Daily Driver Engine Build 350-450whp>:D - Page 12 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-19-2013, 05:13 PM   #111
BlkNite713
BlkNite713's Avatar
Fan#: 88254
What I Drive: 2002 Viper Blue SVT
Points 1,363, Level 20
Points: 1,363, Level: 20 Points: 1,363, Level: 20 Points: 1,363, Level: 20
Level Up 63% Completed
FF Reputation: 1 BlkNite713 Good Standing Member
Bahahahaha I have them too! All the bolts labeled in bags next to the corresponding parts!
Just replaced all the coolant hoses with blue CFM 10 piece kit. Very good quality stuff!
Will post more pics soon!
Anthony
Anthony ....The one and only GTS Blue SVT
Turbo Tuning Underway!!!!
-Built Motor(Probe/Eagle/ARP)
-Semi Built Tranny(Torsen/Clutchmaster)
-Triplex Comp CT2 Billet HF-X
BlkNite713 is offline
Old 07-19-2013, 07:48 PM   #112
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
Hahaha its like I'm there with ya
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 07-23-2013, 09:34 PM   #113
BlkNite713
BlkNite713's Avatar
Fan#: 88254
...::Update::...
Hit two speed bumps.
1. One of the piston rings was defective from total seal and they are sending me a new one via USPS.
2. When I checked my valves to replace the seals I noticed all the exhaust valves were lightly rusted. Grabbed some WD-40 and 600 grit sand paper and managed to get almost all of it off. I didn't finish them all yet so can't post pics. Since I have to remove everything anyhow I will probably grab some scotch brite pads and clean off the hole head to just play it safe and remove carbon build up. I could replace all the valves but that's $350-$400 in parts from ford(if they even have them anymore) and another $500 at the machine shop.... That's just not in my budget right now. Some I'm gonna clean it throw it back on and hope for the best. If I hear tapping ill just grab another head on the forums vs $1000 worth of work needed to get my head to OEM spec again.
Also, I have come to the realization I had a gigantic problem.... Because I am swapping pistons rods crank ect.... And I removed my cams.... How the heck do I install my timing belt to ensure proper timing? I have the cam tools for the zetec motor but I'm confused as to how I'm suppose to install this thing? Cams and gears are not changing at all! Head is just being scrubbed and new seals.
Thanks for any input!
Anthony
Old 07-24-2013, 11:34 AM   #114
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 21,172, Level 91
Points: 21,172, Level: 91 Points: 21,172, Level: 91 Points: 21,172, Level: 91
Level Up 65% Completed
Forum Activity 7%
FF Reputation: 54 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
surface rust on the valves wont hurt any thing. as long as its not affecting the valve seats and the stems are smooth so they wont damage seals. scotch bright should work fine.
on the cam timing just get the head installed on the new engine with short block set to tdc using the block plug tool. set the cams using the cam plate. then put your belt on and set its tension. very easy on the zetec
Tim
Turbo Turtle Garage
Zetec and Duratec Turbo kits, engine building
turboturtlegarage.com
facebook.com/TurboTurtleGarage
TurboTurtleFab@gmail.com
Turbo Turtle is online now
Old 07-24-2013, 11:58 AM   #115
BlkNite713
BlkNite713's Avatar
Fan#: 88254
Tim:
That's what I figured I just wanted to reverify so thanks for clearing that up. I sent a picture to Tom and he also agreed the clean valves don't need to be replaced. Should finish them today and post some more pics up.
Anthony
Old 07-30-2013, 04:41 PM   #116
BlkNite713
BlkNite713's Avatar
Fan#: 88254
Head is finished and ready to go back on the motor. Quick question.... Which way do the arrows on the pistons point? I know to the front on the motor but which side is the front, the side with the timing belt or the side where the tranny bolts up?
Thanks
Anthony
Old 07-30-2013, 10:50 PM   #117
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
I used mine with the word intake set towards intake side, I didn't have any arrows
FF MODERATOR
RIFF CREW
Old 07-30-2013, 10:51 PM   #118
BlkNite713
BlkNite713's Avatar
Fan#: 88254
I Pm'd Tom earlier and he confirmed it is to the Timing belt side.
Anthony
Old 07-30-2013, 11:37 PM   #119
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
you wouldn't believe how many phone calls instant messengers to tom I did everyday fo rmy engine build. stand up guy. hell he still helps me daily
FF MODERATOR
RIFF CREW
Old 07-31-2013, 12:12 AM   #120
Turbo Turtle
Fins Up!
Fan#: 32772
Forum Activity 7%
Thanks
Anthony
the arrows dont matter. the larger valve reliefs go on the intake side.
tim
Turbo Turtle Garage
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
