Headlight Wiring - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-06-2013, 12:11 PM   #1
gaz12321
Fan#: 110937
What I Drive: 2004 TDCi Sport Blue/Purple
FF Reputation: 1 gaz12321 Good Standing Member
Headlight Wiring
Hi all,
I have had an issue with my headlights on my 04 Focus, I went to change a blown bulb today only to find out that the connection that the bulb plugs into has completely melted and no good, I took it to my local Ford repair center who had a look and said that I would need to replace the whole headlight as this comes as part of the actual light cluster, is this correct?
I don't want to go to the hassle of removing the headlight to find out so thought I would ask here, I can pick up a second hand light and change it myself but i don't want to do this if it isn't necessary, does anyone know if the wiring for the headlights is built in to the cluster or am I able to just replace some sort of wiring loom?
gaz12321 is offline
Old 03-06-2013, 02:10 PM   #2
slinkmerc
Fan#: 109901
What I Drive: 2002 Silver ZX3
Points 260, Level 5
Points: 260, Level: 5 Points: 260, Level: 5 Points: 260, Level: 5
Level Up 20% Completed
FF Reputation: 2 slinkmerc Good Standing Member
accordinng to mitchell on demand this is the wiring circuit for an 04 focus...I entered in info for a zx3 as I am not sure what car you have. But these are the wiring diagrams for headlights with and without day time running lights. the first diagram is without day time running lighets...second one is with.
Hope this helps you
slinkmerc is offline
Old 03-07-2013, 05:01 PM   #3
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
What I Drive: 2004, Pitch Black Zx3
Points 16,184, Level 81
Points: 16,184, Level: 81 Points: 16,184, Level: 81 Points: 16,184, Level: 81
Level Up 67% Completed
FF Reputation: 13 fhh02a Great Standing Member
Buy-Sell-Trade Rating: (10)
actually Gaz, I had to do this. Its really easy. You dont need to buy a new light.
You do need to remove the light from the car.
Steps are as follows:
1. remove light
2. cut the old bulb holder/ 3 pronged plug out (pay attention to the color of the wires)
3. get 9007 bulb holder from parts store
4. Use wire connectors to attach new plug (use the bullet type.. makes it easier to switch leads if needed)
5. Put light back in
6. Put light on car and see if you got it right
fhh02a is offline
Old 03-08-2013, 09:07 AM   #4
gaz12321
Fan#: 110937
Thanks for the reply fhh02a, I had already found a cheap replacement headlight on ebay from a scrapyard by the time I saw your post, cheers anyway.
I have been reading a lot that one of the bolts holding the headlight in is on the underside and hard to get to, is this on the MK1 focus or the facelift models, or both?
gaz12321 is offline
Old 03-08-2013, 10:01 AM   #5
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
What I Drive: 03 CD Silver ZX5
Points 11,415, Level 70
Points: 11,415, Level: 70 Points: 11,415, Level: 70 Points: 11,415, Level: 70
Level Up 42% Completed
FF Reputation: 59 katiekay Excellent Standing Member
Buy-Sell-Trade Rating: (48)
Possibly on both. The bolt is really not that hard to get to, it attaches to the end of the radiator support. Easiest way to get to it is from underneath the car, you might have to move the fender liner out of your way to see it.
Hatch Nation #8
September 2012 Ride of the Month
katiekay is offline
