Do These alignment specs look ok to you? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-08-2013, 05:20 PM   #1
Uptcv1
Uptcv1's Avatar
Fan#: 88390
What I Drive: 2012 sonic blue SE sport DCT hatch
Points 2,514, Level 30
Points: 2,514, Level: 30 Points: 2,514, Level: 30 Points: 2,514, Level: 30
Level Up 43% Completed
FF Reputation: 1 Uptcv1 Good Standing Member
Uptcv1 is offline
Old 03-08-2013, 05:40 PM   #2
Some Guy From NY
Some Guy From NY's Avatar
Fan#: 101517
What I Drive: 2012 SGM Focus SEL sedan DCT
FF Reputation: 3 Some Guy From NY Good Standing Member
everything should be green.
how does it drive?
Mods: Drop in K&N filter, Steeda RSB, MS3 RMM, Remote start, Llumar tint, Ti engine cover, Husky floor mats, OEM splash guards
Some Guy From NY is offline
Old 03-08-2013, 06:00 PM   #3
Uptcv1
Uptcv1's Avatar
Fan#: 88390
how does it drive?
about to find out... only drove home (5 minutes from dealer) but heading out now.. 20+miles each way, so I'll put 40 miles to the test..
-any aligment gurus pls comment!
Uptcv1 is offline
Old 03-08-2013, 06:20 PM   #4
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,532, Level 47
Points: 5,532, Level: 47 Points: 5,532, Level: 47 Points: 5,532, Level: 47
Level Up 91% Completed
Forum Activity 10%
FF Reputation: 35 thenorm Great Standing Member
I would say a little too much toe. especially in the rear, which ideally would be closer to 0.
Also is that toe-in in hte front? Usually should be a tiny bit of toe out in FWD car as the pull from the tires while driving will straigthen it out.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 03-08-2013, 06:39 PM   #5
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,041, Level 17
Points: 1,041, Level: 17 Points: 1,041, Level: 17 Points: 1,041, Level: 17
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 4 thejordan Good Standing Member
Yeah too much toe. Closer to 0 the better. What are you lowered on? Rear camber is way too high, you'll want to invest in rear camber adjustment kit. However, those numbers are all over the place, doesn't look like the guy did any adjustment.
thejordan is offline
Old 03-08-2013, 06:45 PM   #6
Some Guy From NY
Fan#: 101517
I'm confused why he let it be with anything NOT in the green. You went for an alignment...everything should be in spec, ie: green.
Old 03-08-2013, 06:53 PM   #7
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
Good catch thenorm, it looks like they got the front toe backwards,there's no way they'd set it up with that much toe out in the back, I think it'd be noticeably squirrely (and potentially dangerous) if that were toe out. Conventional wisdom with a FWD is a little toe out in front due the torquing force when driving causing the front to toe in some closer to zero (still want a hair toe out in front for steering response), and a little toe in in back since that's static and road friction causes some toe out when driving.
I just looked at an instructional video from Hunter alignment (99% sure that's what was used) and they're showing toe in as a + figure and toe out as -, so somebody screwed up with the front toe. I guess they can say it's in the green and therefore correct, but it's not ideal.
6SPD_soul is offline
Old 03-08-2013, 06:58 PM   #8
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
Well the front camber is non adjustable without camber plates or other things, but yeah the total toe in back is pretty half assed and the front toe is completely backwards. Somebody was either in a total rush or not trying very hard.
It's worth it to in advance request before and after measurement sheets, and then you'll know what was and wasn't adjusted.
OP, why'd you get the alignment done and how's it driving now?
Old 03-08-2013, 07:21 PM   #9
thejordan
thejordan's Avatar
Fan#: 107706
Here are the specs from Ford (for a ST)
Caster
left front measurement Spec: 4.28 +/- 0.75
right front measurement Spec: 4.28 +/- 0.75
Camber
left front measurement Spec: -0.83 +/- 0.75
right front measurement Spec: -0.93 +/- 0.75
left rear measurement Spec: -1.35 +/- 0.75
right rear measurement Spec: -1.35 +/- 0.75
Toe
(positive value is toe in, negative value is toe out)
front total measurement Spec: 0.10 +/- 0.20
left rear measurement Spec: 0.19 +/- 0.2
right rear measurement Spec: 0.19 +/-0.2
rear total measurement Spec: 0.38 +/- 0.2
Old 03-08-2013, 09:11 PM   #10
Kabigon
Fan#: 88299
Points 4,384, Level 42
Points: 4,384, Level: 42 Points: 4,384, Level: 42 Points: 4,384, Level: 42
Level Up 17% Completed
Forum Activity 10%
FF Reputation: 11 Kabigon Great Standing Member
Correct toe specs:
Front toe @ curb ride height (positive value is toe in, negative value is toe out): 0.2 0.2
Rear toe @ curb ride height (positive value is toe in, negative value is toe out): 0.38 0.20 (total)
I am Kabigon and I approve this message.
Kabigon is online now
