All electrical starts to fade out at higher RPMs. What could it be? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-26-2013, 11:10 PM   #1
<focusONthis>
<focusONthis>'s Avatar
Fan#: 55388
What I Drive: 2002 silver ZX3
FF Reputation: 1 <focusONthis> Good Standing Member
Buy-Sell-Trade Rating: (6)
I recently been having an issue with my 02 zx3. The car starts up with no problem & drives fine. The problem is when i got my headlights on at nite, i noticed that as the RPMs go higher, my headlights start to flicker & get very dim, along with the interior lights dimming as well. And if the a/c or heater is on high, it drops down & almost sounds like its off. Then, as i let off the throttle to shift gears, the headlights brighten up completely, along with the interior lights.
Now i looked it up & people say its the alternator but i replaced the alternator about 5 months ago. Also, i had a friend check the battery with a voltmeter when the car was running & it read the normal reading at idle & the normal reading while pushing the throttle a lil.
After reading all the above info, do you know what it is or could be?
I'd really appreciate the help.
Thanks,
Eric <focusONthis>
SoCal Crew#16
Zetec Crew#289
<focusONthis> is offline
Old 02-26-2013, 11:28 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
I have the same problem.
Haven't found the issue yet, hours of dataloging done and nothing jumps out at me other than what's going wrong.
I swear it's the alternator getting weak, but datalogs don't reflect this. If the alt was getting weak I should see charge Duty Cycle rise over time. It hasn't, same as it's always been.
But the thing my car has in common with yours is the problem. Wiring and such are different, mine is rear mount battery and rewired starter/alternator. Kinda adds more faith that it is the alternator.
FWIW, I describe it as acting like the WOT alternator cutout option you can turn on with a custom tune.
OH, you're not playing dumb ...
iminhell is offline
Old 02-28-2013, 03:51 PM   #3
<focusONthis>
Fan#: 55388
Well it's good to know I'm not alone on this but it sounds like its gonna be hell trying to find out what's the problem. Well I'm gonna do what I can to find out the problem.
If anybody else has any ideas, post them.
SoCal Crew#16
Zetec Crew#289
Old 03-01-2013, 12:27 PM   #4
don627
Fan#: 56863
What I Drive: 2014 Focus Hatchback
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 2%
FF Reputation: 1 don627 Good Standing Member
Mine did that for about 4months then the alternator went out completely. After the alternator change no more fading headlights at 4000rpm and above. I did read that you couldn't nail it down by looking at the data. I'm not certain what the actual mechanism behind the fading lights is other that the alt not charging at high rpms and the car running off the battery.
don627 is offline
Old 03-01-2013, 12:30 PM   #5
FocusRus
FocusRus's Avatar
Fan#: 109798
What I Drive: 2004 Silver Sedan SE
Points 356, Level 7
Points: 356, Level: 7 Points: 356, Level: 7 Points: 356, Level: 7
Level Up 12% Completed
FF Reputation: 3 FocusRus Good Standing Member
Buy-Sell-Trade Rating: (9)
altenator.....have it load tested
FocusRus is offline
Old 03-01-2013, 01:22 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,767, Level 73
Points: 12,767, Level: 73 Points: 12,767, Level: 73 Points: 12,767, Level: 73
Level Up 80% Completed
Forum Activity 99%
For one member with this issue a couple years ago I suggested using a spare power adapter in the lighter socket as an easy way to hook up a voltmeter to watch system voltage as he drove, separate from any of the car's systems. In his case it showed an intermittent problem that he hadn't been able to duplicate with the car at rest.
The "Local Rebuilder" that's often recommended here could bench test it for you, but if the recent replacement is under warranty you may be stuck in the repeated replacement "Groundhog Day" scenario of poor rebuilt alternators that is unfortunately all too common....
Good Luck getting it solved!
sailor is offline
Old 03-03-2013, 12:25 AM   #7
<focusONthis>
Fan#: 55388
So how do I test the alternator? I don't feel completely comfortable with working on electricals so I get a lil nervous when I do. Haha! I'm sure u understand.
SoCal Crew#16
Zetec Crew#289
Old 03-03-2013, 12:27 AM   #8
<focusONthis>
Fan#: 55388
And I bought the alternator with warranty at autozone. Do they check the part at the store?
SoCal Crew#16
Zetec Crew#289
Old 03-03-2013, 10:06 AM   #9
don627
Fan#: 56863
Points 208, Level 4
Forum Activity 2%
We have seen lots of crap alternators out there so you were better off rebuilding the one it had. Thats what I did and so far no more issues (knock on wood). At this point I would have yours tested and try for a warranty return but, like someone said it might start feeling like groundhog day with constant bad alternators. I'm not so sure the rebuilt Motorcraft ones are any good either. A friend of mine got a NAPA one and it was fine.
don627 is offline
Old 03-04-2013, 08:24 AM   #10
JayDeZ
Fan#: 97919
What I Drive: 2014 Honda Accord Sport 6-sp manual
Points 1,466, Level 21
Points: 1,466, Level: 21 Points: 1,466, Level: 21 Points: 1,466, Level: 21
Level Up 66% Completed
FF Reputation: 3 JayDeZ Good Standing Member
Take it to autozone, they will load test it in the car. I'm guessing you bought a remanufactured unit from Autozone. Every one I have bought from them had a shelf life of 8-12 months before it had to be replaced again.
If you can afford it, and you are keeping the car for a while, get a new alternator from a place like rockauto.com.
Jay
JayDeZ is offline
