Where are heated seat switches located? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-25-2013, 11:27 PM   #11
Lscman
Fan#: 95211
What I Drive: 2007 ZX3
Points 1,218, Level 19
Points: 1,218, Level: 19 Points: 1,218, Level: 19 Points: 1,218, Level: 19
Level Up 18% Completed
FF Reputation: 9 Lscman Good Standing Member
excellent, thanks everyone!!!!!!!!
Lscman is offline
Old 02-26-2013, 06:20 AM   #12
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 578, Level 11
Points: 578, Level: 11 Points: 578, Level: 11 Points: 578, Level: 11
Level Up 56% Completed
Forum Activity 2%
FF Reputation: 1 BrApple Good Standing Member
Originally Posted by Lscman View Post
Did the system have adjustable temp dials in addition to switches? I see some references to levels 1 thru 5. If so, where were these dials mounted? Thanks
The one thru five dial is in the MKIII focus. My brothers 06 ST was just an on/off switch.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is offline
Old 02-26-2013, 07:05 AM   #13
gonefhsn
BEWST AGAIN YAY!!!!!
gonefhsn's Avatar
Fan#: 45759
What I Drive: 13 Tangerine Scream ST2,12 RAM 2500
Points 96,869, Level 100
Points: 96,869, Level: 100 Points: 96,869, Level: 100 Points: 96,869, Level: 100
Level Up 0% Completed
FF Reputation: 21 gonefhsn Great Standing Member
That bezel just snaps in.
gonefhsn is offline
Old 02-26-2013, 06:30 PM   #14
Lscman
Fan#: 95211
OK, but my console bezel is part of the console, one huge piece of molded plastic. It would need to be cut off with a dremel tool in order to install another bezel. Perhaps the cars with these switches had the standard bezel section cut off at the factory allowing the special bezel to snap into place.
I see some cars came with traction control button and no heated seats. It looks to me like a drivers seat switch will plug into the traction control switch hole for drivers only heat feature.
Lscman is offline
Old 02-26-2013, 06:49 PM   #15
Focusblackzx5
Focusblackzx5's Avatar
Fan#: 95212
What I Drive: 2012 Mitsubishi Lancer
Points 1,323, Level 20
Points: 1,323, Level: 20 Points: 1,323, Level: 20 Points: 1,323, Level: 20
Level Up 23% Completed
FF Reputation: 1 Focusblackzx5 Good Standing Member
post a picture of your console ;)
my 05 zx5 SES has heated seats and traction control and it snap out. Even my old 03 SPI base Foci console, without any switch, was just snap in.
2012 White Mitsubishi Lancer 2.0L : New car
2005 Black Ford Focus zx5 SES : Trade In
2003 Arizonna beige Ford Focus SE : Sold
Focusblackzx5 is offline
Old 02-26-2013, 10:45 PM   #16
Lscman
Fan#: 95211
Not much to see. The external appearance of the console suggests the bezel is a separate piece, but when you examine it closely from inside you can see there's no seam separation. It definitely has not been plastic welded together with a machine. Console has been molded as one piece. I should footnote that I'm talking about a factory console I bought on the forum with center armwrest. I don't know the year, so it could be year 2000 or something prior to when traction control and heated seat options became available. Heated seats were apparently not offered in 2000 because they do not appear in the wiring diagram book. I don't think power seats were available either. I'm guessing traction control wasn't. If this is the case, there would be no need for buttons or wiring access thru removable bezel.
Lscman is offline
Old 02-27-2013, 08:42 AM   #17
Bob G
Fan#: 94741
What I Drive: 2007 CD Silver ST
Points 37, Level 1
Points: 37, Level: 1 Points: 37, Level: 1 Points: 37, Level: 1
Level Up 74% Completed
FF Reputation: 2 Bob G Good Standing Member
I'm going to suggest getting another console, probably from a junk yard or fom someone here. A 2 piece console should fit right in, and you don't have to worry about hacking, chopping and cobbling a console.
Bob
Bob G is offline
Old 02-27-2013, 11:47 PM   #18
Lscman
Fan#: 95211
Bob
thnx, I just looked at my original '07 console with no armrest and it indeed has the 2pc design with separate bezel. It may be tough to find an affordable console with armrest in the right color with a single button bezel for drivers heat only. I don't want to spend hundreds for a stupid button, I'd rather just cut a hole to mount it. Oh what to do.......
Lscman is offline
Old 02-28-2013, 08:05 AM   #19
Bob G
Fan#: 94741
Points 37, Level 1
I don't think it would be quite so hard. All Focus' from 2000 to 2007 pretty much used the same console regardless of trim level, plus the vast majority I've seen are black. I never even knew there was any difference until you brought it up (2 piece vs 1 piece).
I guess I should clarify - I would get any 2 piece console and cut a hole for the button. I think you would be happier with the results than trying to cut and reassemble your 1 piece console. Hope this helps.
Bob
Bob G is offline
Old 02-28-2013, 07:16 PM   #20
Lscman
Fan#: 95211
Bob
If I resort to cutting a hole to fit a surface-mounted generic heat button & cobble up wiring, there's no reason to purchase a third console. Realize that the proper factory OEM heated seat button will not fit in a hole cut by hand. They are not surface-mounted.
I already bought a second console costing $100 in order to get an integral armrest. Taking bezel button configurations and arm rests into account, there were at least 16 different "black-ish" console configurations used from '00-'07 (in shades of dark gray, charcoal and black). The shifter hole bezel cover by itself costs over $100 new, some colors and button configurations have been obsoleted. It is especially tough to find a console in good condition and proper color with working armrest latch complete with all plastic parts. Any missing parts will be super expensive or obsolete.
Lscman is offline
