removing hatch badges and dealer name - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-05-2013, 11:22 AM   #11
Slo86GT
Slo86GT's Avatar
Fan#: 88885
What I Drive: 2013 Sterling Gray Focus SE
Points 3,119, Level 34
Points: 3,119, Level: 34 Points: 3,119, Level: 34 Points: 3,119, Level: 34
Level Up 46% Completed
FF Reputation: 2 Slo86GT Good Standing Member
Hairdryer, floss to get the badges off.
More hairdryer, and a plain old eraser from the dollar store to get the foam/sticky off.
Then get the film of the sticky off with WD40 and microfiber. Finish up with claybar/wax to your content.
Came out beautiful.
2013 Focus SE 5M Daily Driver
2003 Mustang GT V8/Auto Wife's Daily
1986 Mustang GT V8/5M Toy
- Jody -
Slo86GT is offline
Old 03-05-2013, 01:11 PM   #12
Jim_J
Jim_J's Avatar
Fan#: 109775
What I Drive: 2013 Silver SE with a shudder trans
FF Reputation: 1 Jim_J Good Standing Member
The factory plastic badges can often be simply lifted with a mix of force and care when new, that's all I used to debadge mine with no reside, careful lifting after parking in the sun. YMMV is you are in a cold climate. Floss can help, but it can also cut the glue strip making cleanup harder.
Factory vinyl might or might not peel off clean. I've used the "glue off" stuff to get residue off, then wash it down completely to get all solvent off as quick as possible and had good results, but it wasn't needed on this car as the dealer didn't put a sticker on.
Jim_J is offline
Old 03-05-2013, 01:45 PM   #13
wacky
Fan#: 110451
What I Drive: 2013 Black Focus Titanium Hatch
Points 82, Level 1
Points: 82, Level: 1 Points: 82, Level: 1 Points: 82, Level: 1
Level Up 64% Completed
FF Reputation: 2 wacky Good Standing Member
i used hairdryer and floss for mine... works great! :)
wacky is offline
Old 03-05-2013, 02:14 PM   #14
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,339, Level 77
Points: 14,339, Level: 77 Points: 14,339, Level: 77 Points: 14,339, Level: 77
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 19%
FF Reputation: 15 Elizabeth Great Standing Member
I took mine off too. Usually if done right away it is easy to peel off the dealer stickies. Mine was separate vinyl lettering. no big deal.
Agree a bit of floss under the badges works well. Just saw under the badge and it comes off. the residue is easy to rub off.
Elizabeth is offline
Old 03-05-2013, 02:23 PM   #15
Jim_J
Jim_J's Avatar
Fan#: 109775
I used an 80 degree day with the back end parked in the sunshine, and just carefully lifted the badges off from the corners with my thumbnails. Easy, no residue, no marks or rubbing and no AC power needed and saved the floss for my teeth. I've done it this way since they started using stick on badges instead of metal hole mounted ones where debadging took bondo, sanding and paint.
It's much easier when the badges are new.
If you have a lack of good weather a hair dryer will make it easier.
Sometimes it's good to put something under the side opposite the one you are lifting, to keep the opposite side of the badge from digging into the paint when lifted. It's never been an issue for me with the plastic badges, but some sharp mold flashing could conceivably dig in.
Jim_J is offline
Old 03-05-2013, 03:55 PM   #16
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
did mine after it sat in the sun for a few hours last summer, just peeled em right off and then removed the adhesive with some goo gone stuff. worked fantastic
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 03-05-2013, 05:07 PM   #17
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
Points 4,174, Level 41
Points: 4,174, Level: 41 Points: 4,174, Level: 41 Points: 4,174, Level: 41
Level Up 12% Completed
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Heat gun will get it off in no time, than you can peel the adhesive off which your fingers when everything heated up.
I now drive a Japanese Ford.
macdiesel is offline
Old 03-06-2013, 02:38 PM   #18
dragonpalm
dragonpalm's Avatar
Fan#: 104183
What I Drive: 2013 White Platinum Titanium Sedan
Points 571, Level 11
Points: 571, Level: 11 Points: 571, Level: 11 Points: 571, Level: 11
Level Up 43% Completed
FF Reputation: 3 dragonpalm Good Standing Member
I had the dealer remove its stickers as a condition of sale. I'm surprised not everyone does this. Why be a moving advertisement for them after you've already purchased?
dragonpalm is offline
Old 03-06-2013, 02:43 PM   #19
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,057, Level 67
Points: 10,057, Level: 67 Points: 10,057, Level: 67 Points: 10,057, Level: 67
Level Up 2% Completed
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
My dealer only put a tacky plate frame on the back of the car, I only left it long enough to get the actual plate and then went out to get a plain black plastic frame. No dealer stickers, etc.....
suss6052 is online now
Old 03-06-2013, 02:58 PM   #20
150mphzetec
Fan#: 77175
What I Drive: 00 yellow zetec
Points 389, Level 7
Points: 389, Level: 7 Points: 389, Level: 7 Points: 389, Level: 7
FF Reputation: 2 150mphzetec Good Standing Member
^^this. I had the same thing done with the same condition. Unless they are sponsoring the car by providing replacement parts or funding for racing, then they can stick those stickers on toilet paper so people can wipe on them [bootyshak
150mphzetec is offline
