Planned - Mach HID spruce up - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus SVT > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 03-14-2013, 11:35 AM   #11
mikeb0916
mikeb0916's Avatar
Fan#: 87595
What I Drive: 03 Twilight Blue ZX3 PWSC & 06 ST
FF Reputation: 2 mikeb0916 Good Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by p0sitivevibez View Post
TRS emailed me back and suggested the Evox-r projector swap. I found on the other Focus site that they don't fit.
So..
OEM housing lense swap
Laminx clear w/UV
TRS E55 clear lenses
TRS Morimoto 50w ballasts/bulbs (5000K)
I would love to swap some upgraded projectors in there but they won't fit and I don't want to mess with fabrication.
The EvoX-R do fit, but the oem ignitor doesn't fit or attach to the back of it. They mount perfectly inside of a mach housing. I bought a set when they first came out and learned the hard way. I actually still have them sitting in the shipping foam/box (minus the clear lens) with no use for them.
2003 Twilight Blue ZX3
Powerworks BBK, Quaife, Spec stg. 2+, Fidanza, and more...
2006 Pitch Black ST
Cold air intake (HID retrofit coming soon)
mikeb0916 is offline
Old 03-14-2013, 11:43 AM   #12
p0sitivevibez
p0sitivevibez's Avatar
Fan#: 11223
What I Drive: SVTF
FF Reputation: 1 p0sitivevibez Good Standing Member
Buy-Sell-Trade Rating: (6)
Ahh so there's no way to hook them up even?
That sucks dude!!
p0sitivevibez is offline
Old 03-14-2013, 11:59 AM   #13
mikeb0916
mikeb0916's Avatar
Fan#: 87595
That sucks dude!!
You can hook them up if you're using a ballast that has the d2s end on it (like the morimoto 3five or 5five ballast (or the majority of any oem ballasts like denso)
The bulb would go into the back of the projector housing like usual and then the d2s plug from the ballast securely attaches to the bulb
I was going to go this route, but I actually was able to find a set of the Hella HID projectors from the FJ group buy that are completely sold out.
Now, you would have to find a way to power the aftermarket ballast, but that would be needed no matter what projector you are using if you are using a ballast other than oem.
2006 Pitch Black ST
Old 03-14-2013, 12:11 PM   #14
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
FF Reputation: 4 calebstubstad Good Standing Member
i kinda wanna do a clear lense swap and remove the foreground limiter cap thing, but the directions i saw, i can't understand at all
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 03-14-2013, 12:28 PM   #15
mikeb0916
mikeb0916's Avatar
Fan#: 87595
We're lucky because we can take the projector unit out of the headlamp housing through the back of the housing.
Make sure you unplug the ignitor, take the bulb out and put in a safe place (no fingerprints). You should be able to see four screws that hold the projector in the housing. Take those out and you should be able to maneuver the projector housing out of the headlight housing.
The lens is held in with a metal ring on the back side of it. Take out the metal ring, and the lens comes right out. Taking the foreground limiter is easy, just bend the tabs on top wide enough apart to slide it off the metal bracket. You just have to be careful not to scratch the inside of the projector bowl. Once it's scratched, there is no going back and fixing it without a new projector unit.
2006 Pitch Black ST
Old 03-14-2013, 12:32 PM   #16
calebstubstad
Chef Boyardee
Fan#: 103240
oh, it is that easy? lol. i'll try it here one of these days. maybe saturday. as for clear lense, i need that ballast first then i'll work on making em better haha. will they still be way better than halogens even without removing the limiter or adding clear lenses?
[HOONIGAN]
Old 03-14-2013, 12:56 PM   #17
mikeb0916
mikeb0916's Avatar
Fan#: 87595
I had just the clear lens and it is definitely a decent cheap upgrade, and even just upgrading to the machs from halogens it will be much better.
Once you start getting into it, you might have to align the projectors with the screws and such, but nothing with the lighting is difficult as long as you take your time and have patience.. otherwise things can go wrong fast if you rush lol.
2006 Pitch Black ST
Old 03-14-2013, 01:04 PM   #18
mikeb0916
mikeb0916's Avatar
Fan#: 87595
I believe the 35w kits plug right in to the Machs, but the 50w kits will have to have some creative wiring. I'll have my buddy help me with that.
They won't be plug and play. You will have a pigtail that plugs into the ballast. Somehow you need to wire in the pigtail. If you were getting the morimoto 3fives, I would say pull power from right inside the mach housing where the oem ballast was pulling power. IDK if the wiring inside the housing can handle 50w pull, so I would tap into the car wiring harness before the plug that goes into the mach housing.
2006 Pitch Black ST
Old 03-14-2013, 01:28 PM   #19
calebstubstad
Chef Boyardee
Fan#: 103240
what is meant by allignment of projectors upon reinstalling them? i understand the little twist knobs to get the cutoff at the right height, is that all you mean?
[HOONIGAN]
Old 03-14-2013, 02:35 PM   #20
mikeb0916
mikeb0916's Avatar
Fan#: 87595
Yep.
2006 Pitch Black ST
