Require detailed information on dual clutch transmission - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-10-2013, 09:41 AM   #11
UnleashedBeast
UnleashedBeast's Avatar
Fan#: 100738
What I Drive: 2012 Focus Titanium
FF Reputation: 3 UnleashedBeast Good Standing Member
Originally Posted by Seriously Focused View Post
It completely bewilders me that one would start ANOTHER thread on the DCT....
some people have no desire to read 50+ pages of ramblings and tangents to gain what little information is required here.
2014 Mustang GT custom ordered to replace the GT500: Sterling Gray, NAV, Recaros, Brembos, Glass Roof, back up camera, 6 speed auto, loaded
2012 Focus Titanium - 18" wheels with handling package
2009 GT500 Shelby (700 rwhp) - sold
UnleashedBeast is offline
Old 03-10-2013, 10:49 AM   #12
MyThIc3LiTe
MyThIc3LiTe's Avatar
Fan#: 95163
What I Drive: 2012 Focus Titanium Blue Candy
FF Reputation: 4 MyThIc3LiTe Good Standing Member
Because the DCT, like all DCTs from now till the end of time, is a black box of witchcraft and unicorn rainbows.
2012 Ford Focus Titanium Blue Candy Hatch 2009 Suzuki Swift+ - Traded in 2006 Lincoln Zephyr - Traded in
http://www.aniteshjaswalphotography.com
If you live in Edmonton, AB I would be more then happy to do a shoot with you!
MyThIc3LiTe is offline
Old 03-10-2013, 11:26 AM   #13
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,082, Level 34
Points: 3,082, Level: 34 Points: 3,082, Level: 34 Points: 3,082, Level: 34
Level Up 22% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
Originally Posted by PandT View Post
I am following the thread, the only observation that I have is that it's supposed to be an automated manual but the fluid recommendation is not for the manual trans fluid but the special dual clutch automatic trans fluid. I'd like to know why and what the differences are.
While it is an automated manual, the mechanism for changing gears is pretty different from a conventional manual. Instead of a strong human being using leverage to move gears around, you have an small electric servo motor doing the job. So I'd expect the DCT fluid to be formulated to allow gear shifts with the lowest possible effort, especially in cold weather. Plus, as the Focus is clearly a CAFE target car, general friction reduction would also be a priority.
While "normal" gearbox lubricants are something like 75w/90, it seems logical to assume the DCT stuff would be quite a bit thinner.
dan50 is offline
Old 03-10-2013, 11:43 AM   #14
UnleashedBeast
Fan#: 100738
It is very much less viscous. DCT fluid has about the same viscosity as LV ATF.
~6.x cSt @ 100*C
Old 03-10-2013, 12:04 PM   #15
dan50
Fan#: 91789
Forum Activity 4%
~6.x cSt @ 100*C
Yes, its viscosity is similar to ATF. Doing a little more research, the DCT fluid's CsT at 40 Centigrade is 32.2. Mobil1 75/90 manual gearbox fluid is 99 at the same temperature. Mobil1 0w/20 motor oil is 44.8 at 40C.
dan50 is offline
Old 03-10-2013, 12:59 PM   #16
Focus805
Fan#: 90582
What I Drive: 2012 Frosted Glass SEL HB 300A
Points 740, Level 14
Points: 740, Level: 14 Points: 740, Level: 14 Points: 740, Level: 14
Level Up 40% Completed
FF Reputation: 1 Focus805 Good Standing Member
Per the Owner's Manual
Automatic transmission fluid
1.9 quarts (1.8L)1
Motorcraft Dual Clutch Transmission Fluid2 XT-11-QDC
Automatic transmissions that require Motorcraft Dual Clutch Transmission Fluid should only use
Motorcraft Dual Clutch Transmission Fluid. Refer to scheduled maintenance to determine the
correct service interval. Use of any fluid other than the recommended fluid may cause transmission
damage.
My advice? Glad you asked. Put the factory juice in at increased intervals, say 60,000, instead of the factory specified 150,000 miles (which coincidentally is the life of the dry clutches).
Focus805 is offline
Old 03-10-2013, 01:46 PM   #17
dan50
Fan#: 91789
Forum Activity 4%
1.9 quarts (1.8L)1
damage.
Agree periodic fluid changes seem like a good idea even if Ford says otherwise. Plus, with only 2 quarts to exchange and a drain plug on the gearbox, how expensive could it be?
The 150,000 mile life seems to be what Ford uses for everything despite lots of 150,000 mile+ Fords still running around. Maybe 150,000 is a minimum target that can be easily exceeded with good care and moderate driving?
dan50 is offline
Old 03-10-2013, 02:58 PM   #18
UnleashedBeast
Fan#: 100738
Does anyone have pictures of the location for fill and drain plug on this transmission?
No way I would leave that lubricant in there for 150,000 miles. Half of that, maybe.
Old 03-10-2013, 03:28 PM   #19
Kabigon
Fan#: 88299
Points 4,590, Level 43
Points: 4,590, Level: 43 Points: 4,590, Level: 43 Points: 4,590, Level: 43
Level Up 20% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 11 Kabigon Great Standing Member
While it is an automated manual, the mechanism for changing gears is pretty different from a conventional manual. Instead of a strong human being using leverage to move gears around, you have an small electric servo motor doing the job. So I'd expect the DCT fluid to be formulated to allow gear shifts with the lowest possible effort...
The gear lubricant is chosen (in part) based on the "strength" of the electric motors used for shifting???
I'm sorry but that is absurd.
A small 3 phase electric motor with gear reduction can be quite powerful as such a motor is used for clutch actuation (which requires far more torque than a gear change).
I am Kabigon and I approve this message.
Kabigon is offline
Old 03-10-2013, 03:42 PM   #20
dan50
Fan#: 91789
Forum Activity 4%
[QUOTE=Kabigon;4629509]The gear lubricant is chosen (in part) based on the "strength" of the electric motors used for shifting???
A small 3 phase electric motor with gear reduction can be quite powerful as such a motor is used for clutch actuation (which requires far more torque than a gear change).[/QU
Nice style.
dan50 is offline
