Oil Pressure concern/question - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST EcoBoost Performance (2013-Current)
Focus ST EcoBoost Performance (2013-Current) The place to chat about the 2.0L EcoBoost engine performance, tuning and exhaust related upgrades.
Old 03-05-2013, 11:07 PM   #11
shineboy
shineboy's Avatar
Fan#: 60173
What I Drive: 2013 ST, 2004 Cobra
Points 1,251, Level 19
Points: 1,251, Level: 19 Points: 1,251, Level: 19 Points: 1,251, Level: 19
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 1 shineboy Good Standing Member
Originally Posted by spinadog View Post
confirmed - I see the same readings. My car is also white - could that explain it? :-P
Has to be the explanation! Hahaha
2013 ST2 for DD
2004 Terminator for fun
shineboy is offline
Old 03-13-2013, 01:43 AM   #12
MyOtherCarIsAPlane
Fan#: 106673
What I Drive: 2013 Tangerine Scream ST
FF Reputation: 1 MyOtherCarIsAPlane Good Standing Member
Mine is Tangerine Scream, but it's almost exactly the same for each condition/temp/pressure. Not the color
MyOtherCarIsAPlane is offline
Old 03-13-2013, 02:50 AM   #13
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,723, Level 94
Points: 23,723, Level: 94 Points: 23,723, Level: 94 Points: 23,723, Level: 94
Level Up 38% Completed
Forum Activity 13%
it's fine. Remember that gauges lie... there will be variations between individual vehicles as well.
mikebontoft is online now
Old 06-26-2013, 11:53 PM   #14
acbauza
Fan#: 104447
What I Drive: 2013 Performance Blue Focus ST
FF Reputation: 1 acbauza Good Standing Member
What he said. It's ok. Under heavy load aka track use the oil temp will go past the half and near the 3/4 mark. So long as it doesn't get into the 300* mark you are ok.
Don't over think. Just drive it.
acbauza is offline
Old 08-03-2013, 09:54 PM   #15
vanace
Fan#: 350
What I Drive: 2005 ST
FF Reputation: 1 vanace Good Standing Member
It is questions like this that made Ford years ago go to idiot gauges for oil pressure. Years past people complained like you. "my oil pressure is low". It wasn't. Logic tells you if a oil pump is turning slow (idle) that it isn't going to produce as much pressure as when it is doing 3000 RPM. So Ford put idiot gauges in. Now finally Ford put a real pressure gauge in. And soon complainers who know nothing of mechanical things will complain enough that Ford will resort to put idiot gauges back in. Carful what you complain about.
ST crew #18
vanace is offline
Old 08-10-2013, 12:43 AM   #16
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,618, Level 31
Points: 2,618, Level: 31 Points: 2,618, Level: 31 Points: 2,618, Level: 31
Level Up 12% Completed
Ford oil pressure gauges are just idiot lights masquerading as gauges.
The SVT oil pressure gauge was a lie, it simply looks to see if the idiot light sensor switch for oil pressure is made, then give the gauge a phony output signal based off RPM. The service manual explains it. it's not a pressure gauge, it's an idiot light with a needle that moves based on RPM.
I bet there is a water temperature component for the new ST oil pressure gauge that tells it to show high oil pressure until the coolant is warmed up.
elsolo is offline
Old 08-17-2013, 06:02 PM   #17
PrankOne
PrankOne's Avatar
Fan#: 117902
What I Drive: 2013 Tuxedo Black Metallic ST3
FF Reputation: 1 PrankOne Good Standing Member
You're good bro. Mine reads the exact same thing, & mine is still running on the factory oil (meaning it hasn't had it's first oil/oil filter change).
I got 99 problems but my Focus ain't one 🚘
PrankOne is offline
Old 08-26-2013, 09:28 PM   #18
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,097, Level 34
Points: 3,097, Level: 34 Points: 3,097, Level: 34 Points: 3,097, Level: 34
Level Up 32% Completed
FF Reputation: 11 hEaT Great Standing Member
The ST has a real boost and oil pressure gauge. The indicated oil temperature is inferred from coolant temp and oil pressure.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster. ...idiots
hEaT is offline
Old 08-29-2013, 05:26 PM   #19
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Why you use 270 sweep gauges instead of cheap 90 degree ones like that, the error if any small fall off in pressure is hard to see there. If electric oil pressure then greater error, they are never dead accurate.
Factory gauges usually suck................
amc49 is offline
