Old 02-17-2013, 08:23 AM   #1
alz focus
Fan#: 67546
What I Drive: 2002 Blue SE
FF Reputation: 5 alz focus Good Standing Member
Gauge sweep every time you start the car
On my 2000 Focus, my daughter's car, I notice that the gauges sweep all the way to max and then down every time I start the car.
I drove this car for about six months when first purchased and don't recall it doing that then in 2011.
The tripometer doesn't reset and the aftermarket radio doesn't loose any info either. No other abnormalities that I can think of except a recurring P0171 that I can't get rid of for more than a year now.
Any ideas?
Al
2002 Focus SE Zetec ATX
2000 Focus SE SPI ATX
2006 Freestyle SEL AWD
alz focus is offline
Fan#: 1
Old 02-17-2013, 08:30 AM   #2
don627
Fan#: 56863
What I Drive: 2007 infra-red zx3
FF Reputation: 1 don627 Good Standing Member
It acts like it is loosing power while the engine is off. These cars will do strange things if the battery is weak. My battery was weak and would crank the car every time but, my factory cd changer would 'forget' that I had 6 cds' inside of it at night. So I would start with a test of the battery and charging system and go from there. Hopefully the cluster is not faulty.
don627 is offline
Old 02-17-2013, 08:51 AM   #3
johnwbr
Fan#: 83135
What I Drive: 2005 Gold se wagon
FF Reputation: 1 johnwbr Good Standing Member
My 2000 zetec did that when the battery was old. Changing the battery always fixed it. I had the car for 12 years and probably changed the battery about three times.
johnwbr is offline
Old 02-17-2013, 09:07 AM   #4
wannabe_svt
wannabe_svt's Avatar
Fan#: 92616
What I Drive: 2001, CD Silver. ZX3
FF Reputation: 1 wannabe_svt Good Standing Member
Check the battery and ground wires. I had the same issue with my mustang and it was a dead cell in the battery
OBX longtube race header, Magnaflow resonator & Borla exhaust, FS 65mm TB, H&R coil over suspension, FS front strut bar, Rear SVT sway bar, Black painted EAP's
wannabe_svt is offline
Old 02-17-2013, 09:51 AM   #5
alz focus
Fan#: 67546
I'll keep an eye on the battery for other symptoms. Battery top connections are all secure and corrosion free. Standing voltage is 12.6 and idle voltage is at 14.1. As long as my daughter is not having starting issues or any other problems, I'm going to leave it for now.
Thanks
Al
Old 02-17-2013, 10:52 AM   #6
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
FF Reputation: 15 a_2000_se Great Standing Member
Here's great info on your P0171.
http://www.obd-codes.com/p0171
The side article is also great on explaining Fuel Trim - something I was looking for.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
40k+ miles, now jinxed?
a_2000_se is offline
Old 02-17-2013, 04:04 PM   #7
alz focus
Fan#: 67546
Got in the car again today to run up to the store, no gauge sweep.
Maybe readjusting the battery cables helped or maybe it only does it first thing in the morning. My daughter never notices things like that.
Thanks for that article a_2000_se. I've tried to diagnose this issue for a while and finally gave up. Maybe once it warms up a bit I'll give it another shot before she goes off to college in the fall.
Al
Old 04-14-2013, 07:39 AM   #8
alz focus
Fan#: 67546
Update:
Since I messed with the battery cable connections, there has been no issues with the gauges sweeping at startup.
As for the CEL, I threw in some Chevron Techron concentrated fuel injection cleaner, reset the CEL, and it's been gone for nearly a month now. That 171 code has been on for over a year no matter what I did.
I usually use Seafoam, but this stuff was on sale, Buy One Get One Free, at AZone.
Al
