Aftermarket stereo illumination - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-05-2013, 05:53 PM   #1
opies
Fan#: 109709
What I Drive: 2012 Focus SEL
Points 398, Level 7
Points: 398, Level: 7 Points: 398, Level: 7 Points: 398, Level: 7
Level Up 96% Completed
FF Reputation: 2 opies Good Standing Member
Has anyone successfully gotten their aftermarket stereo to function as intended based on the headlights being on or off? I have the FRST2 hooked up and apparently it does not send a signal to a Pioneer avic x940 to tell it whether the lights are on or off. I would love for it to trigger the automatic dimmer and night/day feature on the nav screen.
opies is offline
Old 03-05-2013, 06:19 PM   #2
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
unfortunately that works in very few cars. most don't send the proper signal for it to work right. I installed at best buy for several years and we never used it. couldn't promise the customer it would work properly so we didn't bother with them.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 03-05-2013, 06:29 PM   #3
opies
Fan#: 109709
Points 398, Level 7
Yeah, I have never, ever, gotten one to work correctly.
I wonder if it is possible to tap the decks illumination wire into the stock headlamp circuit to make it functional?
opies is offline
Old 03-05-2013, 06:32 PM   #4
Kipp
Kipp's Avatar
Fan#: 31300
would depend what trigger the headunit is looking for and if it have a voltage limit for it. if you can provide the correct signal then i'm sure we can find a way to make it work. i'll see if i can find the owners manual for your unit online tomorrow and look in to it.
Midwest Crew #22
Kipp is offline
Old 03-05-2013, 06:38 PM   #5
opies
Fan#: 109709
Points 398, Level 7
One would think its just a ground switch, like the parking brake wire. Just need to tell the unit the lights are on so it will automatically dim. Are the stock panels back lights always on? I never thought to look.
Here is the manual...
http://www.pioneerelectronics.com/St...nual030212.pdf
opies is offline
Old 03-06-2013, 07:35 AM   #6
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
Points 57,400, Level 100
Points: 57,400, Level: 100 Points: 57,400, Level: 100 Points: 57,400, Level: 100
Level Up 0% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
Never mind. I misread your question. It sounds like Kipp has you pretty much covered.
One thing I will say is that to get my headunit (Pioneer DEH-P3500) to dim with the headlights, all I needed to do was wire the elimination input from the car into the elimination wire from the headunit. Io don't know how your radios wiring pigtails and the cars wiring harnesses are set up but I assume it will be something similar.
Hatch Nation #13 : Rally Revolution #13 : ROTM Jan '13
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is offline
Old 03-06-2013, 07:59 AM   #7
Kipp
Kipp's Avatar
Fan#: 31300
well neither that manual or the install manual have the info I was looking for. was trying to see what that illumination trigger needed to work. It should just need to see either a ground or possitive input for it to change; i'm just not sure which one. if all it wants is just a trigger and not a dimming input then you can use either the illumination wire or a parking light wire. you may need a relay though to change it to the correct trigger to work. Did your car come with sync? If not then the ill wire at the headunit should work, but if it had sync then looks like it's a data wire and you'll have to go to the parking light.
Midwest Crew #22
Kipp is offline
Old 03-06-2013, 08:15 AM   #8
opies
Fan#: 109709
Points 398, Level 7
Originally Posted by 02fordsvt View Post
My Pioneer DEH-P3500 unit dims with the lights but it was built to do it. If your unit wasn't originally built to automatically dim with the exterior lights, i doubt you will be able to do it very easily.
The x940bt is designed to pick up the signal from the illumination circuit.
Sent from my MB860 using FF Mobile
opies is offline
Old 03-06-2013, 08:18 AM   #9
opies
Fan#: 109709
Points 398, Level 7
It does have Sync. I have to pull the frst2 module out to get some info off it because the its not programming the steering wheel controls, ill see what the factory illumination wire is giving for an output.
opies is offline
Old 03-06-2013, 08:19 AM   #10
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
Forum Activity 17%
I just saw that and edited my first post.
