Old 02-18-2013, 09:13 PM   #11
duder
Fan#: 110014
What I Drive: 2003 SVT
FF Reputation: 1 duder Good Standing Member
I am going to offer him 4500, if he doesn't take it, then I'm going to walk away.
duder is offline
Old 02-19-2013, 07:13 AM   #12
Bob G
Fan#: 94741
What I Drive: 2007 CD Silver ST
FF Reputation: 1 Bob G Good Standing Member
Hope everything works out for you.
Bob
Bob G is offline
Old 02-19-2013, 11:52 PM   #13
duder
Fan#: 110014
Guy did me a favor, sold it out from under me. May have found an SVT focus, to bad its a 2 hour drive to go see it. will probably look for other cars along the way there.
duder is offline
Old 02-20-2013, 04:58 AM   #14
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 2002 Land Yacht (Windstar)
FF Reputation: 263 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
Yes he did a favor. Seriously, no car is a good car if it's been wrecked, and I never believe a seller's explanation of the wreck. Ask any mechanic who is not trying to sell you a car about it.
Good luck! If you're interested in Focis specifically, then keep reading on this site so you discover what some of the problems might be with those cars. Most problems are very easy repairs when you know what it is, but you might run across people who don't have these resources and have thrown a lot of money at a car to fix it with no avail.
For example, you should be careful of SVTs that are near clutch replacement age and have not had a new clutch. Clutches are very expensive for those cars and 05+ Focis because a new flywheel is required. Both have DMF's. Zetecs use SMFs, and under no circumstance do you want an SPI. It's a good way to talk down a seller who feels guilty for selling a car because of an imminent expensive repair.
Engine running problems are the ones you can use to your advantage to get money off when the repair is simple as described on this site.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-21-2013, 07:57 AM   #15
duder
Fan#: 110014
Picked up a 2003 SVT Focus instead, 139k miles, got it for $4000. Car is spotless. worried about the timing belt though.
duder is offline
Old 02-21-2013, 10:51 AM   #16
sailor
"Elder"
sailor's Avatar
Fan#: 57268
What I Drive: 2004 Pitch Black ZTS
FF Reputation: 48 sailor Great Standing Member
Sounds like a decent purchase, on a car that's worth taking care of & enjoying!
(I hate putting time & effort into a vehicle that's not worth it)
Timing belt IS important to replace at regular intervals, if you don't have the maint. history on when it was done it would be a good thing to schedule replacement as soon as possible.
Before diving right in, take some time reading up here on what is involved & what other items you might want to replace at the same time to avoid any future maint. issues. The Timing belt on these isn't a simple task, and requires special tools &/or skills to do right - so some research is warranted before attempting it. Many pick that time to do major maint. at the same time since much of the labor is included in the timing belt job. For example, the serpentine needs to be removed so replacement of that & it's idler pulley/tensioner is often done as well. Some go so far as to replace the water pump as well while it's easily accessible.
Not all of this NEEDS to be done at once, and certainly depends on budget available. Help from an experienced acquaintance who can assess condition & guess at time since last maint. would help. Timing belt is relatively critical, as you've apparently noted from your research to date - the rest is optional.
"New to You" maint. like fluids, filters, (don't forget fuel filt.) and a general check over looking at hoses, brakes, suspension & driveshaft joints & rubber boots will give you peace of mind. Keeping an eye on things this way can prevent a lot of surprises, and you can then schedule a lot of repairs before they become emergencies.
This sounds like a LOT of work, but it doesn't have to be done all at once! As time goes on you simply develop the habit of looking around (when you do an oil change for example) to see if everything looks "normal" that you don't get a chance to see in normal daily use.
Welcome to FF!
Enjoy the new SVT, and don't be a stranger - there are areas on here of interest beyond just fixing the new car, hope you enjoy checking it out!
sailor is offline
Old 02-21-2013, 08:28 PM   #17
duder
Fan#: 110014
Im not so worried about the maintenance, will most def be tearing into it soon. Thanks for the info!
duder is offline
