Small clunk when diving from a stop - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus ST > Focus ST
Focus ST The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK3 2013-Current Focus ST.
Old 02-19-2013, 02:34 PM   #1
aernan
Fan#: 105907
What I Drive: 2013 performance blue ST3
FF Reputation: 1 aernan Good Standing Member
Recently I noticed a repeatable small clunk noise from the front left engine area. The car does not always make the sound. When it does I can disengage the clutch and re engage three clutch and it makes the sound again.
I suspect it may be an engine mount. Is it possible to inspect the mounts without removing the bottom skid plate?
aernan is online now
Old 02-19-2013, 06:19 PM   #2
StingRay
StingRay's Avatar
Fan#: 67421
What I Drive: 2013 Ingot Silver ST
FF Reputation: 4 StingRay Good Standing Member
Lower rear engine mount is notoriously weak. Most peoples recommended first mod is to replace it with a stronger aftermarket unit. There should be a thread about it around here somewhere...
StingRay is online now
Old 02-19-2013, 06:21 PM   #3
StingRay
StingRay's Avatar
Fan#: 67421
I can't find an ST specific thread, but the mount is the same in the base models anyway so it doesn't matter. this thread has some good info on the mounts; http://www.focusfanatics.com/forum/showthread.php?t=287381
Old 02-19-2013, 08:01 PM   #4
aernan
Fan#: 105907
somewhere down that long thread it got hijacked. There is some talk about the engine smacking the firewall on hard takeoff (drag racing). I am accelerating quite slowly. I would only expect noise if one of the mounts had torn badly. It looks like you need to get the car up on a lift and remove the skid plate to inspect that portion of the car. I only have a driveway/garage to work in. It's snowing right now so I'm not going to climb under today.
Does anyone have any other ideas what it might be?
Old 02-24-2013, 08:50 AM   #5
rohmbd
Fan#: 102877
What I Drive: 2009 Fit Sport
FF Reputation: 1 rohmbd Good Standing Member
Spray some WD40/lithium grease on the Airbox 3 rubber mounting points. Stopped my noise. Check it first by moving your air box around. Had the noise for months, took 5 minutes to make it go away.
rohmbd is offline
Old 02-27-2013, 12:09 AM   #6
Burns098356GX
Burns098356GX's Avatar
Fan#: 94777
What I Drive: 2013 Focus ST
FF Reputation: 1 Burns098356GX Good Standing Member
I recently had a similar problem on my SEL, also in the left front. Turned out it was the grommet between the airbox and the hose leading from it. It'd make a clunky noise if I stopped quick, went over a curb or sewer cover. I put some silicon goop around it and its resolved.
Might want to check that.
Sent from my HTC-Z710a using FF Mobile
Burns098356GX is offline
Old 02-27-2013, 11:07 AM   #7
aernan
Fan#: 105907
that's good advice. When I get a chance I'll give it a try.
