08 foglight mod - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-18-2013, 12:31 AM   #1
dcorwin822
dcorwin822's Avatar
Fan#: 53054
What I Drive: 2008 Vermillion Red SES
Points 3,431, Level 36
Points: 3,431, Level: 36 Points: 3,431, Level: 36 Points: 3,431, Level: 36
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 11 dcorwin822 Great Standing Member
08 foglight mod
Fixed the link. Was going to update the old thread but they closed it.
here's a google docs link as well: https://docs.google.com/file/d/0B8XV...it?usp=sharing
dcorwin822 is offline
Old 02-18-2013, 06:26 AM   #2
A7xschecter6661
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
I have been waiting for this forever! Thanks!
Not sure if I am going to mess with it this far though. It would be easier to run a switch on my HID relay harness.
The reason the fogs turn off is when you turn your high beams on you want to focus on the far away light. If your fog area is lit up its hard to see further. They are on with lowbeam so you can see close, and mid ways away.
But I am the same as you, I only need to see mid so the extra light combined with the high beam and the fogs on top of the mid range light would be excellent. Also it would not overpower anything because both sets of lights are 35w HIDs totaling 70w. Where the original lights would both be running 110w for low and 120w for high.
My lights are always technically on low beam since I did the HID retrofit. All hitting the high beam switch does is drop the shield in the projector. No change in wattage, just my foglights kick off
So if I want this to work I can run a switch off the foglight relay harness and turn them on and off whenever, or I can put a switch on the highbeam shield solenoid and turn my highbeam on and off whenever while technically leaving it on lowbeam with the fogs on.
A7xschecter6661 is offline
Old 02-18-2013, 07:23 PM   #3
Snyper
Snyper's Avatar
Fan#: 96688
What I Drive: 2009 Black SE
Points 1,529, Level 22
Points: 1,529, Level: 22 Points: 1,529, Level: 22 Points: 1,529, Level: 22
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 2%
FF Reputation: 2 Snyper Good Standing Member
Looks like so much work compared to just using a separate switch for the fogs.
Nice write up, though.
Snyper is offline
Old 02-18-2013, 10:20 PM   #4
dcorwin822
dcorwin822's Avatar
Fan#: 53054
Possibly. Although this involves no wire cutting, splicing, or hacking leading to a cleaner mod. To each there own.
