Screwed - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-02-2013, 02:27 PM   #1
anarchy0392
Fan#: 102873
What I Drive: 2002, Silver, SE
Points 1,630, Level 23
Points: 1,630, Level: 23 Points: 1,630, Level: 23 Points: 1,630, Level: 23
Level Up 30% Completed
FF Reputation: 2 anarchy0392 Good Standing Member
Buy-Sell-Trade Rating: (9)
Screwed
Well I'm screwed the bolt for then engine mount broke a few days ago.Its the head that broke off and the threaded part is in the body. So I took it to a shop to have them get it out. They welded a nut to it 5 times drilled it an used a air hammer. Well to say the least no one can get it out. Its the bolt that holds the mount to the uni-body. So it looks like I'm gunna have to get a new car now cause when ever i give it any gas the whole engine jerks violently, shakes the whole car and my mpg is crap along with acceleration.
Anyone have any ideas before I end up getting rid of the car?
anarchy0392 is offline
Old 03-02-2013, 02:54 PM   #2
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
Can you post a picture of the broken off bolt? Which mount? And in my opinion the shop didn't know what they were doing.
Welding a nut to a broken off bolt is an old trick but it generally only works on bolts that the heads were rounded off by incompetents using the wrong tools to get the bolt out.
If the bolt is jammed far enough in there that the head snapped off when a high amount of torque was applied, then a welded on nut will just snap off when the same torque is applied.
If the bolt has really become part of the unibody then a torch can be used to cut it out, then weld in a replacement sheet metal patch, drill a hole in the right place, then weld on a nut. This is trivial for a good body shop to do.
tmittelstaedt is offline
Old 03-02-2013, 04:37 PM   #3
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,079, Level 67
Points: 10,079, Level: 67 Points: 10,079, Level: 67 Points: 10,079, Level: 67
Level Up 8% Completed
Forum Activity 42%
Activity: 42% Activity: 42% Activity: 42%
FF Reputation: 5 pasta Good Standing Member
Buy-Sell-Trade Rating: (41)
i agree ^^^^^
pasta is offline
Old 03-02-2013, 05:16 PM   #4
anarchy0392
Fan#: 102873
Old 03-02-2013, 05:51 PM   #5
jinstall
Deutsche Arsche
jinstall's Avatar
Fan#: 9730
What I Drive: 01 ZX3RACECAR/04 ST170/13 FST2
Points 2,806, Level 32
Points: 2,806, Level: 32 Points: 2,806, Level: 32 Points: 2,806, Level: 32
Level Up 38% Completed
Forum Activity 11%
FF Reputation: 4 jinstall Good Standing Member
drill and tap.
2001 Focus ZX3 Race Car in Germany-Ours SHIPPING
2010 Renault Clio 1.2 16V in Germany-Hers FOR SALE
2004 SVTF EAP/ST170-Mine
2013 Focus ST2 TS NAV SUNROOF-Hers
jinstall is offline
Old 03-02-2013, 05:55 PM   #6
anarchy0392
Fan#: 102873
The shop tried to drill and tap. Apparently it broke a few of their drill bits.
Old 03-02-2013, 06:33 PM   #7
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,358, Level 20
Points: 1,358, Level: 20 Points: 1,358, Level: 20 Points: 1,358, Level: 20
Level Up 58% Completed
FF Reputation: 1 coldbear Good Standing Member
My Procedure.
Remove the mount so you can work on the bolt removal. After MM removal, find a stainless steel washer that will go over the bolt post, or whats left of the it. Find a stainless steel nut that will fit tightly "over" the bolt post. Now here's where the magic comes in. Find a new dry 3/16'' stainless(316) welding rod. Take the rod and hold it at 12:00 o'clock and push the rod gently down and weld for a couple seconds. Be ready with a wrench that will fit over the stainless bolt. Have it READY! Slowly turn the bolt 15 degrees and then reverse. Keep going back and forth graduley increasing the turns. Works 95% for me, but don't feel defeated if the stainless nut pops off. Just set everything up agin and try again. When you weld the nut, you are putting a great deal of heat into the broken stud. That is why you need to be ready with the wrench. And be sure to use a stainless welding rod,and nothing else. Made my way through college doing these repairs. You can go to any reputable welding shop and tell them of your delimia. They will sell you a couple of rods pretty reasonable. Clean around the broken stud and do your homework. IT WILL BACK OUT! Good Luck and laugh at the broken stud when it comes out.
coldbear is offline
Old 03-02-2013, 06:46 PM   #8
coldbear
Fan#: 78292
Addendum/ HEAT RANGE
That will be 75 amps on the AC/DC welder and start the weld at the center of the broken stud, gradually weld in circles untill you fill the top of the nut. And please don't use a wire gun on this job, as they aren't as successful as AC/DC generators. jmo.
coldbear is offline
Old 03-02-2013, 06:51 PM   #9
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,551, Level 48
Points: 5,551, Level: 48 Points: 5,551, Level: 48 Points: 5,551, Level: 48
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 8%
FF Reputation: 35 thenorm Great Standing Member
find another shop with better drill bits.
I had an engine mount bolt break (the one into the timing cover). it wouldnt back out until i had drilled the whole length of it out. just take your time drilling, and use lots of fluid to lube and cool (cutting oil, WD40, water even)
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 03-02-2013, 07:38 PM   #10
don627
Fan#: 56863
What I Drive: 2014 Focus Hatchback
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 2%
FF Reputation: 1 don627 Good Standing Member
That job right there shouldn't be that bad I mean drill that thing out of there and get a new stud in there.
don627 is offline
