Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Old 03-04-2013, 10:35 PM   #11
snake420
snake420's Avatar
Fan#: 85194
What I Drive: 2012 Focus TUXBLK SE 5MT
FF Reputation: 1 snake420 Good Standing Member
Originally Posted by felixthecat View Post
"Deeprecon1'' also replaced the front sway bar too. Dropping the cradle adds a little time.
">>>>Undue the sway bar link on the strut & the pinch bolt & pound on the top of the knuckle to loosen the strut from the knuckle. Or you could open up the pincer's on the knuckle w/ a prybar.<<<<"
We actually did all the above, and it was still quite difficult. I think it was a mixture of the slightly below 50° temperature, winter road grime, and inexperience. Definitely a "spring" job.
snake420 is offline
Old 03-05-2013, 05:34 PM   #12
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 34 felixthecat Great Standing Member
Thats where a garage w/ heat comes in, huh
Interduce Mr. Torsen to the mix D23 crew- D-Tech- Sedan Revolution= #131
felixthecat is online now
Old 03-20-2013, 05:45 AM   #13
RedVAhb757
Fan#: 111780
What I Drive: 2012 Red Automatic Hatchback
FF Reputation: 1 RedVAhb757 Good Standing Member
If you had the choice to do it over again would you have gone with the steeds springs & bars? I'm contemplating this same kit really hard. I do know the ride in my focus is rougher now than when I bought it but I accredit that to the factory continentals having 42k miles on them and 4/32 tread left.
RedVAhb757 is offline
Old 03-20-2013, 09:00 AM   #14
Deeprecon1
Fan#: 109780
What I Drive: 2013 silver se 5 speed & 04 F250SD
FF Reputation: 1 Deeprecon1 Good Standing Member
That is a hard call, I have not driven a focus with Steeds. I would suggest you get a set of struts and shocks before you take on the swap. DONT USE STOCK
the foci will handle much better w/ sways and springs. I really need to get off my butt and post pics showing how the car stands with stock 17s. I have no wheel gap and have never rubbed.
Compression rate on the stock strut is not set up for handling the rough Cali roads.
Rebound is ok ... but you will have a little NOT BAD bounce after mild bumps
The sways ... make a big difference in roll. Very noticeable when cornering hard on rough surface. The foci likes to rail corners
The big question is are you going to self install ?
you will need METRIC sockets, wrenches, Allen keys .. big cheater bar.
Since your back east soak the bolts the night before "liquid wrench"
13 Silver 5spd MT
Deeprecon1 is offline
