RPM's stay high or vary randomly at idle - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 02-17-2013, 09:44 AM   #1
p58ff
p58ff's Avatar
Fan#: 25247
What I Drive: 2010 Red 4-Door SES
FF Reputation: 1 p58ff Good Standing Member
As the title says the engine speed has been acting strange recently. I first noticed that the engine speed was staying high when I stopped for stop lights and the like. It was up in the 2K RPM zone. The accelerator pedal is not sticking from what I see.
Yesterday after using the car to jump a dead battery on my truck the engine speed just started climbing then went back down. After a few minutes it did it again and I also noticed that both cooling fans came on and I thought I heard the A/C compressor 'clack' on. Again it cycled and after a minute or so it was normal again.
I'm looking for some ideas on places to have a look to solve this mystery.
Pav
p58ff is offline
Old 02-17-2013, 10:15 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
Points 27,115, Level 97
Points: 27,115, Level: 97 Points: 27,115, Level: 97 Points: 27,115, Level: 97
Level Up 77% Completed
Forum Activity 4%
Is the DEF or DEF/FLR selected in the vent selector? If so, that will turn on the AC even if you have heat on.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 02-17-2013, 12:42 PM   #3
p58ff
p58ff's Avatar
Fan#: 25247
It could have been as it was in the 30* degree temp range and I was clearing snow among other things. I had forgotten about that possibility.
That may account for the fans spooling up but that still leaves the erratic idle speed/raised idle speed issue during regular driving.
p58ff is offline
Old 02-17-2013, 01:32 PM   #4
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
Not really, as long as you're on those settings the AC idle is going to be set.
Which engine do you have? Have you checked the usual suspect- the PCV valve line? That or any other vacuum leak you can find under the hood by listening for a hiss. Follow the VECI vacuum schematic for locations. Just trace down the lines- there are only about 5 or 6.
Be eclectic.
Old 02-18-2013, 07:55 AM   #5
focusse13
Fan#: 109854
What I Drive: 2013 Ford Focus SE
FF Reputation: 1 focusse13 Good Standing Member
IAC valve maybe?
focusse13 is offline
Old 04-21-2013, 10:06 AM   #6
p58ff
p58ff's Avatar
Fan#: 25247
IAC did not help. Thinking it might be a vacuum leak as I just noticed the rubber fitting that connects the PCV line to the throttle body was in bad shape. Need to address that first I think.
p58ff is offline
