Common problem or not..rear end links - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-10-2013, 05:52 PM   #1
Fishnmaine
Fan#: 96185
What I Drive: 2004 Ford Focus ZX5 2.3L
Points 84, Level 1
Points: 84, Level: 1 Points: 84, Level: 1 Points: 84, Level: 1
Level Up 68% Completed
FF Reputation: 1 Fishnmaine Good Standing Member
Noise came thru the front and back. And we all know noise travels. Anyways I replaced the front end links for which one was bad. Great! I though I took care of the problem. Front noise was gone but I still have a slight clunking noise out back. In this forum I've read mostly the front going. Are the rears prone to do the same? I jacked up the car tried to move things around to see if any bad bushings everything seems tight. And look fine. Links I can't move around.
Thanks
Fishnmaine is offline
Old 03-10-2013, 08:42 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,376, Level 75
Points: 13,376, Level: 75 Points: 13,376, Level: 75 Points: 13,376, Level: 75
Level Up 32% Completed
Forum Activity 99%
Rear sway bar end links aren't as noted for this due to the design. The rubber bush links don't exhibit the noises loose ball & socket links like the front ones do, rear type is generally either OK or rusted out & broken....
Honestly, the most common "clunking" noise from out back is from the exhaust hitting bodywork, particularly if one of the few hangers is broken - followed by "rattles" from loose heat shielding. "Squeaks" as the suspension moves often come from brake cables rubbing in their guides.
I'm going to move this over to the "wheels, tires, suspension & brakes" area for you, as you might get more ideas from the folks in that area.
Luck!
sailor is online now
Old 03-11-2013, 09:00 AM   #3
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,890, Level 59
Points: 7,890, Level: 59 Points: 7,890, Level: 59 Points: 7,890, Level: 59
Level Up 70% Completed
Forum Activity 29%
Activity: 29% Activity: 29% Activity: 29%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Typically, the only noise people complain of on the rear sway bar comes from those who have added a sway bar with Steeda's kit when they didnt have the mounts for a rear sway bar from Ford. That is the brackets shifting on the rear subframe.
Is the noise there at slow and higher speeds? Have you greased the bushings on the actual bar? Perhaps it is catching/slipping some and not moving smoothly. Are the endlinks overly tightened, causing a popping?
rambleon84 is online now
Old 03-11-2013, 02:47 PM   #4
Fishnmaine
Fan#: 96185
Points 84, Level 1
It does it over bumps like the front did...I'm wondering if the rubber bushing on top of the shock is gone.....But I am missing one bracket for the exhaust. But you would have to wiggle it excessively to touch. Sway bar bushings wouldn't make a clunking noise or would it?
Thanks
Old 03-11-2013, 04:07 PM   #5
Fattie
Fan#: 46016
What I Drive: 6 Duratec Focus
Points 8,431, Level 61
Points: 8,431, Level: 61 Points: 8,431, Level: 61 Points: 8,431, Level: 61
Level Up 94% Completed
FF Reputation: 5 Fattie Good Standing Member
Buy-Sell-Trade Rating: (6)
Hey , another mainer ! if you were closer id come over and help you figure it out.
If the rear sway bar links were gone , then the bar could clunk on the bottom on the control arm.
6 Duratec Focus
3 04 zx4's
2 05 zx3's
1 03 zx3
Fattie is offline
