Focus Won't Start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-01-2013, 03:11 AM   #1
Red01Focus
Fan#: 40437
What I Drive: 2001 Infa Red SE
Points 11,068, Level 69
Points: 11,068, Level: 69 Points: 11,068, Level: 69 Points: 11,068, Level: 69
Level Up 55% Completed
FF Reputation: 10 Red01Focus Great Standing Member
Buy-Sell-Trade Rating: (56)
Focus Won't Start
I'm sure people are tired of reading these but trying to use my cell phone to search isn't working
I have a 2001 Automatic Zetec Sedan (165,xxx)that has been sitting for almost 3 years(i know,i know) :( i tried getting it road worthy during that time but had issues financially, Anyways to the problem. The battery was recently replace as was the starter but it won't crank over. lights come on and chimes sound but as soon as i turn the key the lights kick off and the car starts clicking. is it possible that the alternator is bad? any help is appreciated
SEDAN REVOLUTION #13
Red01Focus is offline
Old 03-01-2013, 03:29 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,370, Level 100
Points: 138,370, Level: 100 Points: 138,370, Level: 100 Points: 138,370, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (11)
Check the power wires and ground wires. I'm assuming the battery is new or tested to be good?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 03-01-2013, 02:02 PM   #3
Red01Focus
Fan#: 40437
battery is brand new just bought it the other night
Old 03-01-2013, 02:36 PM   #4
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 324, Level 6
Points: 324, Level: 6 Points: 324, Level: 6 Points: 324, Level: 6
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 10%
FF Reputation: 8 Milton Good Standing Member
The alternator will not figure into it until after the car starts up.
1) make sure your new battery is fully charged.
2) If that does not work the check positive and ground connections
-- remove neg connection at battery. Clean the connector and reattach to battery. Trace that negative cable(s) to the other ends. Disconnect those ends, clean the connectors and reattach.
-- do the same with the positive battery cable.
Inspect the cables to see if they have started to corrode inside the insulation. If so replace the corroded cables
Three years is a long time. I let a 65 VW bug set for two years, the points had turned to green powder. I replaced the points, put in a gallon of gas, jumped it and it started right up. Nothing like a simple machine.
Milton is offline
Old 03-01-2013, 02:48 PM   #5
Red01Focus
Fan#: 40437
i replaced the battery cables last year along with the starter(brand new)
Old 03-01-2013, 02:52 PM   #6
Milton
Fan#: 89715
Points 324, Level 6
Forum Activity 10%
Look a year ago is a long time. Your symptoms are of a bad connection. Turn a wrench or sit on your a**. Your choice.
Milton is offline
Old 03-01-2013, 03:00 PM   #7
miazda
miazda's Avatar
Fan#: 103761
What I Drive: 03 SVT
FF Reputation: 1 miazda Good Standing Member
Neutral safety switch? Will it shift from park when you apply the brake?
Edit for reading: Yep you need more juice, newer battery or not. Find some jumper cables, also just because a battery is "new" doesn't mean it's good. I've had more than one which were not good. Quality control isn't what it used to be in the battery department these days it seems.
miazda is offline
Old 03-01-2013, 03:14 PM   #8
Milton
Fan#: 89715
Points 324, Level 6
Forum Activity 10%
His stated symptom is:
Losing the lights and the starter clicking indicates not enough power, but he just replaced the battery. So what could be the problem? Answer: the power distribution system (the electrical cables and connections) have an issue. High resistance somewhere is preventing the transmission of the high currents required to start an engine.
Milton is offline
Old 03-01-2013, 03:56 PM   #9
FocusRus
FocusRus's Avatar
Fan#: 109798
What I Drive: 2004 Silver Sedan SE
Points 356, Level 7
Points: 356, Level: 7 Points: 356, Level: 7 Points: 356, Level: 7
Level Up 12% Completed
FF Reputation: 3 FocusRus Good Standing Member
Buy-Sell-Trade Rating: (9)
Danny, you know full well that your problem is in the wiring, i.e...cables. Clean the corrosion off of the pos/neg cables and crank her up.....I guarntee that you're smokin a cable or two somewhere.
FocusRus is offline
Old 03-01-2013, 04:04 PM   #10
Red01Focus
Fan#: 40437
There is no corrosion on the pos/neg cables,i'll see about getting it jumped and will let everyone know how that goes, will also get the battery looked at as well
