2010 coupe 50K maintenance suggestions - Focus Fanatics
Old 02-18-2013, 06:45 PM   #1
anwi1179
anwi1179's Avatar
Fan#: 72587
What I Drive: 2010, black, focus se coupe
FF Reputation: 2 anwi1179 Good Standing Member
I'm 30 miles from 50K. A routine oil change is due about now. I was wondering if I need to swap out tranny, clutch, and radiator fluids about now too? Plus I've noticed 1st and R are pretty tough to shift into from full stops sitting in natural and when its cold.
anwi1179 is offline
Old 02-19-2013, 05:41 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
FF Reputation: 270 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
You just now need an oil change? UH... you should've had like 10 oil changes so far.
You need:
1) Remove spark plugs, clean, add anti-seize, check and adjust gap- reinstall.
2) Clean MAF
3) Air filter
4) Fuel filter- which should be changed every 20-30k miles or 1 year if you want to keep your fuel pump running as long as possible. I hope to get 200k out of mine.
5) Transmission fluid check
Personally, I think your transmission fluid is fine. All manual transmissions do that. What you do is shift into all the gears until the gears start to catch.
You don't change the clutch until you fail the clutch test- which is simple. Find a flat road, get up to 15 mph or so, shift into 4th gear, and floor the accel. One of 2 things will happen when you release the clutch pedal and floor the gas: 1) the engine will rev high, but the car will not move. This means you need a new clutch. 2) the engine will make a horrible groaning noise, and the car will not move. This means your clutch is ok. No matter which one you get, push the clutch pedal back in immediately.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-19-2013, 06:45 AM   #3
05focusST91
05focusST91's Avatar
Fan#: 83640
What I Drive: 2008 chevy cobalt SS/TC.
FF Reputation: 6 05focusST91 Good Standing Member
Id definitley check the coolant it should be done around 40k, if you wanna check the battery too if it has lost any power
Funtion>form.
FLOOR IT!
2005 focus ST (gone)
Still here!
05focusST91 is offline
Old 02-19-2013, 04:14 PM   #4
anwi1179
anwi1179's Avatar
Fan#: 72587
what do you mean by this? are you talking about 1st and reverse being hard to shift into? cause this hasn't been an issue before.
anwi1179 is offline
Old 02-19-2013, 05:27 PM   #5
whynotthinkwhynot
Captain TMI
Fan#: 18416
When it's cold, that happens. You might be seeing the beginning of the dreaded transmission shift tower pin failure. That usually doesn't happen until after 100k, but it could happen earlier if you spend a lot of time in traffic shifting.
Be eclectic.
Old 02-19-2013, 07:13 PM   #6
anwi1179
anwi1179's Avatar
Fan#: 72587
damn that sounds like its expensive to fix..
anwi1179 is offline
