Fuel Efficiency - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-04-2013, 09:07 PM   #1
clayton89
Fan#: 108214
What I Drive: 2006 Sonic Blue ZXW
Points 542, Level 10
Points: 542, Level: 10 Points: 542, Level: 10 Points: 542, Level: 10
Level Up 84% Completed
FF Reputation: 1 clayton89 Good Standing Member
Fuel Efficiency
My friend has found a pretty good deal on a set of OZ ultraleggeras 16 x 7 and he currently has 15 inch steelies. He was curious if the increase in contact patch of the tire going from 185 - 205 will offset the increase mpg factor of having lightweight wheels of approx 5lbs lighter?
Thanks for your comments
Edit: He has a 05 4 door focus
clayton89 is online now
Old 03-04-2013, 09:28 PM   #2
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,434, Level 65
Points: 9,434, Level: 65 Points: 9,434, Level: 65 Points: 9,434, Level: 65
Level Up 28% Completed
Forum Activity 7%
It may but most likely it would be negligible.
as an example I went from 16" wheels with 205/55/r16 tires to 17" wheels with 225/45/r17 on my Subaru and actually got better fuel economy because the wheel and tire combo was lighter than the original size.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 03-04-2013, 10:54 PM   #3
clayton89
Fan#: 108214
That was my thought, but I am guessing that the stock steel wheels weigh like 20 lbs plus the weight of the tires. So my guess would be that the 16 inch tires would weigh about the same maybe less, But I do believe that saving 5lbs per wheel will be very beneficial for mpgs.
Old 03-05-2013, 12:13 AM   #4
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 7%
It depends on the tires really. My 16" tires around 25lbs each and my 17" tires are about 20lbs each. The wheel weights I do not know off hand but i had looked the weight of my tires on tirerack.
Old 03-05-2013, 04:48 PM   #5
clayton89
Fan#: 108214
just looking on tire rack at a few tires it looks that the 16 inch tires are around 20lbs versus 15 inch tires are around 18lbs
Old 03-05-2013, 04:56 PM   #6
clayton89
Fan#: 108214
OK looking at a post on the forum from Julian at Tire Rack stated that theirs are like 19lbs a piece shown here and over on this discussion it looks like the factory may weigh 20.5 lbs (figuring a 18lb tire 38.5 - 18 = 20.5) do you guys think that a total weight loss of wheel weight 5lbs plus the 2lb gain in tire and greater contact patch width would hurt gas mileage or hardly be noticeable?
Old 03-05-2013, 05:03 PM   #7
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
don't forget the aero impact :D
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 03-05-2013, 05:21 PM   #8
clayton89
Fan#: 108214
I know lol. I just know I have seen a few people here complain about their mileage based on increasing wheel sizes, but usually they all increase the width of the tire. I have seen a few people say that with the increase in contact patch will increase friction with road surface leading to less MPGs
Old 03-05-2013, 05:44 PM   #9
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,701, Level 76
Points: 13,701, Level: 76 Points: 13,701, Level: 76 Points: 13,701, Level: 76
Level Up 13% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Thats where friction comes in= more friction= more stick. Get mpg eco type tires & you'll loose friction but have better mpg.
felixthecat is offline
Old 03-05-2013, 06:25 PM   #10
Levi05
Levi05's Avatar
Fan#: 89386
What I Drive: 2005 Liquid Gray ST
Points 763, Level 14
Points: 763, Level: 14 Points: 763, Level: 14 Points: 763, Level: 14
Level Up 63% Completed
FF Reputation: 1 Levi05 Good Standing Member
If you do some deep research, you will find that wider tires will typically have less rolling resistance. And going to a wider tire doesnt increase the contact patch but only changes the shape of the contact patch (if tire pressures remain the same as before).
It gets complicated but simple answer is a wider tire alone wont hurt fuel mileage. Wheel weight and tire compound/tread design have a bigger impact.
Go to autospeed.com and lookup an article called "tyres, grip, and all that..." <- explains everything. Haha.
Levi05 is offline
