Bad/Frozen VCT Gear? Miss drvin my baby plz help? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-04-2013, 06:32 PM   #1
lilfocusfreak
Fan#: 100585
What I Drive: 04 sonic blue svt
FF Reputation: 1 lilfocusfreak Good Standing Member
Well its one thing after another with my svt..I love the car too death but its been such a pain in the ars since day one.. So otherday I took a 8 hour trip to columbus there and back and my vct gear on my intake cam started making kind of a ticking/ rotational, metal tapping metal sound...Had no problems what so ever with the car that night, no power loss no hesitation nothing, ran completley fine... Well the next morning I go to start to leave for work and it just cranks over and kinda wants to start but wont, so the third time i tried cranking it over it sounded like a backfire threw thee intake so i let off... The next crank i noticed it cranked over smooth n quick with no compression.. So checked coil, plugs,compression n made sure she had gas n spark wich she does, but I notcied my timing belt was loose only between the two cam gears on the top...so with some reading iv learned u are suppose to be able to turn the intake gear towards the windsheild? i know u shoulnt b able to see play with the t-belt tensioned properly but my belt between the 2 gears has about half inch of play I can move up and down.. The vct gear I cant spin towards windsheild n seems locked up..Now shouldnt (with the play in my belt) my vct gear spin back towards windsheild and remove the play in my belt? Isnt this what the spring in the vct gear is for to hold the gear towards winsheild? did timing about 12 k ago n know my belt hasnt been loose like this until this happend... any advice would be greatly appreciated...Anybody switched to aftermarket adjustable gears? if so what all does it take to do so?
lilfocusfreak is offline
Old 03-04-2013, 09:46 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,517, Level 100
Points: 52,517, Level: 100 Points: 52,517, Level: 100 Points: 52,517, Level: 100
Level Up 0% Completed
Forum Activity 62%
Activity: 62% Activity: 62% Activity: 62%
Buy-Sell-Trade Rating: (28)
Sounds to me like your have issues with the idler / tensioner , the VCT should turn but not easy at all till you bleed the oil out of it
The VCT gear is not there to take the slack out thats the tensioners job , I would check to make sure one is not loose or bearing goin out on them , thats about the only place you can get slack from
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 03-05-2013, 12:47 PM   #3
lilfocusfreak
Fan#: 100585
Thanks Tom... I will look into that today when I get off work... I hope its simple fix as so... but knowing my luck I doubt it... Was just weird because it only seems the belt is loose between the two cam gears like my vct is stuck towards the frnt bumper....If I remember correctly wouldnt the vct gear want to spring back towards the windsheild and take the slack out of the belt between the two gears? If the tensoiner is going bad n allowing the belt to slack, wouldnt it start to slide off the gears towards the pass fender.. Dealt with this when I did my timing tryin to get the belt tensioned right, too tight i thought moved belt towards engine, too loose made belt run towards fender part of pulley..,. My belt is still in the middle where I tensioned it too when I did my timing...
Old 03-05-2013, 12:55 PM   #4
lilfocusfreak
Fan#: 100585
Also I have read about a vct delete kit that you make Tom? What are the ups and downs of deleting the vct? Its pretty much a stock engine:( would this be a waste of my time? I appreciate your time and input Tom, thanks once again..
Old 03-05-2013, 02:32 PM   #5
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 62%
The VCT doesnt spring anywhere
The VCT Elim works but you have to buy 2 adj cam gears and then some time on the dyno
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
