Rear door wiring - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-06-2013, 12:58 PM   #1
Winona Brad
Winona Brad's Avatar
Fan#: 104568
What I Drive: 2012 Ingot Silver Focus
Points 37, Level 1
Points: 37, Level: 1 Points: 37, Level: 1 Points: 37, Level: 1
Level Up 74% Completed
FF Reputation: 1 Winona Brad Good Standing Member
Unhappy Rear door wiring
Anyone experienced a bad electrical connector for the rear driver side door? Just got back from the dealer and mine is so corroded they need to cut the connector out and direct wire everything. Estimate is $500, Ford will not warranty it because i have 41k miles. Customer care said "sorry" faith in Ford is fading.
Anyone have any thoughts on how to get this warranted? If not anyone had the door panel off and seen the connection? How hard would it be to DIY?
Thanks!
Winona Brad is offline
Old 03-06-2013, 01:32 PM   #2
mp223
Fan#: 104161
What I Drive: 2012 Focus SEL
Points 166, Level 3
Points: 166, Level: 3 Points: 166, Level: 3 Points: 166, Level: 3
Level Up 32% Completed
FF Reputation: 0 mp223 Newbie
I'm sorry I can't answer your other questions but if your dealer said they want to "cut the connector out and direct wire everything" that sounds like a terrible hack. I would look at another dealership or a reputable independent shop to fix your issues.
mp223 is online now
Old 03-06-2013, 01:40 PM   #3
Winona Brad
Fan#: 104568
Points 37, Level 1
Thanks for the reply, the dealer is good but the problem is the car side of the connection is half the wiring harness for the car so its not practical to replace the harnes. But I agree, not a great fix for a 2012
Old 03-06-2013, 02:03 PM   #4
mp223
Fan#: 104161
Points 166, Level 3
Why was it corroding in the first place?
How badly corroded are you talking about? For DIY, you might be able to remove the door/pillar trim and use some steel wool or a wire brush to remove the corrosion (baking soda and water could also help), then cover the connector in a healthy amount dielectric grease and shrink tube to prevent it from corroding further.
mp223 is online now
Old 03-06-2013, 04:21 PM   #5
Winona Brad
Fan#: 104568
Points 37, Level 1
The dealer tried cleaning it and some of the terminals are broken so the connector needs to be replaced or removed. The dealer was going to solder and heat shrink the wires together and elimiate the connector. I have done a fare amount of wiring and figured i could the same for a whole lot less than $500.
Old 03-06-2013, 04:23 PM   #6
StingRay
StingRay's Avatar
Fan#: 67421
What I Drive: 2014 Tuxedo Black SE Sport
Points 1,751, Level 24
Points: 1,751, Level: 24 Points: 1,751, Level: 24 Points: 1,751, Level: 24
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
Forum Activity 30%
FF Reputation: 5 StingRay Good Standing Member
You are paying almost 100% of that cost in labor, so yes doing it youself would be the better option. It's not too hard to do wiring in an area like that if you are experienced in wiring. But it is VERY time consuming and labor intensive to get to the connector usually.
StingRay is online now
Old 03-06-2013, 04:32 PM   #7
Jim_J
Jim_J's Avatar
Fan#: 109775
What I Drive: 2013 Silver SE with a shudder trans
FF Reputation: 1 Jim_J Good Standing Member
$500 is way too much. You can do it yourself. The first question is why did they corrode? Is there a leak?
There are photos of replacing the speakers on a 2012, they go into door panel removal
http://www.focusfanatics.com/forum/showthread.php?t=280887
Jim_J is offline
Old 03-09-2013, 08:29 AM   #8
Winona Brad
Fan#: 104568
Points 37, Level 1
Wanted to update everyone, one of the very small wires to the door control unit was broken out of the connector. I rerouted a new wire and problem solved. Really disappointed in the dealer not fixing this when they had it all opened up and they charged $90 to diag. The rest of the connector cleaned up fine.
Time to go talk to a service manager.
Thanks for everyones input!
