DURATEC Performance (2003-2011) The place to chat about any Duratec 23, 23E, and 20 engine performance, tuning and exhaust related upgrades.
#21 | ||||
hey felix u should do a right up on how u did ur cams i want to do them im very mechanically inclined but im kinda nervous to try this..
| Sponsored Links | |||
Advertisement | |||
#22 | ||||
It idle's like the stock ones.
The idle is very similar to stock. And no you don't have to buy gears to install the cams.
Interduce Mr. Torsen to the mix |
#23 | ||||
there is a stage 2 right did you notice anything in third gear?.....that's a huge "fall on your face"for our cars.
#24 | ||||
Whats that mean? Theres no lag or hesatation or fall on your face w/ my car. I can get over 90mph in 3rd & it pulls pretty good.
#25 | ||||
Felix- I agree, you should post a write up for the install. My cams should be in any day now and I am eager to get these badboys in!
#26 | ||||
Cam install= The way I did mine. I racked the car, pulled the rf wheel, serpentine belt, part of the inter fender. pull the coil pks, plugs & cam cover. Get the #1 at tdc. You will find the #1 int & exh lobes pointing at each other. Underneath= in front of the axle theres a plug in the cam cover, pull that & insert a pin that screws in & butts against the crank. Up top on the back side of the cams is a slot that is offset, put your cam timing bar into the slots= resting on the head.There is a plug up top directly behind the pass motor mount, pull that & insert a 3/16 drill bit into the hole. This will keep the tensioner from springing back. This is where I messed up= forgot to install the 3/16 drill to hold the tensioner & had to pull the cam cover. Add 'bout 2 more hrs. back up top, I used a tie wrap to tie the exh cam gear to the chain & then put a open end wrench on the cam flats of the exh cam & another wrench on the cam sprocket bolt, holding both, loosen the cam bolt & then loosen the intake. Back at the exh, pull the bolt out & let the chain & sprocket "tie wrapped" hang. Mark the cam caps so you know which direction they go. Loosen the cam caps & loosen the ones pointing down last= more spring pressure. Set the caps & bolts so you know which way the go back in. Pull the exh cam out & then do the same for the intake leaving the cam gear on, when you remove the int. cam. Undue the gear off the int & install on new int cam using lock tight on bolt, finger tighten, then using cam lube to lube up the lobes, install the intake cam & snug the bolts down.Great time look compare the cam lobes w/ the oem wimpy ones. Lube up the exh. lobes & install the exh. cam & snug down the bolts. Put the cam timing bar on the back of the cams & the int & exh lobes on #1 should be pointing towards each other. Install the chain around the int sprocket & then install the exh. sprocket & bolt to the exh. cam, using locktight. Torque down the cam caps to spec in order. Then torque the cam sprocket bolts using the open wrench on the cam flats & a wrench on the cam bolts tighten. Undue the 3/16 drill & install the plug & do the same below. Take a wrench & turn the motor over & then check the lash. It should be with in the cam spec's. Raise the car pull the oil filter & plug let drain & install your inter fender liner & rf wheel/tire, then pour your new oil over the cams. Install the cam cover & plugs & coil pkgs. Good time to install new plugs. Fire it up & let run at 1500 rpm for a little bit. When I installed my cams, I forgot 'bout the cam tensioner & wham, I had to pull the cover off & that added about 2 more hrs. Using Mobil 1 5/20 since new the inside of the motor looked really, really clean. Looking at the cam spec's, they look wimpy compared to what I'm use to looking at. I like the 224-0012 spec's better, but I kept telling myself, This is a DD. They have a stock idle & it pulls really good for what it is. I'm happy w/ them. I'm punching this up from memory over a yr ago. I hope this helps you guy's out. Felixthecat
#28 | ||||
I never have that "fall on face" in third either. Weird. Why do some experienced Focus guys say stage 1 cams are barely noticable and not worth it? Where is the change? Power band shifted higher? Lose your low end torque? Would going stage 2 be bad for a DD? Thanks FelixTheCat and others who have actually done cams.
05 ZX3: F2 CAI, Trubendz 2.5 inch exhaust, Tom's Tune/SCT, Eibach Sportlines, TZ10 rims 205/40/17, SVT dampeners 15.90 Quarter Mile Best official reaction time: .0004 |
#29 | ||||
#30 | ||||
So the people who said it was barely a difference are lying? I want to add to my top end without losing anything low down.
05 ZX3: F2 CAI, Trubendz 2.5 inch exhaust, Tom's Tune/SCT, Eibach Sportlines, TZ10 rims 205/40/17, SVT dampeners 15.90 Quarter Mile Best official reaction time: .0004 Last edited by streetfocus; 03-08-2013 at 01:54 PM. Reason: Typo |
| Thread Tools | |
| Display Modes | |
