00-04 headlight disassembly for harness replacement - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-02-2013, 03:40 PM   #1
X-Rated
X-Rated's Avatar
Fan#: 55237
What I Drive: 03 Tan ZTW
Points 2,707, Level 31
Points: 2,707, Level: 31 Points: 2,707, Level: 31 Points: 2,707, Level: 31
Level Up 72% Completed
Forum Activity 3%
FF Reputation: 4 X-Rated Good Standing Member
Buy-Sell-Trade Rating: (12)
I recently had 1 of the plugs that goes directly into the bulb completely disintegrate and I need to replace the harness (I have a 03 ZTW). I have searched the threads and how-to's and found nothing on how to take a part a headlight so this harness can be replaced. Can anyone help?
2003 ZTW - 2.0L 16v Zetec: 9mm Racing plug wires, long style CAI, shorty header w/down pipe, glasspack for a resonator & raptor muffler
Drive it like you stole it!!
X-Rated is offline
Old 03-02-2013, 06:41 PM   #2
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
Points 58,328, Level 100
Points: 58,328, Level: 100 Points: 58,328, Level: 100 Points: 58,328, Level: 100
Level Up 0% Completed
Forum Activity 14%
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
Do you have a picture of the part your talking about
One way the fix something inside the headlight is to get a "new" one. One from a salvage yard should be pretty reasonable and you can also buy them online.
Hatch Nation #13 : Rally Revolution #13 : ROTM Jan '13
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is offline
Old 03-02-2013, 07:11 PM   #3
X-Rated
X-Rated's Avatar
Fan#: 55237
Forum Activity 3%
I do not at the moment but it's the harness you would pull off to change the bulb if it was burned out. I was looking at upgrading the harness and plug so this wouldn't happen again.
If you need a pic I can get it.
X-Rated is offline
Old 03-02-2013, 08:06 PM   #4
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
Forum Activity 14%
If someone else isn't able to get you an answer, a picture would help me help you a bit more.
BTW I just remembered, I have two junk headlights sitting in my closet. If you want an OEM replacement, I can send the you a replacement part from them for the cost of shipping.
Old 03-03-2013, 02:59 PM   #5
X-Rated
X-Rated's Avatar
Fan#: 55237
Forum Activity 3%
Ok, here are the pics you needed to see.....the 2nd pic shows the broken plug, the 3rd pic shows the end of the harness but to get this harness out I need to separate the housings.
X-Rated is offline
Old 03-03-2013, 11:29 PM   #6
fhh02a
HATCH NATION
fhh02a's Avatar
Fan#: 57548
What I Drive: 2004, Pitch Black Zx3
Points 16,184, Level 81
Points: 16,184, Level: 81 Points: 16,184, Level: 81 Points: 16,184, Level: 81
Level Up 67% Completed
FF Reputation: 13 fhh02a Great Standing Member
Buy-Sell-Trade Rating: (10)
the harness that connects to the bulb is very easy to change. Just cut the old one off and wire a new one in.
I cant tell if the plug that is attached to the actual headlight (where the car harness attaches) is missed up or not..
if it is you will need to bake the headlights apart and try to replace it
if you need help with anything let me know
fhh02a is offline
Old 03-03-2013, 11:33 PM   #7
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,434, Level 65
Points: 9,434, Level: 65 Points: 9,434, Level: 65 Points: 9,434, Level: 65
Level Up 28% Completed
Forum Activity 7%
you can buy that plug from Ford. don't know the part number off the top of my head.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is online now
Old 03-04-2013, 02:44 AM   #8
amc49
Fan#: 96610
Points 3,359, Level 36
Points: 3,359, Level: 36 Points: 3,359, Level: 36 Points: 3,359, Level: 36
Level Up 6% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
The headlight assembly is heat glued together and not intended to ever be taken apart. Not that someone couldn't do it but getting it back together and still sealed to not get condensation will be problematic......................
amc49 is offline
Old 03-04-2013, 02:52 AM   #9
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 36,605, Level 100
Points: 36,605, Level: 100 Points: 36,605, Level: 100 Points: 36,605, Level: 100
Forum Activity 3%
That looks like the culprit of useing 90/100w bulbs. You really shouldn't go higher than 55watt in stock housings with out upgraded wiring anyways.
There are several thread where people have put the housings in the oven to soften the glue in order to open them up for either a reto-fit, repair, or painting.
Ill try to find you a couple real quick to help yea out.
Sent from 34.0764 N, 118.4296 W
TheGlassMaker is offline
Old 03-04-2013, 03:15 AM   #10
TheGlassMaker
REVOLT.BUILD.RISE
Fan#: 69510
Forum Activity 3%
Here's a retrofit, it mentions the oven instructions about half way down the first post.
http://www.focusfanatics.com/forum/showthread.php?t=164851
Here is another with oven instructions.
http://www.focusfanatics.com/forum/showthread.php?t=163593
Here's one for Resealing.
http://www.focusfanatics.com/howtos/resealingtaillight/
