¡¡¡NEW ITEM - Massive Cam Timing Tool Set - MZR 2.3 DISI Turbo!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Exclusive Vendor Discussions > Massive Speed
Massive Speed Discuss about forced induction upgrades and performance tuning for your Ford Focus.
Sponsored By: Massive Speed
Old 03-01-2013, 12:58 PM   #1
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Points 15,918, Level 81
Points: 15,918, Level: 81 Points: 15,918, Level: 81 Points: 15,918, Level: 81
Level Up 14% Completed
Buy-Sell-Trade Rating: (19)
Massive has been producing cam timing tools for the regular MZR 2.0/2.3 engine since 2008, with incredible success. However, the turbo 2.3 guys (Mazdaspeed 3, 6 and CX-7) were left out in the cold. Massive has changed all that with our new 2.3 DISI specific tool kit. Available in a 2 piece set for turbo only, or a master set for all MZR and Zetec motors. Far less expensive than others while superior in quality.
Here's our full description from the site:
A true cut above in quality and accuracy! You’ll need these tools to positively hold your crank and cams in place whilst timing your motor. Several manufacturers have discontinued their tools. None offered the level of precision found here.
Gages are much more than a simple piece of bar stock like others have produced – they are much thicker (and hence stronger) bars that feature 2 machined reliefs offering a TIGHT +/- .001” fit. A much more accurate means of locking your cams, resulting in less need for cam degreeing post install.
Pins are super tolerance monolithic machined 6061 aluminum for an exact fit. Pins are anodized in high vis Massive Purple for corrosion resistance and this bright coloring will help to remind user of removal(seen folks leave it in – NOT good!). Should pin be left in, aluminum construction will give way without harming vital engine internals. Handle area has built in hex for tool usage. Alpha stamping so you’ll know the difference between the 2 pin styles.
4 piece kit covers all Zetec and Duratec motors, Including DISI turbo 2.3 Superior Alternative to:
*OTC 303-465 (T94P-6256-CH) Camshaft Alignment Plate
*OTC 303-574 (T97-P6000-A) Timing Peg, Crankshaft TDC Zetec
*OTC 303-507 Timing Peg, Crankshaft TDC Duratec
*AST FM 2300 Peg Bar Ford / Mazda Duratec / MZR
*OTC 303-1061 Cam Alignment Plate
2 piece kit includes superior alternate to:
Great for service on the faulty / problematic VVT gear / ticking and loose chain issue on 07-10 MS3 and CX-7. Mazda Bulletin / TSB / Recall No:01-012-12
Quality made IN HOUSE right here in the USA !!!
2 Piece kit is just $89.97, 4 piece Master set, just $109.18.
Still ships for just $5 to the lower 48 states!!!
Find 'em Here
K Dog is offline
Old 06-03-2013, 08:27 AM   #2
redsvt313
redsvt313's Avatar
Fan#: 111179
What I Drive: 2002 Infra Red svt focus
Points 340, Level 6
Points: 340, Level: 6 Points: 340, Level: 6 Points: 340, Level: 6
Level Up 80% Completed
FF Reputation: 1 redsvt313 Good Standing Member
Does this also cover the svt model?
sent from my rooted thunderblaster!
redsvt313 is offline
Old 06-03-2013, 09:14 AM   #3
02_z_x_3
Fan#: 53977
What I Drive: 02 zx3
Points 4,316, Level 41
Points: 4,316, Level: 41 Points: 4,316, Level: 41 Points: 4,316, Level: 41
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
Forum Activity 3%
FF Reputation: 9 02_z_x_3 Good Standing Member
Buy-Sell-Trade Rating: (13)
The bottom master set will work on the svt
02_z_x_3 is offline
Old 06-03-2013, 10:16 AM   #4
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
The master set would cover the SVT, or you could buy the kit without the DISI stuff for $35 here:
http://massivespeedsystem.com/_massi...y/g-59726.aspx
K Dog is offline
