01 zx3 manual trans won't go into gear - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-18-2013, 08:44 PM   #1
Willybignut
Fan#: 110039
What I Drive: 2001 red zx3
FF Reputation: 1 Willybignut Good Standing Member
Hi i'm new to the forum here. I've searched and read for a few days now and haven't found an answer to my problem. Any help would be greatly appreciated. That being said here is my problem:
My g/f's 01 zx3 (140k miles) has been very reliable and running fine up until this point. We were driving in a parking lot when i stopped and went to go again and it was very difficult to put into gear almost like driving without using the clutch. I parked the car at the store and came back and it drove just fine. A few miles later it started to be very difficult to shift again for the rest of the drive home. The next morning the car will start and idle just fine but when the clutch is pressed it will not go into any gear. When the car is off it will go into gear just fine. If I try to start it while in gear, the engine turns over and shakes like its stalling but never starts. The clutch was not slipping before, although it is 4-5 years old. Also the pedal still feels normal as does the shifter. I checked the shift cables and they are still intact.
Any suggestions?
Willybignut is offline
Old 02-18-2013, 09:30 PM   #2
ManiacalZX3
ManiacalZX3's Avatar
Fan#: 6111
What I Drive: 2001 White ZX3
Points 520, Level 10
Points: 520, Level: 10 Points: 520, Level: 10 Points: 520, Level: 10
Level Up 40% Completed
FF Reputation: 1 ManiacalZX3 Good Standing Member
I had this on my 1991 escort. What I found was that the needle bearings in the pilot bearing came out and caused the input shaft to get seized into the pilot bearing in the crankshaft. So the clutch felt normal, I even could see the slave cylinder move normally against the clutch. I could shift with the engine off, if I was already moving I could shift gears by matching rpms. Now Im not saying its the bearing for sure but I would bet money on something with the clutch or related part. Sadly Im sure you have to pull trans and engine apart to look inside.
ManiacalZX3 is offline
Old 02-18-2013, 10:56 PM   #3
Squareleft
Squareleft's Avatar
Fan#: 33224
What I Drive: 01 ZX3, 07 Volvo S60R
Points 1,090, Level 17
Points: 1,090, Level: 17 Points: 1,090, Level: 17 Points: 1,090, Level: 17
Level Up 90% Completed
FF Reputation: 1 Squareleft Good Standing Member
Buy-Sell-Trade Rating: (6)
Agreed. sounds like a clutch. Taking it out is the one certain way to see if its the clutch or something internal.
Squareleft is offline
Old 02-20-2013, 02:25 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,443, Level 75
Points: 13,443, Level: 75 Points: 13,443, Level: 75 Points: 13,443, Level: 75
Level Up 49% Completed
Forum Activity 99%
'Fraid it does sound like a clutch issue. One similar issue another member had that would explain the intermittent nature of the problem was a clutch disc that had a piece of friction material break off and wedge between the surfaces locking it up partially.
When something like this happens it's likely almost worn out anyways, so there prob. wasn't much life left before it started slipping anyways.
Give it a couple short tries starting it in gear with the clutch depressed. IF this is what happened you MIGHT be lucky & it's just a small piece loose that'll drop out & the thing will work again for a while....
sailor is online now
Old 02-20-2013, 04:13 PM   #5
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 592, Level 11
Points: 592, Level: 11 Points: 592, Level: 11 Points: 592, Level: 11
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 1 BrApple Good Standing Member
the MTX-75 doesn't use a pilot bearing so it isn't that.
Does the car shift normally when the engine isn't running? If so it sounds like a clutch issue. Try bleeding the clutch first and see what happenes.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is online now
