All electrical starts to fade out at higher RPMs. What could it be? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-09-2013, 12:39 AM   #11
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
FF Reputation: 49 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
Zombie bump,
I ended up solving my issue just a bit ago, or so it seems for now.
Ended up being a bad Spark Plug Wire. It was fitting to the ignition coil a little loose, other 3 felt good. Dug around and found an old aftermarket wire and replace the bad one.
Lights don't dim anymore WOT/high RPM.
My theory is that the added amperage the ignition was sucking up caused something to go awry with the electronics, interference and such.
iminhell is online now
Old 06-09-2013, 05:55 AM   #12
Kodyston
Kodyston's Avatar
Fan#: 112498
What I Drive: 2003 Sangria Red ZX3; Zetec; MTX-75
Points 625, Level 12
Points: 625, Level: 12 Points: 625, Level: 12 Points: 625, Level: 12
Level Up 50% Completed
FF Reputation: 3 Kodyston Good Standing Member
Originally Posted by iminhell View Post
Zombie bump,
How interesting... mine does the same thing... But, I just recently put new plugs and wires and my headlights still dim along with my gauge cluster dimming and flashing in and out at idle. I did the odometer dealer test thing and mine drops as low as 10 volts (for a sec or two) when a fan kicks on and when I have the heater or ac on. and it's only charging no higher than 13.8 or .9 no matter what...
Kodyston is offline
Old 06-12-2013, 05:47 PM   #13
FocusRus
FocusRus's Avatar
Fan#: 109798
What I Drive: 2004 Silver Sedan SE
Points 356, Level 7
Points: 356, Level: 7 Points: 356, Level: 7 Points: 356, Level: 7
Level Up 12% Completed
Forum Activity 8%
FF Reputation: 3 FocusRus Good Standing Member
Buy-Sell-Trade Rating: (9)
Say Kodyston, your problem may lay in the battery......sounds like low cca's........remember, the alt's job is to replenish the battery's reserves......not run a 90-100% duty cycle. That damn blower motor pulls alot of amps from the battery. And if you have any poor grounds......things tend to "heat" up a bit in the supply wiring. Fft......
I tell you what bro, I killed a new altenator in 3 weeks cause my sound system and ac kept my battery low and so the alt ran a high duty cycle tryin to keep up. Now I'm somewhat iffy on running the system at all....in fact I just took out the sub box this morning. Shoot, I did a Super big 3 upgrade and upsized every ground wire I could find and I'm still jittery....lol
And like you I see 13.5-13.7 volts constantly when running the ac....of coarse its only 95 to 200 degrees here in z big easy....lol
Sent from my SPH-D710 using FF Mobile
SR#269 'I know where the 'zetec' kicks in....'
FocusRus is offline
Old 06-12-2013, 05:51 PM   #14
FocusRus
FocusRus's Avatar
Fan#: 109798
Points 356, Level 7
Forum Activity 8%
I know you're out there lurkin.....amc49.....I can feel your presence....the force is strong with you.....lol
FocusRus is offline
Old 06-12-2013, 10:30 PM   #15
Kodyston
Kodyston's Avatar
Fan#: 112498
Well last Sunday I was tired of seeing 13.6V and 13.7V so I took my terminals off my battery and cleaned the connectors and the terminals themselves for like an hour (no joke) with a wire brush. It kinda felt like the connectors and terminals had an oily substance on them, so I got all of that off and wired it back up. Then I took my alternator pigtail off and took a tiny flat headed screwdriver and shoved the wires in on the back of pigtail. Plus, within the 2 hours I'm messing around with it, I have a battery charger on the battery slowly charging it up. Cranked the car up while doing the dealer test and it was reading 14.8V and even spiking up to 15 volts. But today is Thursday (4 days later) and I'm only charging at 14.1 or 14.2 volts now. Turn on the A/C, when I get hot or even the heat at night to clear the fog off the windshield, any higher than 2 or 3 notches on the dash and the dealer test shows anywhere from 10.2 volts to 12.whatever. I did have a DTC low battery voltage (can't remember the number right off hand) but after I cleaned the terminals I'm getting a DTC NONE. So I guess It's decent for now and where I had the battery unhooked it cleared the code and it hasn't came back yet...
My guess is when my alternator went out on my last August 2012 and I drove on battery for 3 days before I realized my alternator was "fried", I "fried" some battery cells along with it. When I get some extra cash I'll have to go get a new battery to see if that solves anything. I'll keep everyone updated whenever I do. lol Money is hard to come by now-a-days. haha
Kodyston is offline
Old 06-12-2013, 10:31 PM   #16
Kodyston
Kodyston's Avatar
Fan#: 112498
Hahaha! I thought I was the only one that could feel his presence. lmao
Kodyston is offline
Old 06-13-2013, 07:33 PM   #17
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,737, Level 73
Points: 12,737, Level: 73 Points: 12,737, Level: 73 Points: 12,737, Level: 73
Level Up 72% Completed
Forum Activity 99%
Kodyston - that 14.1-14.2 sounds good, is the idle bumping up when you turn up the fan?
It's supposed to increase via the IAC when the extra load is put on the alternator.
That pigtail you played with could still have an issue if it doesn't. AFAIK that's the source the computer uses to bump up the idle when needed due to increased electrical load.
Just another thought, getting a free battery load test would still be the first step just to make sure the "basics" are OK.
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 06-13-2013, 11:38 PM   #18
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 19%
First of all, not possible to drive a car on a bad alternator for days.
Second, there are only 6 cells in a 12v battery; each measuring 2.1 volts. So if 1 cell dies you loose 2.1v at rest; so on a Volt Meter you'll see ~10v.
When a battery drops voltage under load it means the Electrolyte is not releasing enough stored energy. It's basically wore out. The other choice is the lead plates are deteriorated and the internal resistance has risen. Either condition requires replacement of the battery.
Now, can a weak battery cause lights and such to dim at idle?
Yes.
This is because the alternator is not working to full potential at idle. So when you stress it the battery does the job of adding the demanded Amperage to hold a stable Voltage. When the battery is weak it's unable to sustain that Voltage and things don't work correctly.
So yes, test the battery. Odds are it's bad.
Also, there should be a 'greasy' coating on battery terminals and clamps. Either dielectric grease or wheel bearing grease works well.
Old 06-14-2013, 12:03 AM   #19
FocusRus
FocusRus's Avatar
Fan#: 109798
Points 356, Level 7
Forum Activity 8%
Wheel bearing grease.....haven't heard that one for sometime.....but it works for damn sure.
FocusRus is offline
Old 06-14-2013, 02:08 AM   #20
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Vaseline used to be recommended, when most folks had that in their home & no car supplies on hand.
I might draw the line at Brylcream though.
Baking Soda & Water is cheaper "Battery Terminal Cleaner" to wash off acid seepage than an official spray can.
(Grin)
"Rubber Side Down"
