Wanting wheels but what to do about TPMS sensors??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-05-2013, 11:16 AM   #1
katkrazy2007
Fan#: 105248
What I Drive: 2008 Ebony Focus SES
FF Reputation: 1 katkrazy2007 Good Standing Member
Angry Wanting wheels but what to do about TPMS sensors???
I am in the market for new aftermarket wheels for my 2008 SES sedan, so I did a little research and on Tirerack.com it says for 320 they will put tpms sensors into my new wheels and tires mounted and balanced which is good. But when I called Ford to see what they charged for the same service and to mount my new already mounted tires and wheels onto my car and they said 200 per wheel to put my old tpms sensors on my new wheels and tires!! Is this true?? They also said I couldn't flash them to make it to where it didn't keep giving a low tire pressure signal if I decided to go without tpms sensors at all because of the high price.. why is it so cheap to have new tpms sensors put in the wheels from Tirerack, but so extremely expensive to move my old sensors to my new wheels and tires??? I feel like something isn't right and I need input from you all. Please and thanks!!
<Focus Freak>
katkrazy2007 is offline
Old 03-05-2013, 11:30 AM   #2
Rubix
Rubix's Avatar
Fan#: 109903
What I Drive: 2011 SES
FF Reputation: 1 Rubix Good Standing Member
Im not 100% sure on this, but I believe our sensors are just the screwed in type, not the kind with the band. It shouldnt be that difficult to just move the ones on the stockers over to the new wheels. Id just get the wheels and take it to a tire shop and have them mount it on.
Rubix is offline
Old 03-05-2013, 11:31 AM   #3
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,734, Level 76
Points: 13,734, Level: 76 Points: 13,734, Level: 76 Points: 13,734, Level: 76
Level Up 21% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
The dealer is most likely charging you for new OEM ford sensors, and mounting of your new wheels plus the breakdown of your old wheels and tires, which IIRC that runs around $50 a wheel and $100 a sensor, so the dealer is about right. The sensors from Tire Rack most likely arn't OEM ford (you'll have to check on this) but they will work, plus they only have to deal with one set of wheels so the price from them sounds about right as well.
SkyPilot is online now
Old 03-05-2013, 12:07 PM   #4
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
Our style sensors are the band style, I think they switched to the other style in 2010 IIRC. To move your old sensors to the new rims they need to use new bands because the OEM are not reusable. If I were you I would use the valve stem TPMS sensors, as long as they are the same Mhz they will work... Last I checked the frequencies are all the same.
If you can't wear it out, burn it off
DarderSauce is offline
Old 03-05-2013, 12:10 PM   #5
ThaKillerKlown
ThaKillerKlown's Avatar
Fan#: 73791
What I Drive: '11 SES Sedan
Points 391, Level 7
Points: 391, Level: 7 Points: 391, Level: 7 Points: 391, Level: 7
Level Up 82% Completed
Forum Activity 3%
FF Reputation: 1 ThaKillerKlown Good Standing Member
2008's use sensors banded to the wheels rather than valve stem sensors...
I know this because I had an 08 SE that I put 09/10 SES rims on and the car would not read the new wheels because the sensors were NOT interchangeable.
Its not hard to remedy however... Simply cut the old bands, buy new bands and move the sensors from the old wheels to the new ones.
ThaKillerKlown is online now
Old 03-05-2013, 12:16 PM   #6
DarderSauce
Fan#: 95564
Sensors are interchangeable, PM Slammed2.0 he has done it for a few foci.
Old 03-05-2013, 12:24 PM   #7
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,733, Level 24
Points: 1,733, Level: 24 Points: 1,733, Level: 24 Points: 1,733, Level: 24
Level Up 33% Completed
Forum Activity 2%
FF Reputation: 5 Miller88 Good Standing Member
I've seen a few things online that people have done - including grabbing a trailer wheel from Harbor Freight and mounting all 4 sensors inside of it.
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 03-05-2013, 01:09 PM   #8
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 969, Level 16
Level Up 69% Completed
FF Reputation: 4 gtferrari Good Standing Member
On my 08 i had the bands. Picked up a set of bands on ebay for $20 the dealer gets 50-75 ea. If your not using the other wheels then transfer the sensors to the other wheels. If not pick up some new sensors on ebay too. Then stop by your dealer and have the car trained to the new sensors
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
Old 03-05-2013, 02:39 PM   #9
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 18,945, Level 87
Points: 18,945, Level: 87 Points: 18,945, Level: 87 Points: 18,945, Level: 87
Level Up 19% Completed
Forum Activity 7%
FF Reputation: 7 badazz2010focus Good Standing Member
I have valve stem style sensors all thought there computers say I do not....LOL
badazz2010focus is offline
Old 03-05-2013, 03:18 PM   #10
katkrazy2007
Fan#: 105248
All of this is incredibly helpful.. Thanks so much! So, since I have the bands in mine, I can just buy new bands and have the place I am having the tires mounted on at put the new bands in my new wheels and transfer my old sensors? Then is it required to take my car to Ford to have my car trained to the sensors if I just use my old ones?
Also, where I am ordering my new wheels and tires from will mount my new tires onto the new wheels and Hunter Road Force balance my tires for no extra cost -- Can the tech at the tire place still place my new bands and old sensors into my new wheels and tires even if they are mounted and balanced already? Or should I order my tires unmounted from the wheels?? I would like to have them mounted and balanced by tirerack since they use the hunter road force balancing and also do it at no extra charge.
<Focus Freak>
