I thought this car got good MPG?! - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-24-2013, 10:10 PM   #11
Njk570
Fan#: 109191
What I Drive: 2012 Ford Focus Titanium
FF Reputation: 1 Njk570 Good Standing Member
Originally Posted by Milwaukee, WY View Post
I was personally averaging 31 MPG all last summer and fall, but since the cold weather set in and with the winter blend fuel, I'm now averaging 27.4. If you look at the Monroney, it gives a range of mileages for the car. 27 MPG falls within this range.
I just find it hard to believe is all, i drive slower than a lot of people and on flat areas, and some people are getting up to 40mpg going 65mpy, while im getting about the same as the Focus ST only going 55.
Njk570 is offline
Old 02-24-2013, 10:15 PM   #12
sgmfocus
sgmfocus's Avatar
Fan#: 101095
What I Drive: 2012 sgm sedan se,sfe package
Points 226, Level 4
Points: 226, Level: 4 Points: 226, Level: 4 Points: 226, Level: 4
Level Up 52% Completed
FF Reputation: 3 sgmfocus Good Standing Member
i would give it time cold weather killed the mileage on my car was averaging 39 last summer(running ethanol free gas) lucky to get 32 when its below 40 degrees, check the air filter ,and the tire pressure you may want to raise it a couple pounds (i run 40 psi)
sgmfocus is offline
Old 02-24-2013, 10:19 PM   #13
Deesiel678
Deesiel678's Avatar
Fan#: 105147
What I Drive: 2013 white SE hatch
Points 550, Level 10
Points: 550, Level: 10 Points: 550, Level: 10 Points: 550, Level: 10
Level Up 50% Completed
FF Reputation: 3 Deesiel678 Good Standing Member
How are you calculating your mpg? Are you basing it off of the mpg display in car, or another method? The built in display can be off by quite a bit at times
2013 Ox White SE hatch black pack 5m
H&R, Eibach, Styluz, K&N, Vibrant, JBR, Injected Engineering
Deesiel678 is offline
Old 02-24-2013, 10:35 PM   #14
Njk570
Fan#: 109191
I tested it both from the display and mathematically on paper. They were both close to each other.
Njk570 is offline
Old 02-24-2013, 11:25 PM   #15
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 3 Juicedz Good Standing Member
I rose to 43.0mpg right before my turn and I had the cruise set @ 50mph on the highway. I'm in s. Florida it's probably 65f out right now. 2013 se hatch 5-speed.
Juicedz is online now
Old 02-24-2013, 11:31 PM   #16
1rkRAGE
Fan#: 107519
What I Drive: 2012 Focus SEL Hatch - Oxford White
FF Reputation: 1 1rkRAGE Good Standing Member
check the tires. I got my used car with mismatched tires, and it was just right around the estimates. For highway it was right on. at 55-62 mph it would be around 37 against a headwind. ~41+ along a headwind. (Winter blend fuel at that)
i easily gained 3+ mpg with new tires. I think for the most part the new tires help with the city driving more. Don't dip below 28 combined now for my usual work routine.
another thing is fuel used. For me premium works, others don't notice any difference though.
1rkRAGE is offline
Old 02-24-2013, 11:54 PM   #17
liquidblue88
liquidblue88's Avatar
Fan#: 109694
What I Drive: 2012 Tuxedo Black 5dr Titanium
FF Reputation: 1 liquidblue88 Good Standing Member
This is my #1 gripe with this vehicle. I have had the car since late December and the MPGs have been average at best. I average around 26 MPGs (currently 25...) It is mostly city driving and stop and go traffic but come on! I try very hard to coast to stops, slowly accelerate, and brake easy.
I brought this up to my car dealer and he said to give it some time. I am not sure how long to give it though.
My gf recently got in my car and said "you only get 25 MPGs... my fusion gets that". The fuel efficiency is very underwhelming! Not happy at all with this.
liquidblue88 is offline
Old 02-25-2013, 12:00 AM   #18
Some Guy From NY
Some Guy From NY's Avatar
Fan#: 101517
What I Drive: 2012 SGM Focus SEL sedan DCT
FF Reputation: 3 Some Guy From NY Good Standing Member
I too get horrible gas mileage. I drive to and from PA a lot, set my cruise at 65mph and only get 33mpg if I am lucky. Usually its between 30-33mpg. Highest I ever got was during the summer on a trip to Rhode Island where I got 37mpg. Never saw that high of a number again.
Very Disappointing.
Mods: Drop in K&N filter, Steeda RSB, MS3 RMM, Remote start, Llumar tint, Ti engine cover, Husky floor mats, OEM splash guards
Some Guy From NY is offline
Old 02-25-2013, 12:15 AM   #19
Njk570
Fan#: 109191
Very Disappointing.
Exactly, like if i would have known it was going to get this low of gas mileage, i would have bought the ST version or a 5.0 Mustang!
Njk570 is offline
Old 02-25-2013, 02:20 AM   #20
billand
Fan#: 103046
Points 404, Level 8
Points: 404, Level: 8 Points: 404, Level: 8 Points: 404, Level: 8
Level Up 8% Completed
FF Reputation: 2 billand Good Standing Member
It depends we have 12 Titanium that my wife drives mostly highway and I drive and 13 ST mostly city I get better MPG then her because the way I drive. She gets 26 to 30 and I get 27 city and my car only has 500 miles.
Some tips on better gas mileage:
Check your tire pressure and wear on the tires
Change the oil to the correct level to much oil is bad
if you use E85 stop its more power but much less MPG
change air filter\
Take the car to for and have for perform a valve cleaning with BG products to get the carbon off the valves direct injection motors collect carbon deposits on valves much faster then a conventional motor
billand is offline
