Sway bars - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-10-2013, 08:05 PM   #1
Jester1911
Jester1911's Avatar
Fan#: 109586
What I Drive: 2013 Sterling Gray SE 5door
FF Reputation: 1 Jester1911 Good Standing Member
Sway bars
My intentions are to get both steeda sway bars, but can only get one at a time.
For those that have them, if you had to make a choice, would you get the front or the rear first?
I thought I finally had everything figgered out. I finally had a handle on things and on my life. Nope. Just turns out I don't give a shit anymore.
Rally Revolution #34
Jester1911 is offline
Old 03-10-2013, 08:15 PM   #2
sgmfocus
sgmfocus's Avatar
Fan#: 101095
What I Drive: 2012 sgm sedan se,sfe package
Points 226, Level 4
Points: 226, Level: 4 Points: 226, Level: 4 Points: 226, Level: 4
Level Up 52% Completed
FF Reputation: 3 sgmfocus Good Standing Member
go with the rear bar first then see if you think you need front, its easier and cheaper the fronts a three hour job(what dealer said)you have to drop the subframe in order to do front. i got these when i put my rear bar on saves you from having to take bar off to grease it .http://energysuspension.com/products...-Bushings.html the 9.5161R fit the 1 inch bar about 20 dollars at autozone
sgmfocus is offline
Old 03-10-2013, 08:18 PM   #3
Jester1911
Jester1911's Avatar
Fan#: 109586
I did take a look under the front end, didn't seem like that bad a job.
This is coming from a guy that swapped spring packs under a 94 YJ every weekend just to see what setup worked best. (my garage is pretty well equipped.
Old 03-10-2013, 08:29 PM   #4
Brabs_Weather
Fan#: 93741
What I Drive: 04 Ex Ltd, 08 Edge Ltd, 12 FF Ti
Points 709, Level 14
Points: 709, Level: 14 Points: 709, Level: 14 Points: 709, Level: 14
Level Up 9% Completed
FF Reputation: 2 Brabs_Weather Good Standing Member
i have the Steeda RSB from a friend and it does a very good job on its own. A friend did have both and he said ones or the other work great alone but the front seems to counter act the rear. Besides have to lower the chassis to install the FSB and front end alignment. My car does not rock when cars pass or meander on the road with high winds.
White Platinum Tricoat Metallic
2012 Ford Focus Titanium
Handling Package Nitto Motivo's
Borla Exhaust with UltraQuiet resonator
K&N X-4870. Steeda RSB
Brabs_Weather is offline
Old 03-10-2013, 08:34 PM   #5
cobie56
Fan#: 84403
i installed the rear first (and only) and saw a marked difference for the better in ride and handling.... my intent was to do the front later but as it's such a pita to do it and i don't feel it necessary (tho it'd prob improve handling further) i'll just stick w/ the rear...
cobie56 is offline
Old 03-10-2013, 08:37 PM   #6
Jester1911
Jester1911's Avatar
Fan#: 109586
I guess I simply don't understand how they "work against each other". I'm not new to suspension, and to me this just doesn't make any sense.
Why would you need to do an alignment when swapping the sway bar in the front, how would swapping them change anything?
To me it seems as my rear tire is always trying to lift, and that would tell me that a front swaybar would be more beneficial, but I've been proven wrong before.
I may go with the rear simply for cost purposes.
Old 03-10-2013, 08:51 PM   #7
sgmfocus
sgmfocus's Avatar
Fan#: 101095
Points 226, Level 4
heard the same about the bars cancelling each other out /don't know how hard it is to remove subframe check here for instructionshttp://www.fordracingparts.com/downl...htM-FR3-FS.pdf. if done wrong makes a horrible noise had my steering rack replaced at 4000 miles ,the mechanic didn't tighten the bolts correctly car was back at shop same day 9 hours to replace rack 8.5 hours to realign the subframe
sgmfocus is offline
Old 03-10-2013, 08:52 PM   #8
Brabs_Weather
Fan#: 93741
Yes what he said. This isn't my first RODEO.
"heard the same about the bars cancelling each other out /don't know how hard it is to remove subframe check here for instructionshttp://www.fordracingparts.com/downl...htM-FR3-FS.pdf. if done wrong makes a horrible noise had my steering rack replaced at 4000 miles ,the mechanic didn't tighten the bolts correctly car was back at shop same day 9 hours to replace rack 8.5 hours to realign the subframe "
Old 03-10-2013, 08:54 PM   #9
Jester1911
Jester1911's Avatar
Fan#: 109586
Awesome link, thanks!
Old 03-10-2013, 09:20 PM   #10
Creative
Creative's Avatar
Fan#: 108024
What I Drive: 2013 Ford Focus
Points 3,615, Level 37
Points: 3,615, Level: 37 Points: 3,615, Level: 37 Points: 3,615, Level: 37
Level Up 77% Completed
FF Reputation: 3 Creative Good Standing Member
I have both, I honestly think your better off with just the rear unless your planning on full race purpose. Also front is a pita to install. I don't mind both and they are nice to have forautox but honestly just get the rear
Originally Posted by Dialed View Post
Let's be honest guys, car modding is not synonymous with warranty-covered cars.
As the old saying goes, you have to pay to play.
Creative is offline
