boost a bad idea? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-17-2013, 10:07 AM   #1
00ZX3red
Fan#: 107099
What I Drive: 2000 Red ZX3
FF Reputation: 1 00ZX3red Good Standing Member
boost a bad idea?
I have a 00 zetec with 280000km. Im going to add a CAI in the spring. I was thinking of adding boost as well. Do you think the motor could take the extra pressure?
She is currently running 5w20 syn. Hasn't Got a leak and hits redline daily. I do mostly highway drives 150km a day. Are their any prerequisites you guys would recommend or do you feel boost Probably isn't a good idea given her age.
Thanks
John
00ZX3red is offline
Old 02-17-2013, 02:06 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,620, Level 62
Points: 8,620, Level: 62 Points: 8,620, Level: 62 Points: 8,620, Level: 62
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
Forum Activity 27%
Activity: 27% Activity: 27% Activity: 27%
Do a compression check. If all looks good start out small and slowly add more. Stock block usually around 12-14 psi of boost.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 02-17-2013, 07:00 PM   #3
inis
Fan#: 32050
What I Drive: 00 Zx2 s/r (yellow)
Points 2,856, Level 32
Points: 2,856, Level: 32 Points: 2,856, Level: 32 Points: 2,856, Level: 32
Level Up 71% Completed
Level up: 71% Level up: 71% Level up: 71%
FF Reputation: 1 inis Good Standing Member
Thanks
John
Agreed with Magus about a compression check.
However I wouldn't go put 12-14psi on a stock block even with the best tune. Most turbo's worth a shit at 12-14 will break a rod (or 2) on a stock block.
Seriously thats some horrible advice.
Anyways, start with a compression check and go from there.
inis is online now
Old 02-17-2013, 07:56 PM   #4
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
Almost every "stock" zetec or "how much boost" thread / post on both this forum and others state that 12 psi that provides about 220-250 HP is fine on the stock block. The JR BBK provided about 8 IIRC. The pro charger about 10psi.... that is not "horrible" advise.
Hatch Nation #42
Old 02-17-2013, 08:00 PM   #5
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 15,082, Level 79
Points: 15,082, Level: 79 Points: 15,082, Level: 79 Points: 15,082, Level: 79
Level Up 47% Completed
Forum Activity 5%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
start off low like was suggested. wouldnt suggest anything more than 12psi though even if your car is in spectacular working order. i think what he was saying is 14psi is a little much for a stock bottom end. it just depends on how long you want the stock bottom end to last. 14psi might earn you a blown motor before too terribly long.
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is offline
Old 02-17-2013, 10:21 PM   #6
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
My initial range was a little on the high end... Should have been 10-12 as a max.... But as has been identified in another post two different turbo setups at the same PSI can provide very large differences in output power. So it should be more references on output power in the 220-250 (max) range.
Hatch Nation #42
Old 02-17-2013, 10:30 PM   #7
inis
Fan#: 32050
even 12psi is alot on any turbo worth a dam.
No one here has a right to post how much he can run without knowing turbo specs. All you are doing is giving him/her a blown motor.
Sure he could run 12psi, but that might last 2hrs vs 2 years.
inis is online now
Old 02-17-2013, 10:54 PM   #8
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
I said "usually"....this is also a open public forum so every one is open to there own opinion. One poster such as my self should not be the only word that is viewed before doing any thing to OP's car. The OP should also search on the forum as this has been asked many times.
Many dyno runs show that 10-12 psi is the approximate value on average that will yield approximate 220-250 HP. Many people and engine builders who on this forum will say that, this is the theoretical "maximum" HP on a stock healthy Zetec block. There are many variables in a FI setup that will all run into reliability and power outputs. One should take a large number of hours and at a minimum few weeks researching what is needed and what is required to do a FI turbo set up.
Hatch Nation #42
Old 02-18-2013, 09:33 AM   #9
DarwinSays
DarwinSays's Avatar
Fan#: 35941
What I Drive: 2004 SVT Silver / EAP / CWP
Points 1,382, Level 20
Points: 1,382, Level: 20 Points: 1,382, Level: 20 Points: 1,382, Level: 20
Level Up 82% Completed
FF Reputation: 2 DarwinSays Good Standing Member
Define worth a damn. plenty of high end racing motors run 20+PSI all day long
They're not giving him a blown motor by suggesting a max of 10-12psi, OP is doing that for himself by believing he can boost an engine with that many miles on it without having any problems with it.
Honestly, if you want more power from the engine, rebuild the internals first. forged conn rods, pistons, rings, gaskets, etc. maybe a number of SVT parts and then boost it from there so that you're better assured it's not gonna blow up a week after you put the turbo on it. If this is your only vehicle and can't afford the down time, then maybe look into getting a donor motor on to build up in your spare time and swap when it's ready. This also lets you build the other motor up so you have a spare on hand if/when the current one acts up. ~.^
my $.02 - good luck, whatever you choose to do.
User Gallery
#include 'brain.h'
DarwinSays is offline
Old 02-18-2013, 10:36 AM   #10
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
By worth a damn, he meant good for performance. 12 psi power will vary by turbo, you can have 12psi with 330wtq or 200wtq, notice I pointed torque and not HP or psi.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
