SPI Hiccup - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-02-2013, 09:31 PM   #1
2003focusowner
Fan#: 51939
What I Drive: 2003 Focus SE SPI
Points 5,246, Level 46
Points: 5,246, Level: 46 Points: 5,246, Level: 46 Points: 5,246, Level: 46
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 2 2003focusowner Good Standing Member
SPI Hiccup
My 2003 SPI has always had an occasional hiccup going down the highway. seems to be a little prevelant lately. I have never been able to find the cause of this. I know its been mentioned on here before about others having the same issue. Anyone recall what may have been found to be causing the hiccup?
My SPi has been good to me....just rolled 216,000 miles.
2003focusowner is offline
Old 03-02-2013, 09:42 PM   #2
dromeda
Fan#: 28157
Points 155, Level 3
Points: 155, Level: 3 Points: 155, Level: 3 Points: 155, Level: 3
Level Up 10% Completed
FF Reputation: 1 dromeda Good Standing Member
Mine's done this twice:
1) Every now and then it would shimmy then stop until it always did it and it turned out to be a vacuum leak on the PCV hose (from the intake tube rubbing on it).
2) Spark plugs needed changed. There was no electrode/insulation left and it was arcing inside the plug (or not at all) causing misfires.
Since you said highway, I'm guessing it's a misfire issue. Have you tried pulling any codes? Misfires can happen three ways: no spark, no fuel, no air. When was the last time you pulled the plugs? Any misfire or lean codes?
dromeda is offline
Old 03-03-2013, 08:26 AM   #3
2003focusowner
Fan#: 51939
There have been no codes with this issue. Plugs have 60K on them. I typically change them every 50k. This has done this ever since I bought the car in 2004. Its just starting to do it a little more frequent now.
Old 03-03-2013, 08:29 AM   #4
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 36,806, Level 100
Points: 36,806, Level: 100 Points: 36,806, Level: 100 Points: 36,806, Level: 100
Level Up 0% Completed
Wouldn't hurt to check and or change the PCV valve and hose. Take the valve out and shake it if it rattles than it still works. If it don't then it needs replaced.
TheGlassMaker is offline
Old 03-03-2013, 08:33 AM   #5
2003focusowner
Fan#: 51939
The PCV valve is ok....just checked it.........will have to check the hose......I assume one would be looking for a collapsed hose?
Old 03-03-2013, 08:42 AM   #6
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
That or cracked. They are known to dry out and cause a vacuum leak.
Old 03-03-2013, 09:29 AM   #7
dromeda
Fan#: 28157
Points 155, Level 3
Could try changing out spark plug wires and coil pack too.
dromeda is offline
Old 03-03-2013, 06:11 PM   #8
Donnyd21
Fan#: 109211
What I Drive: 2002
FF Reputation: 1 Donnyd21 Good Standing Member
O2 sensor, primary, change it, they are only goo for 80-90k miles before they become slow/very inaccurate.
I HAVE GOOD USED OEM PISTON AND ROD ASSEMBLIES FOR ALL 2.0L SPI ENGINES (FOCUS, ESCORT AND TRACERS)!! PM ME.
Donnyd21 is offline
