retrofiting later i would wait on this unless you have some form of projector like eagle eyes but be mindful that setup uses a h9 bulb i think. If youre using the stock housings it would be better to find a 50/65watt halogen bulb.
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
Old 03-13-2013, 11:40 PM   #9
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,349, Level 20
Points: 1,349, Level: 20 Points: 1,349, Level: 20 Points: 1,349, Level: 20
Level Up 49% Completed
Forum Activity 12%
FF Reputation: 1 popwarhomie Good Standing Member
5000k is pure white in 35 watts.
You do not need a can bus harness.
The MH1 projectors uses H1 bulbs.
35 watt. MH1 projectors are to small for 55 watts. 55 watts will ruin the chrome coating on the projector bowls after time. TRS does not recommend 55 watts in the MH1s because of this.
I would just do the stage 3 kit with the projectors. Might as will buy it all and do it right the first time.
2010 Focus coupe 5 speed
Projector retrofit/LED tails/ Pioneer 80prs/(2)AQ2200D/BK800.4/6 SQ pro mids/4 SQ supertweets/AlphaDamp/HDC3 18"s walled/ Juicebox G31/ DC power 270XP Alt/
94 Lightning
A lot of mods.
popwarhomie is offline
Old 03-14-2013, 12:11 AM   #10
crice8
crice8's Avatar
Fan#: 84830
Here you are sir:
http://youtu.be/QKPWVRLdp8U
Galatians 6:14
crice8 is offline
