Front Wheel Bearing and ABS sensor.... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-25-2013, 12:13 AM   #1
motorlaw
Fan#: 16505
What I Drive: 2003 InfraRed SVT Focus
FF Reputation: 1 motorlaw Good Standing Member
I dont know if this has been posted before or not so if it is I apologize. My mechanic friend of 20 years and I this weekend took of both front wheel hubs of my SVT focus and brought it to Pepboys to have new bearings pressed in and the old ones pressed out. I myself purchased the new bearings from Advance Auto. When we got the hubs back and finished putting them back on the car we got ABS and traction control sensor warnings. Upon further research I am told that you have to put the bearings in the proper way and not BACKWARDS like my mechanic friend is saying pepboys did. We DO know that they blocked the hole with the circlips for the ABS sensor (which we wound up fixing) once we did the sensor went in NO problem.
My questions are...1) Is it possible I bought the wrong bearings (IE abs bearings or NON abs bearings) or is it one bearing fits both abs and NON abs. and 2) if it IS the case that could not have gotten the right ones. ....did pep boys put the bearings in backwards.
Any help is MOST appreciated. thanks.
motorlaw is offline
Old 02-25-2013, 12:39 AM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,994, Level 74
Points: 12,994, Level: 74 Points: 12,994, Level: 74 Points: 12,994, Level: 74
Level Up 36% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "Wheels, Tires, Brakes & Suspension".
zetecDon is offline
Old 02-25-2013, 06:11 PM   #3
Richard Bridgette
Fan#: 99824
What I Drive: SCCA GT-1 road race Mustang
FF Reputation: 2 Richard Bridgette Good Standing Member
Front wheel bearings and ABS
There are two different front wheel bearings for 2000-2007 Focus, one for non-ABS and one for ABS. Bearing size is the same, but the ABS bearing has a built-in magnetic ring that makes the ABS sensor work. Not only do you need the correct bearing for ABS but th bearing must be installed with the magnetic ring facing the sensor. Richard Bridgette, Huntersville, NC
Richard Bridgette is offline
Old 07-10-2013, 12:55 PM   #4
Lscman
Fan#: 95211
What I Drive: 2007 ZX3
Points 1,214, Level 19
Points: 1,214, Level: 19 Points: 1,214, Level: 19 Points: 1,214, Level: 19
Level Up 14% Completed
FF Reputation: 9 Lscman Good Standing Member
Could somebody please advise me where the front sensor is located on a 2000-2007 Focus equipped with ABS?? Mine does not have ABS, but I would like to install my bearing in the same orientation as an ABS-equipped car.
On a car with ABS, does the red side of the bearing point outward toward the wheel flange and the black side of the bearing point inward toward the transmission....or is this wrong?
All the comments on the forum say the black side of the bearing point toward the sensor, but since I have no sensor, that doesn't help me lol.
thanks
Lscman is offline
Old 07-10-2013, 11:22 PM   #5
DoctorJ
Fan#: 113834
What I Drive: 2001 Twilight Blue sedan
Points 63, Level 1
Points: 63, Level: 1 Points: 63, Level: 1 Points: 63, Level: 1
Level Up 26% Completed
Forum Activity 5%
FF Reputation: 1 DoctorJ Good Standing Member
Front ABS sensor is located on the spindle, on the top, outside of where the strut mounts. This is the location on my 2001 sedan. It can be removed with a 7mm socket.
Your correct on the bearings. Red points outward, black inwards.
My Centric Brand bearings were black on both sides. I just guessed which side was which, and they work. Either i got lucky, or it doesn't matter for the bearings i purchased. I dunno.
DoctorJ is offline
Old 10-09-2014, 08:03 PM   #6
deandeib
Fan#: 109014
What I Drive: 2011 Sterling Focus
Points 34, Level 1
Points: 34, Level: 1 Points: 34, Level: 1 Points: 34, Level: 1
Level Up 68% Completed
Forum Activity 5%
FF Reputation: 1 deandeib Good Standing Member
How did you unblock the hole for the ABS sensor? I am having a problem with the hole being obstructed somehow and the sensor not going in, after bearing replacement. The bearing was installed red side out, which is the correct way, as I understand it.
deandeib is offline
Old 10-09-2014, 08:22 PM   #7
shlbygt
Fan#: 23315
What I Drive: 04 SVT PWSC EAP
Points 673, Level 13
Points: 673, Level: 13 Points: 673, Level: 13 Points: 673, Level: 13
Level Up 46% Completed
FF Reputation: 5 shlbygt Good Standing Member
Most bearings available now are for cars with ABS so the parts manufacturers only need to carry one part number.
The best way to check the bearing is to test with a piece of steel to see which side it sticks to.
The magnetic side of the bearing faces towards the engine/transmission and the C-clip.
If you are looking at the back side of the hub/knuckle, the magnetic side of the bearing faces the ABS pickup that protrudes through the knuckle.
shlbygt is online now
Old 10-10-2014, 05:41 AM   #8
deandeib
Fan#: 109014
Points 34, Level 1
Forum Activity 5%
Is it possible that it's the c-clip that is obstructing the ABS hole? It can't be the bearing itself since it must be pressed in to the stop inside the knuckle. I'm thinking. I can see what looks like the end of the hub turning inside but the obstruction itself does NOT turn. Might be that the gap in the c-clip has to be lined up with the ABS hole so the sensor can go in all the way.
deandeib is offline
Old 10-10-2014, 10:50 AM   #9
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,000, Level 33
Points: 3,000, Level: 33 Points: 3,000, Level: 33 Points: 3,000, Level: 33
Level Up 67% Completed
Forum Activity 8%
I don't own the car, but I'm guessing the answer is yes.
On an SVT thread:
Originally Posted by BadIdea View Post
Side note - if you ever replace the wheel bearing the opening of the c clip has to be at 12 oclock to allow the speed sensor to properly insert.
Looks the same way in this image:
http://www.underhoodservice.com/tech...abs-tone-ring/
PratoN is offline
Old 10-10-2014, 04:20 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,723, Level 73
Points: 12,723, Level: 73 Points: 12,723, Level: 73 Points: 12,723, Level: 73
Level Up 69% Completed
Forum Activity 99%
Looks good
Moved to Brakes, Suspension & Chassis for reference.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
