water cooling turbo? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-07-2013, 02:56 PM   #1
svtf1417
MOAR BEWST!!!!
svtf1417's Avatar
Fan#: 58428
What I Drive: 2001 ZTS, 2002 SVTF Turbocharged
FF Reputation: 6 svtf1417 Good Standing Member
Buy-Sell-Trade Rating: (6)
First of all, I would like say either I can't do one of the simplest tasks, or I've found a question google searches and focus fanatics searches can't answer.
That being said, has anyone tapped into their water lines to cool their turbo? I have a ball bearing turbo and didn't cool it at all last year and never had problems considering I have a pump to pull all the oil out of the turbo when I shut the car off so it doesn't cook.
I have a good idea of where I can tap into for the feed line, but I don't really know where I should drain it too since the turbo sits so low. Any insight whether how to do it or if it's even worth my time would be greatly appreciated
[#1417] 2002 Sonic Blue SVT Focus
Born on June 25, 2002
2001 Silver ZTS Sedan - "Ol' Reliable"
svtf1417 is offline
Old 03-07-2013, 05:10 PM   #2
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,045, Level 50
Points: 6,045, Level: 50 Points: 6,045, Level: 50 Points: 6,045, Level: 50
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 4%
FF Reputation: 9 Deftmetal Good Standing Member
OEM turbos are the most common to use coolant and oil from the engine.
I'm not sure where you could drain to but it's such a small line it might be fine to run it up to the coolant reservoir. I'm not very familiar with the engine but there must be an easy spot to tap a hole close to the pump or along the pressurized side of the system
Rally Revolution #14
Josh
Originally Posted by dyn085 View Post
Don't hate on an amputee chick that's still playing with lego's.
Deftmetal is offline
Old 03-09-2013, 01:44 AM   #3
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,021, Level 33
Points: 3,021, Level: 33 Points: 3,021, Level: 33 Points: 3,021, Level: 33
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
FF Reputation: 3 paulg127 Good Standing Member
I tried to tap lines that had some distance or hardware between the tap points to provide some flow (pressure differential) through the turbo. The 'turbo by garrett' site provided some good insight to the ideal angle the fittings shoule be at to provide maximum thermo siphon effect. http://www.turbobygarrett.com/turbob...il_water_lines
Of course with a bearing turbo, you probably don't need the H2O cooling...my e-bay crapper turdbo needs all the help it can get...
I'm on Hanford, you can swing by to check out the tap points.
paulg127 is offline
Old 03-09-2013, 08:32 AM   #4
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
What I Drive: 86 GN, 11.1@128, 20 psi
Points 4,504, Level 42
Points: 4,504, Level: 42 Points: 4,504, Level: 42 Points: 4,504, Level: 42
Level Up 77% Completed
Forum Activity 8%
FF Reputation: 8 NJSVTGUY Good Standing Member
Buy-Sell-Trade Rating: (10)
The coolent doesn't gravity drain from the turbo. The retun line does not have to be lower. That's how a stock GN is routed.... the return runs higher. Another option is to use an air cooled PTE turbo, that's what I run.
NJSVTGUY is offline
Old 03-09-2013, 11:39 PM   #5
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,090, Level 55
Points: 7,090, Level: 55 Points: 7,090, Level: 55 Points: 7,090, Level: 55
Level Up 70% Completed
FF Reputation: 15 PSUrivie Great Standing Member
This is a great read for water cooling.
http://www.turbobygarrett.com/turbob...er_Cooling.pdf
No I don't think my car needs "moar low". I apologize to everyone for my car not looking like all the other Foci at FR14.
PSUrivie is offline
Old 03-10-2013, 05:53 PM   #6
beansfocus
beansfocus's Avatar
Fan#: 83771
What I Drive: A dark haired donkey!!
Points 986, Level 16
Points: 986, Level: 16 Points: 986, Level: 16 Points: 986, Level: 16
Level Up 86% Completed
FF Reputation: 1 beansfocus Good Standing Member
For my gt28r on my 09 I spliced into my heater core hose to feed the turbo with coolant
beansfocus is offline
Old 03-10-2013, 07:33 PM   #7
svtf1417
MOAR BEWST!!!!
svtf1417's Avatar
Fan#: 58428
all great info thanks guys. Paulg I just might have to do that at some point!
Where did you run the return line to?
svtf1417 is offline
Old 03-10-2013, 07:52 PM   #8
beansfocus
beansfocus's Avatar
Fan#: 83771
Idk how your turbo is setup but on my Garrett the turbo has an inlet and outlet for the coolant so I cut the heater hose going from the motor to the core and have it enter the turbo and then exit the turbo
Old 03-10-2013, 08:09 PM   #9
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
id recommend like earlier posted an air cooled PTE
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
