bumps jerk the car to the side on bumps - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-25-2013, 09:05 AM   #1
bp944
Fan#: 109979
What I Drive: 2002 zx3 white, 292k miles
FF Reputation: 1 bp944 Good Standing Member
When I take the large turns on the highway and the car hits a bump, I can feel the car jump to the side. Lets say I'm taking a sweeping right turn at 50. I hit a small bump in the road and the car jumps a little to the left. Its not enough to be warranted as dangerous but its quite unnerving. Is this due to bad struts/shocks or just bad tires. The tires are near the end of their life.
bp944 is offline
Old 02-25-2013, 10:22 AM   #2
Ajr252
Fan#: 109981
What I Drive: 2000 black ZX3
FF Reputation: 1 Ajr252 Good Standing Member
Wheel bearings? Jack the car off the ground and see if you can make the tyre move (with your hands) side to side. I just had to replace a back left bearing. It was moving the car around the road from time to time.
Ajr252 is offline
Old 02-25-2013, 10:23 AM   #3
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,547, Level 22
Points: 1,547, Level: 22 Points: 1,547, Level: 22 Points: 1,547, Level: 22
Level Up 47% Completed
FF Reputation: 7 gondorian Good Standing Member
My car used to do this before I did the whole rear suspension. I think it was a combination of bad bushings and worn out shocks.
gondorian is offline
Old 02-25-2013, 10:38 AM   #4
bp944
Fan#: 109979
Is there supposed to be some sort of dust cap on the front wheel bearings? I got the car and it doesn't have anything on top of the axle nut. You can see the axle nut just sitting there when the wheel is on. (If it does....I'm guessing its the wheel bearings).
When you say bushings, are you just thinking the sway bar bushing or more?
What is the cheapest way to fix this all? The car has 290k miles and I'm looking to go cheap on it. Can I get used struts/springs and be okay? In a perfect world, I'd love to get some cheap coilovers so that I could lower the car for better MPG.
I was looking at the rear suspension and the springs look new. They are black and have no rust/scratches/etc. I'm assuming a 290k mile springs would be a lot worse.
bp944 is offline
Old 02-25-2013, 01:07 PM   #5
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 12 Outback
Points 9,445, Level 65
Points: 9,445, Level: 65 Points: 9,445, Level: 65 Points: 9,445, Level: 65
Level Up 32% Completed
Forum Activity 8%
poor rear alignment will do it too. Your car probably has too much toe out. moving you to the wheels tires brakes section for more answers.
2012 Subaru Outback 6 speed manual - current DD
I always moderate naked!
bringler26 is offline
Old 02-25-2013, 01:28 PM   #6
Ger's 2012 Focus
Ger's 2012 Focus's Avatar
Fan#: 107783
What I Drive: 2012 Race Red SE Focus HB
FF Reputation: 1 Ger's 2012 Focus Good Standing Member
Sounds like poor judgement in driving thru turns, if ya ask ME!
Ger Brassfield - owner of the flaming race red HB
Someone wants to go off-roading in a Focus.......SERIOUSLY???
After driving this car and exiting same, my thoughts are ..."Dang, this car sits LOW!!"
Ger's 2012 Focus is offline
Old 02-25-2013, 02:16 PM   #7
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
x2 on the rear suspension & alignment suggestions. Although, even with new Eagle GT's, new suspension, and fresh alignment, I still get some rear wheel hop in bumpy corners.
OP - some degree of hop is just a fact of life with the lightweight rear-ends of a compact hatchback.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 02-25-2013, 05:43 PM   #8
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 8%
I think what he is referring to is more like a wiggly butt. if your rear tires are hopping over bumps through corners I would advise not hitting such large bumps...
This feeling can be exaggerated if you lift of the gas or brake hard while cornering. Also known as lift induced over steer.
Old 02-25-2013, 05:51 PM   #9
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,995, Level 40
Points: 3,995, Level: 40 Points: 3,995, Level: 40 Points: 3,995, Level: 40
Level Up 23% Completed
FF Reputation: 14 mac.mogul Great Standing Member
It seems like maybe the shocks are worn out.
My Mustang would do the same thing because it had a solid rear axle, but if your shocks are worn out, you're going to end up with the same problem.
If you've got as many miles as you say you do, I would recommend a full suspension refresh down to the bushings.
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
Old 02-25-2013, 06:22 PM   #10
my_beautious_ZX3
Fan#: 32386
nah, that only affects women over the age of 30
