Window question. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-19-2013, 04:50 AM   #1
Plymchris
Fan#: 110100
What I Drive: '07 Estate
FF Reputation: 1 Plymchris Good Standing Member
Window question.
Hi there, I have a MKII estate. The rubber seal at the bottom of the electric window (both passenger and driver) has a built up quite a garden of moss, even though I have done a fairly good job of cleaning this all up I have a problem in the fact that when the windows wind down the seal does not wipe the water off the windows so not only does it mean that I cannot clear them easily when the are wet but I am also worried that this means water will be able ot easily run down inside the door.
Any suggestions? Also wat is the technical name for this component should I have to replace it? Whenever I search for window seals I get the ones that run around the edge but not the bit at the bottom.
Many thanks for any help.
Plymchris is offline
Old 02-19-2013, 06:54 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Window weatherstrip? They might call that part something different on that side of the pond- it happens like that. Are you sure you're not searching for Door weatherstrip instead of window? The window should only be the window channel and weatherstrip. The channel is the hard felt part that the window fits into, and the weatherstrip is the rubber wiper at the bottom of the window. The door weatherstrip is the foam rubber between the door and the body that is supposed to keep the air out.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-19-2013, 08:15 AM   #3
Plymchris
Fan#: 110100
I guess it would be the weatherstrip, the bit that scrapes the water etc off the window glass when you wind it down. This bit of rubber and felt doesn't contact the window glass at all anymore.
Old 02-19-2013, 12:04 PM   #4
jdetzel
Fan#: 102548
What I Drive: 2012 White Titanium Hatchback
Points 177, Level 3
Points: 177, Level: 3 Points: 177, Level: 3 Points: 177, Level: 3
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 1 jdetzel Good Standing Member
It is usually called a belt moulding or belt weatherstrip.
jdetzel is online now
Old 02-19-2013, 11:04 PM   #5
amc49
Fan#: 96610
Points 3,362, Level 36
Points: 3,362, Level: 36 Points: 3,362, Level: 36 Points: 3,362, Level: 36
Level Up 8% Completed
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
You need to have the understanding that there is NO WEATHERSTRIP ON THE PLANET that guarantees water not getting in door at all. The technology does not exist. ALL car doors have small drain holes on bottom of door to drain water that gets inside, in short they are designed to take on some amount of water getting inside. . The weatherstrip simply stops a LOT of the water from getting inside but not ALL, and no auto dealer on the planet will tell you the door is totally watertight at the bottom of window because it's NOT.
One incident of running window down in very icy conditions will cut the strip edge up enough that it will not wipe all water off, the ice frays the edge.
amc49 is offline
Old 02-20-2013, 01:14 AM   #6
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,621, Level 31
Points: 2,621, Level: 31 Points: 2,621, Level: 31 Points: 2,621, Level: 31
Level Up 14% Completed
Like he said:
Doors need to drain, it's how they are all designed.
That's why they have all drain holes, and a water shield behind the door panel.
You might want new window "fuzzies" but it won't stop water ingress to the interior of the door.
elsolo is online now
Old 02-20-2013, 06:40 AM   #7
Plymchris
Fan#: 110100
Ok I get that the doors will need to drain, i was just mostly worried about large amounts pouring down there and also the fact that the windows don't get wiped off so the seal/fuzzie etc is not actually contacting the window it seems.
I believe I have found the correct part thanks to the search suggestions here, however it seems to be quite an involved job replacing them, anyone here done it and know of a quick way, I'd rather not remove the whole of the door panel just for a weather strip.
Old 02-20-2013, 12:00 PM   #8
elsolo
elsolo's Avatar
Fan#: 96835
Door panels are easy, watch a youtube video if you want to see what you are taking apart. Few screws and a couple clips. 5-10 minutes for a first timer to remove it.
Old 02-20-2013, 12:28 PM   #9
Plymchris
Fan#: 110100
Well that's re-assuring. Might have a go once the weather warms/dries up a bit.
