Go Green!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 03-01-2013, 09:29 AM   #1
sk8salomon
sk8salomon's Avatar
Fan#: 86112
What I Drive: '02 SE Wagon
FF Reputation: 1 sk8salomon Good Standing Member
Go Green!!!
For anti-freeze...just a quick story of how i about made a huge mistake. I walked out to the driveway this morning to find a huge puddle under my car. i got an old white t-shirt and got a sample, red! so i jacked up the car and slid underneath to look at the trans pan, sure enough, red liquid dripping down from the edge of the pan. so i went and got a drain pan, some RTV, 8mm socket and started to remove the pan bolts. i got a drop of liquid on my face and it didn't smell like oil, smelled more like stale water...so, after some investigation i found i really had a coolant leak. it was dripping down the block and on to the trans housing, then dribbling down the edge of the pan. the plastic housing for t-stat has three torx bolts, all were super loose, you could see daylight between the flange. i just flushed the entire system, on my way to the store for some green (non-enviro friendly) coolant.
sk8salomon is offline
Old 03-01-2013, 09:35 AM   #2
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
What I Drive: 03 CD Silver ZX5
Points 11,527, Level 70
Points: 11,527, Level: 70 Points: 11,527, Level: 70 Points: 11,527, Level: 70
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 59 katiekay Excellent Standing Member
Buy-Sell-Trade Rating: (48)
Your t-sat housing might be shot. Almost sounds like the o-ring has deteriorated causing the housing to become loose. I would keep an eye out for a coolant leak in the same spot. Yeah, I also switched to green coolant years ago as well.
Hatch Nation #8
September 2012 Ride of the Month
katiekay is offline
Old 03-01-2013, 09:37 AM   #3
sk8salomon
sk8salomon's Avatar
Fan#: 86112
ah, thanks. so maybe just tightening up the bolts won't fix the prob. maybe i should remove the housing completely and take a look? i'm sure a new gasket will be worth much more than draining the system again later.
Old 03-01-2013, 09:42 AM   #4
RonMaiden
RonMaiden's Avatar
Fan#: 99230
What I Drive: 2012 Red Candy Metallic Hatch SE
Points 4,181, Level 41
Points: 4,181, Level: 41 Points: 4,181, Level: 41 Points: 4,181, Level: 41
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 6 RonMaiden Good Standing Member
Just the feel of the fluid should've tipped you off it was anti-freeze instead of tranny fluid and the backup check can be to touch a sample on your tongue which coolant will immediatly have a sweet taste. Kinda gross but it works.
'12 Focus Red Candy SE Sport 5 spd
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is offline
Old 03-01-2013, 09:43 AM   #5
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Forum Activity 2%
The o-ring is molded into the plastic housing, if it's shot you will need a new housing. This might give you a better idea:
http://www.focushacks.com/mod/Replac...mostat_housing
Hatch Nation #8
katiekay is offline
Old 03-01-2013, 09:56 AM   #6
sk8salomon
sk8salomon's Avatar
Fan#: 86112
thanks pyro, just went out and took a look. i think i got lucky on this one. what was leaking was the t-stat retainer connection, not the damaged flange in the link you showed. the daylight gap i had was in this part, when i took apart there is no gasket there, just plastic to plastic connection. i'm just going to tighten it back up and see how it goes. good to know tho for next time. thanks again!
Old 03-01-2013, 11:49 AM   #7
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,384, Level 65
Points: 9,384, Level: 65 Points: 9,384, Level: 65 Points: 9,384, Level: 65
Level Up 12% Completed
Forum Activity 6%
Ford recommends Motorcraft Gold for their vehicles except for on newer vehicles I've noticed they have been switching to red. You can also you green usually.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 03-01-2013, 12:51 PM   #8
mjd4277
King of all blacks!!
mjd4277's Avatar
Fan#: 64900
What I Drive: 2013 Fusion SE,2012 Fiat 500 Abarth
FF Reputation: 7 mjd4277 Good Standing Member
Umm,put this down on the "How to get a Darwin Award" list.
1975 MG MGB Mk IV "Downshift"
2012 Fiat 500 Abarth "Scorpion"
2013 Fusion SE "Epyon"
2003 Nissan Frontier SVE "Trailbreaker"
Team Duratec #241-Bailout Money?!?! WTF is that??
mjd4277 is offline
Old 03-01-2013, 01:02 PM   #9
RonMaiden
RonMaiden's Avatar
Fan#: 99230
No,it's just a little old school. Sometimes you need a quick diagnosis and alot o people know the "taste" and feel of vital fluids which on the fly is a helpful thing and I've seen it alot at the dragstrip. I didn't say I was ingesting it. If the OP did the same (or the touch test) he would've saved himself the trouble and had the diagnosis in a few seconds.
Old 03-01-2013, 01:36 PM   #10
mjd4277
mjd4277's Avatar
Fan#: 64900
Old school is being able to "smell" the difference between antifreeze/coolant and transmission fluid,let alone being able to tell the difference by looking at it. Whether you ingest the stuff or not it still can travel thru your blood stream-not a good thing.
mjd4277 is offline
