Wiring Radar to Ignition - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > MK2 Interior Mods & Upgrades
MK2 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2008-2011 Focus.
Old 02-28-2013, 04:59 PM   #1
Snyper
Snyper's Avatar
Fan#: 96688
What I Drive: 2009 Black SE
Points 1,478, Level 21
Points: 1,478, Level: 21 Points: 1,478, Level: 21 Points: 1,478, Level: 21
Level Up 78% Completed
Forum Activity 3%
FF Reputation: 2 Snyper Good Standing Member
I've googled and searched threads, haven't found much of anything so here I am.
I want my radar to be wired into the car so that when I turn on the ignition, it will go on and when I turn the car off, the radar goes off as well. My initial plan was to use an add-a-fuse and I tried that today and it didn't work at all. I tried a bunch of fuses that are open and I tried the radio fuse as well. Any help would be appreciated.
Snyper is offline
Old 02-28-2013, 05:28 PM   #2
nickstewartroc
Fan#: 93665
What I Drive: 2011 Blue Focus SE
Points 301, Level 6
Points: 301, Level: 6 Points: 301, Level: 6 Points: 301, Level: 6
Level Up 2% Completed
FF Reputation: 1 nickstewartroc Good Standing Member
Read below for what I did for my headunit, same thing, just for your radar ;)
mrfatride
02-20-2012, 08:31 PM
you have to go to the ignition harness. take the black plastic shroud off the steering wheel (yes it will be a pain in the ass) on the left side of the steering wheel (if you are looking at it) there will be a black harness with 5 or so wires tied into it. there should be a purple wire with a green stripe there. to make sure you have the right harness unplug it and then try to start the car. if the car does not turn over you got the right harness
nickstewartroc is offline
Old 02-28-2013, 06:57 PM   #3
Snyper
Snyper's Avatar
Fan#: 96688
Forum Activity 3%
So any suggestions on how to remove that plastic shroud (and more so, what the hell is it?)
And I'll assume you just tapped into the purple/green wire?
Snyper is offline
Old 02-28-2013, 06:58 PM   #4
nickstewartroc
Fan#: 93665
Points 301, Level 6
The one under the steering wheel, the one that has the little door for the OBD port, just pulls off, and yeah, just spliced into the purple/green wire
Old 02-28-2013, 07:48 PM   #5
Snyper
Snyper's Avatar
Fan#: 96688
Forum Activity 3%
Oh, the little piece that when off reveals the fuse box and all kinds of wiring.
And my radar wire has a white and a red wire when the covering is pulled back; do I splice both those into the purple/green wire?
Sorry for the what-may-seem-to-be dumb questions.
Snyper is offline
Old 02-28-2013, 08:21 PM   #6
nickstewartroc
Fan#: 93665
Points 301, Level 6
Not dumb at all! As for what wires, can you post a pic? Is it just white and red, or is there a black wire or anything?
Old 02-28-2013, 08:50 PM   #7
Snyper
Snyper's Avatar
Fan#: 96688
Forum Activity 3%
Not an actual photo, since I didn't feel like undoing what I had done with the wire, but it's just like this, except instead of being a white, red (close together so rather hard to even notice there is a white), and black, it's just a white and red.
Snyper is offline
Old 03-01-2013, 09:25 AM   #8
nickstewartroc
Fan#: 93665
Points 301, Level 6
Whats your model radar? Just want to look up the manual to make sure I don't tell you the wrong thing and break yours!
Old 03-02-2013, 08:25 AM   #9
Snyper
Snyper's Avatar
Fan#: 96688
Forum Activity 3%
cobra esd 7400
Snyper is offline
Old 03-02-2013, 09:24 AM   #10
nickstewartroc
Fan#: 93665
Points 301, Level 6
Basically you cut open the cord that goes from the radar detector to a cigarette lighter socket, correct? If so, you will need to connect one wire to the purple with green, and the other wire to ground, basically any metal on your car
