Horrible misfire - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-03-2013, 05:31 PM   #1
JoeGrzesiak
Fan#: 110749
What I Drive: 2001 Blue ZTS
FF Reputation: 1 JoeGrzesiak Good Standing Member
Angry Horrible misfire
Hi, I am new here and have searched for a solution, but couldn't find much.
A couple days ago I was driving and it started to jerk, like when my coil pack was bad. So I replaced the plugs, wires, fuel treatment stuff, and a fuel filter. I just got a new coil pack and now I've got a check engine light saying misfire cyls 1 and 4. Now it barely wants to run. Once in a while before I shift it runs decent before it runs horrible again.
Thanks
JoeGrzesiak is offline
Old 03-04-2013, 08:03 AM   #2
JoeGrzesiak
Fan#: 110749
Now today it doesn't want to idle.
Old 03-04-2013, 08:10 AM   #3
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,710, Level 94
Points: 23,710, Level: 94 Points: 23,710, Level: 94 Points: 23,710, Level: 94
Level Up 36% Completed
Forum Activity 14%
have you checked the pins and wiring at the electrical connector to the coil pack?
Many people have had a problem as you are describing because a pin has backed out, causing half of the primary system to fail.
mikebontoft is online now
Old 03-04-2013, 09:12 AM   #4
JoeGrzesiak
Fan#: 110749
I just went out to look, what is the best way to check it? and best way to repair? Thanks again
Old 03-04-2013, 09:18 AM   #5
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
Motorcraft part # WPT-517
How to link:
http://www.focusfanatics.com/forum/showthread.php?t=182625
BC_ZX3 is offline
Old 03-04-2013, 10:08 AM   #6
JoeGrzesiak
Fan#: 110749
Awesome, thank you guys. I'm gonna grab a pigtail after work. Hopefully that's what's wrong.
Old 03-04-2013, 10:29 AM   #7
ShoOff
ShoOff's Avatar
Fan#: 109590
What I Drive: 2013 Performance Blue SE Hatchback
Points 1,858, Level 25
Points: 1,858, Level: 25 Points: 1,858, Level: 25 Points: 1,858, Level: 25
Level Up 58% Completed
FF Reputation: 16 ShoOff Great Standing Member
a leak in your intake manifild can also cause mulitple cyclinder misfire and such
ShoOff is offline
Old 03-04-2013, 11:25 AM   #8
JoeGrzesiak
Fan#: 110749
But could that get progressively worse also?
Old 03-04-2013, 08:15 PM   #9
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
When you get a misfire in cylinder 1 and 4 as a pair (or 2 and 3 as a pair) it's usually indicative of an ignition primary circuit problem since the Ford "wasted spark" ignition system fires the plugs in those groupings. Of the three wires comprising the ignition coil connector, one of the two thinner outer wires should show physical damage, chafing, splitting or corrosion. (The thicker middle wire is 12V supply.)
Easiest thing to do is to simply tug on the wires; they usually break or come apart if bad.
If the problem is severe and persistent enough, eventually you'lll throw a DTC code - P0350, P0351 or P0352.
BC_ZX3 is offline
Old 03-04-2013, 08:26 PM   #10
JoeGrzesiak
Fan#: 110749
Yeah I started to pull the harness apart and when I was moving the harness around, one of the wires fell off. So I'm hoping when I replace that, everything will be ok haha. I was going to post a picture, but I figured you all have seen that before. Also I have no idea how to post pictures. Haha
