HID install (with DRL, no bulb out error) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-03-2013, 12:23 AM   #1
KibaWolf
KibaWolf's Avatar
Fan#: 97035
What I Drive: 2012 Ford Focus Titanium
Points 2,609, Level 31
Points: 2,609, Level: 31 Points: 2,609, Level: 31 Points: 2,609, Level: 31
Level Up 6% Completed
FF Reputation: 1 KibaWolf Good Standing Member
hello everyone I know a lot of HID thread have been made in the past but I am making a new one for any canadian focus owner that have DRL and would like to install HID and have NO bulb out error, and also the posibility to completly turn off their headlight without have any bulb out error either, I havent installed mine yet (will do in the upcomming month) but I took a wiring diagrams that I edited for my need, so here it is:
You MUST install your HID kit with a relay harness. If you have DRL or not doesnt matter, if you do not install it the HID will flicker because of the lower voltage used from either DRL or under deceleration of the car because of the lower voltage sent to the headlight circuit which is (9-9.5v) under deceleration.
You also MUST use the resistor if you do not want any Bulb Out error.
The on/off switch is optional for people that would like to turn off the HID completly (because of DRL here in canada) while the car is still running. the way the switch is placed is after the actual resistor, so even with the HID completly turned off you wont get a bulb out error. (its simply cut the signal to the relay which turn everything off, so you can run just with fog light if you want.)
here is the actual resistor assembly that youll need, you will need to order 2 as they come as single unit (select universal fit in the choice box):
http://retro-solutions.net/product-i...hm-pid601.html
and here is the HID kit I will order (55 watts) (Do not add the relay harness option, this harness wont work correctly for the focus):
http://www.vvme.com/hid-headlights/s...conversion-kit
This is the Relay Harness that youll need (dont forget to select H11 connectors in the box, they give H1 connector by default):
http://retro-solutions.net/product-i...ss-pid582.html
I hope this will help out some of the canadian owner with DRL in here :)
Ill be posting picture of my HID installed when im done but for now I havent bought anything.
KibaWolf is offline
Old 03-03-2013, 02:39 PM   #2
KibaWolf
KibaWolf's Avatar
Fan#: 97035
Double Post
KibaWolf is offline
Old 03-08-2013, 07:32 PM   #3
KibaWolf
KibaWolf's Avatar
Fan#: 97035
some of my stuff from retro solution just arrived today (ordered monday and got it on friday and im on canada, wow that is quick! thx to retro solution)
Im got my relay harness, my 2 resistors and also my capacitor (Which I didnt used because its turned out to be useless.)
Im still waiting my HID kit which I ordered today since I was only expecting the stuff from retro solution to arrive by the next week, so next weekend I should intall those HID
I changed my mind and went with 55 watts HID, cant wait to see the result.
KibaWolf is offline
Old 03-09-2013, 12:22 PM   #4
VOLDAR
VOLDAR's Avatar
Fan#: 90444
What I Drive: Volt 2014, White Diamond
FF Reputation: 3 VOLDAR Good Standing Member
Nice! Let us know how things go.
White Platinum Metallic Tri-Coat
303A, 6-Speed SelectShift Automatic, 17" Aluminum wheels, Luxury Package,
Parking Technology, Navigation, Winter Package
---replaced by---
Chevy Volt 2014, White Diamond, Luxury Package, S1, Navigation.
VOLDAR is offline
Old 03-09-2013, 12:25 PM   #5
Merrigan
Merrigan's Avatar
Fan#: 104581
What I Drive: 2013 Black SE Hatch
FF Reputation: 2 Merrigan Good Standing Member
Subscribing. I want to see the outcome.
Sent from your mom's house.
Sonics MK3 Crew #21
Merrigan is offline
Old 03-09-2013, 01:26 PM   #6
dbsimms63
Fan#: 110359
What I Drive: 2013 Performance Blue Titanium 5dr
Points 1,715, Level 24
Points: 1,715, Level: 24 Points: 1,715, Level: 24 Points: 1,715, Level: 24
Level Up 15% Completed
Forum Activity 2%
FF Reputation: 2 dbsimms63 Good Standing Member
subscribing
dbsimms63 is offline
Old 03-09-2013, 06:12 PM   #7
KibaWolf
KibaWolf's Avatar
Fan#: 97035
Ill keep you updated guys, Since its weekend my HID kit wont be shipped before monday (3-5 business days to deliver) so by friday Ill start installing everything, ill try to take as much pictures as I can.
To wait here is a picture of some others stuff I bought today to complete my setup which is extension wiring with my on/off switch.
I will solder and shrink everything of course as I want it to last for a long time.
KibaWolf is offline
Old 03-11-2013, 11:53 PM   #8
PandT
Fan#: 110640
What I Drive: 2013 Titanium Hatch 18" Plat White
FF Reputation: 2 PandT Good Standing Member
subscribing
2013 Titanium HB - Handling pkg. - Platinum White
PandT is offline
Old 03-12-2013, 09:24 PM   #9
ATFIII
ATFIII's Avatar
Fan#: 110143
What I Drive: 2012 YBM Ford Focus Titanium
FF Reputation: 1 ATFIII Good Standing Member
Looking forward to seeing the installation!
UNITED STATES COAST GUARD
Semper Paratus!
ATFIII is offline
Old 03-13-2013, 05:21 AM   #10
Focus805
Fan#: 90582
What I Drive: 2012 Frosted Glass SEL HB 300A
Points 740, Level 14
Points: 740, Level: 14 Points: 740, Level: 14 Points: 740, Level: 14
Level Up 40% Completed
FF Reputation: 1 Focus805 Good Standing Member
Looks like fun!
Focus805 is offline
