Paint on Applicator Pad - How Deep of a Scratch? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Auto Washing, Detailing & Paint Protection
Auto Washing, Detailing & Paint Protection Discuss wax, polish, chamois, microfiber towels, simple cloth towel, scratch repair and paint protection. Use this Forum to discuss your cleaning tricks and techniques.
Old 02-24-2013, 10:27 PM   #1
ripto
ripto's Avatar
Fan#: 99257
What I Drive: 2012 Ford Focus
Points 1,435, Level 21
Points: 1,435, Level: 21 Points: 1,435, Level: 21 Points: 1,435, Level: 21
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 1 ripto Good Standing Member
Question Paint on Applicator Pad - How Deep of a Scratch?
I had a guy remove some dings from my car and he ended up leaving some scratches in one area. I went home and used some scratch and swirl remover stuff with an applicator pad and noticed some red color on it. How far down would this mean the scratch is? The scratch catches my finger nail. Should I be looking into wet sanding when the temps get warmer?
2012 Ford Focus SE Sedan, Red Candy Metallic Tinted CC, 5 Speed Manual
SE Sport and Winter Packages, 203A Equipment Group, 17" M&P Wheels
K&N 69-3517TS Intake, Magnaflow 15138 Catback Exhaust, WeatherTech 82573 Window Visors, 35% ON-35 Madico Tint
ripto is offline
Old 02-24-2013, 10:55 PM   #2
jdetzel
Fan#: 102548
What I Drive: 2012 White Titanium Hatchback
Points 173, Level 3
Points: 173, Level: 3 Points: 173, Level: 3 Points: 173, Level: 3
Level Up 46% Completed
FF Reputation: 1 jdetzel Good Standing Member
Has there ever been any repainting done? Getting color on the pad means either you are already down to the base coat, or if repainting was done then you may be on a panel that has been blended and a small amount of color was mixed with the clear.
A scratch that catches your fingernail is usually too deep to be removed by polishing. You can probably reduce it by wet sanding and polishing but you run the risk of sanding through the clear to the base coat. Then the only solution will be painting.
jdetzel is offline
Old 02-24-2013, 11:37 PM   #3
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,642, Level 94
Points: 23,642, Level: 94 Points: 23,642, Level: 94 Points: 23,642, Level: 94
Level Up 30% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
red candy metallic tinted... that sounds like a mess. metallic base coat under red. It's a bit of a deep scratch if it catches on your fingernail. I would be cautious sanding it... I'd hate to see you turn that red into silver.
as for the red coming off on your pad, It sounds like your clear coat IS red.
mikebontoft is online now
Old 02-25-2013, 02:11 AM   #4
billand
Fan#: 103046
What I Drive: 2012 Ford Focus Titanium
Points 404, Level 8
Points: 404, Level: 8 Points: 404, Level: 8 Points: 404, Level: 8
Level Up 8% Completed
FF Reputation: 2 billand Good Standing Member
The color wont come off the car unless the clear coat is burned off. The most likely reson for the color transfering to your wax pad is that the car has overspray on it from being painted or another car being painted neer it.
If you can attach some pics I can guid you on the best way to get the scatches out safely. I opperate my own detail business and have tons of experiance with polishing and paint.
billand is offline
Old 02-25-2013, 07:02 AM   #5
ripto
ripto's Avatar
Fan#: 99257
There hasn't been any repainting done on this area of the car. This problem area is right by the "S" in Focus on the back. I had paint work done (defect from factory) by the passenger rear tire.
I've seen a couple articles and videos where wet sanding doesn't seem that bad. I'd probably start with 3000 grit. It feels like for one of the scratches, there's a flap of metal that piled up on one side, so this makes me think I will need to wet sand.
I will definitely get some pictures up later today. Expect them to be up around 4:45pm EST. I appreciate it!
ripto is offline
Old 02-25-2013, 11:26 AM   #6
billand
Fan#: 103046
Points 404, Level 8
If the reprinted by the tire you have over spray all over your car get a clay bar kit at you local parts stir and follow the directions I bet the paint is all over your car.
Try a product called dr colorchip touch up pair it works way better then duplicolor. Dr colorchip is thicker and sticks and fills much better.
billand is offline
Old 02-25-2013, 02:03 PM   #7
ripto
ripto's Avatar
Fan#: 99257
I do plan to clay bar the car this Spring. However, I'd like to work on this and some other scratches in the mean time. I don't know how overspray would have reached this area. I'd expect it to have gotten over the windows and tail light before it could reach 90 degrees to the back of the trunk, from the opposite wheel, you know what I mean?
ripto is offline
Old 02-25-2013, 03:03 PM   #8
billand
Fan#: 103046
Points 404, Level 8
I do when you clay you'll find it all over your car
billand is offline
Old 02-25-2013, 04:50 PM   #9
ripto
ripto's Avatar
Fan#: 99257
Here are some pictures of the scratches. You can see some parts are almost bowed outward.
ripto is offline
Old 02-25-2013, 04:51 PM   #10
ripto
ripto's Avatar
Fan#: 99257
This other scratch feels much shallower. It barely catches a nail at all, however it stands out too well. Maybe it's just wide? Do you think this would need to be wet sanded, or just compounded?
ripto is offline
