Cleaning of Knuckle cause Wheel Bearing problem? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-07-2013, 10:36 PM   #1
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,413, Level 61
Points: 8,413, Level: 61 Points: 8,413, Level: 61 Points: 8,413, Level: 61
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 27%
Activity: 27% Activity: 27% Activity: 27%
I am just about to finish up my prep work cleaning and painting of the knuckles. I have the wheel bearings pressed out, and due to cleaning their has been some surface rust that have shown up on the machined surface (using water to wash off degreaser). Is there any harm in using a wire wheel to remove the surface rust? I am not grinding it away or anything, just using a "fine" wire cup to clean it up. I haven't really be removing any material that will cause the "grip" on the wheel bearing to lessen right? The removal of the surface rust is on the order of microns in thick and the "conversion" from steel to rust is on the order of 6:1 so should have no change in measurable machined diameter....
Just want to make sure I wont have any problems when I go back and press the new wheel bearings in. Don't think I will but just want a sanity check.
Thanks!
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 03-08-2013, 06:42 AM   #2
amc49
Fan#: 96610
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
Forum Activity 13%
I would be far more worried about any residue of the water and degreaser getting into bearing, degreaser and bearing seal edges do not like each other. They deform and go wavy to leak and then the water gets in..................
amc49 is offline
Old 03-08-2013, 08:41 AM   #3
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
Bearing pressed out.... no bearing in the knuckle for the last two weeks....
Hatch Nation #42
Old 03-08-2013, 03:07 PM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,055, Level 74
Points: 13,055, Level: 74 Points: 13,055, Level: 74 Points: 13,055, Level: 74
Level Up 52% Completed
Forum Activity 99%
I'd just clean w/ rag & wd40 the machined area where the bearing goes in.
felixthecat is online now
