Rear lower control arm bolts stuck - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-27-2013, 09:55 AM   #1
firstv8focus
Fan#: 110498
What I Drive: 2000 white focus zts
FF Reputation: 1 firstv8focus Good Standing Member
I have a 2000 ford focus zts with a bad bushing in the rear lower control arm. I have already replaced the passenger side control arm and now im working on replacing the drivers side. my problem is after i got the car on jack stands and everything. i put my floor jack under the spring and raised the control arm. i sprayed the nuckle bolt with pb blaster and waited then sprayed it again and put a 17mm deep impact socket on it with a 2 foot breacker bar and it would only turn a half of a turn and then stop. i know that the bolts are rusted to the bushings for a fact because i had to cut the passenger control arm out with a grinder. i plan on doing that to the drivers side because i already have the new control arm but i have no idea where to get the bolts for it at. i called ford to see if i could get the adjuster bolt from them and the guy said that he couldnt get it so i think that im screwed. any ideas or help with getting the bolts for this would be great.
firstv8focus is offline
Old 02-27-2013, 10:14 AM   #2
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,547, Level 22
Points: 1,547, Level: 22 Points: 1,547, Level: 22 Points: 1,547, Level: 22
Level Up 47% Completed
FF Reputation: 7 gondorian Good Standing Member
You can get the bolts from ford. It is part number 6S4Z-5K978-AA. It should cost 10-15 for each one.
gondorian is offline
Old 02-27-2013, 10:36 AM   #3
firstv8focus
Fan#: 110498
Ok thanks. I will call ford back and give it a shot.
Old 02-27-2013, 01:13 PM   #4
gondorian
gondorian's Avatar
Fan#: 105695
If your local dealer doesn't seem to be able to get them try searching online for the part number and also call Tousley Ford and Village Ford. They have good prices for parts shipped.
Old 02-27-2013, 03:05 PM   #5
firstv8focus
Fan#: 110498
Well I called my local dealer back and gave him that part number and the guy said that it was the bolt im looking for but it went to a 05 and up. I've looked online for hours and came up with nothing as so.
Old 02-27-2013, 03:12 PM   #6
splicedwdm
Fan#: 92283
What I Drive: '12, candy red, Focus Ti hatch
Points 163, Level 3
Points: 163, Level: 3 Points: 163, Level: 3 Points: 163, Level: 3
Level Up 26% Completed
FF Reputation: 2 splicedwdm Good Standing Member
Just a thought, would it be worth checking a wreckers? Perhaps someone had theirs replaced not long before scrapping it.
Is the '05 bolt compatible? Same dimensions/thread?
splicedwdm is offline
Old 02-27-2013, 03:19 PM   #7
firstv8focus
Fan#: 110498
That I'm not sure of yet. After the guy said that it was for a 05 he basically said that it wouldn't work. I might just have to be careful and grind the metal sleeve off of the bolt like I did on the passenger side. I didn't want to go through that again though cause its a real pain
Old 02-27-2013, 03:34 PM   #8
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 12 Outback
Points 9,450, Level 65
Points: 9,450, Level: 65 Points: 9,450, Level: 65 Points: 9,450, Level: 65
Level Up 34% Completed
Forum Activity 11%
same rear suspension on an 05-11 as an 00-04 just an fyi
2012 Subaru Outback 6 speed manual - current DD
I always moderate naked!
bringler26 is offline
Old 02-27-2013, 03:42 PM   #9
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,902, Level 59
Points: 7,902, Level: 59 Points: 7,902, Level: 59 Points: 7,902, Level: 59
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
iirc, the rears suspension/subframe are the same from 00-07(00-'11?) Only thing excluded would be the wagons.
rambleon84 is offline
Old 02-27-2013, 04:05 PM   #10
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,191, Level 56
Points: 7,191, Level: 56 Points: 7,191, Level: 56 Points: 7,191, Level: 56
Level Up 21% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
yeah the rear subframe is the same from 00-11. Except for the rear trailing arms.
FSWerks stg2 w/ water/meth; Cossie intake.
PSUrivie is offline
