Hi and low slop for modified injectors - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-07-2013, 10:05 PM   #1
Fernando_221
Fan#: 79468
What I Drive: '06 ZX4 2.0L Dtec, '11 MK2.5 2.0L
Points 1,863, Level 25
Points: 1,863, Level: 25 Points: 1,863, Level: 25 Points: 1,863, Level: 25
Level Up 63% Completed
FF Reputation: 3 Fernando_221 Good Standing Member
Hi all,
I'm starting a turbo build, injectors are a modified (TLF Performance, anyone know about it?) for 58lbs.
What values of hi slop, low slop e breakpoint I can use for it?
Can I use the FR 60lbs setting?
Thanks
Fernando_221 is offline
Old 03-08-2013, 06:17 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,516, Level 100
Points: 52,516, Level: 100 Points: 52,516, Level: 100 Points: 52,516, Level: 100
Level Up 0% Completed
Forum Activity 62%
Activity: 62% Activity: 62% Activity: 62%
Buy-Sell-Trade Rating: (28)
I would ask your tuner LOL there is far more to do then just change the slopes
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 03-08-2013, 10:00 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
Get a data sheet from the MFG. of the injectors.
If they don't have one available, return the injectors and buy some reputable ones. It's very tough (next to impossible) for a novice to tune injector slopes. Even some pro's have difficulty. It is possible, just not easy or quick by any means.
121,000 members and still no sponsored racing.
iminhell is offline
Old 03-09-2013, 12:30 AM   #4
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 62%
He is doing blowthrough and 3 inch MAF so even if he had the data sheet it wouldnt help him
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 03-09-2013, 03:06 AM   #5
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,316, Level 35
Points: 3,316, Level: 35 Points: 3,316, Level: 35 Points: 3,316, Level: 35
Level Up 78% Completed
Forum Activity 2%
FF Reputation: 3 paulg127 Good Standing Member
High slope is calculated from injector flow, ( lb flow/3600 ) to get in the ballpark, but the 58lb rating does not seem too accurate. The low slope and breakpoints are very hardware specific, but you can use the adaptive fuel terms of the, what is commonly called short term fuel trim, and the long term fuel trim to dial it in.
Typically the idle adaptive (long term fuel trim, lowest air mass) will show if the low slope may not be correct. If the other (higher air mass) adaptive values are close to nominal, most likely the high slope is pretty close, leaving the low slope to correct the idle adaptive cell, provided you do not have an air leak.
If you don't have either the MAF transfer function or the injectors accurately characterized, you really have no way of knowing which, if either is correct.
I'm sure someone has a 3" maf transfer function out there somewhere....
paulg127 is offline
Old 03-09-2013, 11:36 AM   #6
Fernando_221
Fan#: 79468
Agree. I'll contact you by email.
Old 03-09-2013, 11:37 AM   #7
Fernando_221
Fan#: 79468
Tom, remember my ecu is map/speed density based.
Old 03-09-2013, 11:44 AM   #8
Fernando_221
Fan#: 79468
Asked the guys from TLF Performance and they said this:
"never heard of that we do lactency and dead time here.
Thanks
- tlfperformanceparts"
The injectors came with a flow sheet:
Old 03-09-2013, 01:31 PM   #9
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 62%
You should never use long turm fuel trim for tuning anything and never use short turm fuel trim or either for setting the high or low slopes
LTFT should be turned off in my opinion and STFT1 should be adjusted in the MTF , what about WOT and the high slope ? what about when he changes to blowthrough , adds a MAFia , you can throw out any MTF any one can give you and and injector settings on paper , then what does he do ?
Why does everyone approach tuning engines the hard way
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 03-09-2013, 02:49 PM   #10
paulg127
Fan#: 55998
Forum Activity 2%
I'm approaching it from 20 yrs at FMC as a calibrator. There is a right way to do a calibration and a wrong way. The right way is to have the MAF and injectors flowed and characterized. The entire calibration is based on the MAF being correct, right or wrong, and adaptive changes the fueling from there. You are wasting valuable correction info if you turn off adaptive (long term fuel trim). There are many ways to change the adaptive to use it to help you from smoking a piston and helping drivability and verifying MAF and injector slope. The adaptive tells you at a given air mass that the stoich point is shifted the adapted amount.
Why would you not use this information? What do you think the adaptive is there for?
I have not used a mafia so I do not know how it functions.
I do know the calculations, tables, functions, scalars and entire strategy that use the MAF transfer function as a basis and have a hard time relating that the ENTIRE calibration is shifted if the MAF is going through a 'correction' from the mafia.
That would shift the normalizers (load) input to every table (spark, fuel, air) and that seems to be a mess to sort out.
paulg127 is offline
