H&R coilovers but wanna go lower, how? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-17-2013, 05:44 PM   #11
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,920, Level 74
Points: 12,920, Level: 74 Points: 12,920, Level: 74 Points: 12,920, Level: 74
Level Up 18% Completed
Forum Activity 99%
Try removing the adjusters 1st. Or grab your stock springs & cut & fit those in.
felixthecat is online now
Old 02-17-2013, 08:19 PM   #12
c03morrison
c03morrison's Avatar
Fan#: 47010
What I Drive: 04 tundra zx3
Points 8,293, Level 61
Points: 8,293, Level: 61 Points: 8,293, Level: 61 Points: 8,293, Level: 61
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 6 c03morrison Good Standing Member
Buy-Sell-Trade Rating: (4)
you can search for coil over springs. i have been looking at making a custom coil over setup for the rear cus i want a little stiffer spring in the rear with some adjustment. try this site www.speedwaymotors.com they have a lot of options and you can choose your spring rate too. btw if your looking to take out the adjusters i will take them off your hands cus i cant find anywhere that sells just the adjuster.
04 light tundra green metalic zx3, cia w/ K&N filter, fc 4-2-1, 2.5 bolra trubendz, eibach sportline kit, tinted tails and side blinkers, euro headlights, sct chip, oem cf hood, euro replica bumper
c03morrison is offline
Old 02-17-2013, 08:29 PM   #13
04CompOrngSVT
04CompOrngSVT's Avatar
Fan#: 89598
What I Drive: 2004 Comp Orange SVT-EAP
FF Reputation: 1 04CompOrngSVT Good Standing Member
well I really don't need a different coiliver set up. I like the how I can adjust the dampening on the H&Rs I have now. I'm gonna start by taking the adjusters out. I will update once that's done to see if I like the height. if I don't. I'm going to cut my eibach springs to 6 inches and put adjusters back in.
compition orange SVTF: mbrp 2.5" cat back, ORP w/ o2 cheater, H&R coilovers, aem cai, CFM adjustable short shifter, taylor 8.2mm wires, more to come as the money comes.
04CompOrngSVT is offline
Old 02-18-2013, 03:46 AM   #14
apaolucci
Fan#: 105905
What I Drive: 2013 sterling grey focus
FF Reputation: 1 apaolucci Good Standing Member
Originally Posted by quacking05focus View Post
I guess the H&R setup doesn't go as low as the other offerings (I have the ST setup and with the rear at the lowest setting it makes the tire pretty much flush with the fender and in many angles like it's actually barely in the fender). When you say pigtailed, you mean the spring tapers down so it's a smaller diameter at one end? If that is so it mates with the adjuster (smaller diameter on the bottom) I'm not sure you could run without. Even if the spring sits correctly I'm not sure removing the adjuster will buy you much...it's pretty slim when bottomed out. Hopefully someone with an H&R setup can comment to help you out.
as in "st setup" you are talking about to st's made by kw? i plan on buying those. what kind of wheels are you running that make its flush? im pickled between 17' and 18'
apaolucci is offline
Old 02-18-2013, 06:00 PM   #15
Silver Kona
Silver Kona's Avatar
Fan#: 97802
What I Drive: 00 ZX3 Kona 2.0L Zetec Turbo
Points 51, Level 1
Points: 51, Level: 1 Points: 51, Level: 1 Points: 51, Level: 1
Level Up 2% Completed
FF Reputation: 1 Silver Kona Good Standing Member
My first recommendation is to leave them as is. But if you have to go lower you can try this... The H&R coil over rear springs for the SVT have a couple dead coils on top that can be trimmed without any real world negative effects. I would start off cutting 1 coil off each rear spring and see where it sits. If you want more, cut off another coil or just half of a coil. I wouldn't cut more than 2 coils off. You can also remove the rear spring isolators for maybe 1/4"-1/2" extra drop. Don't remove the perches from the rear.
Here is a pic of the actual coil overs you have for reference:
Silver Kona is offline
Old 02-18-2013, 06:06 PM   #16
04CompOrngSVT
Fan#: 89598
are you sure there's coils that can be cut off? bc I read to not cut pig tail coils? a lot of people are saying removing the adjusters is fine even on other websites. where are the spring insolators at??
Old 02-18-2013, 06:22 PM   #17
Silver Kona
Fan#: 97802
Points 51, Level 1
These springs can surely handle it as I've seen it on multiple set ups for people that just want to go low with their H&R's. The rear springs have a progressive spring rate and the top coils are just touching each other when the car is on the ground.
The spring isloators are located on top of the stock rear springs and are reused on the rear springs on the H&R kit. They are designed to eliminate noises.
Old 02-18-2013, 06:28 PM   #18
04CompOrngSVT
Fan#: 89598
I guess I'll cut 2 dead coils off and keep the adjusters in. never been big on "cutting" coils especially on such an expensive set up. but I wanna go lower so gotta do it.
Old 04-28-2013, 02:28 PM   #19
tvanhorn54
tvanhorn54's Avatar
Fan#: 110380
What I Drive: 2003 Red svt zx5
FF Reputation: 1 tvanhorn54 Good Standing Member
I have coilovers on my car now. I want to go lower but I don't want to buy another set of coilovers. Could I buy some coilover sleeves even though they are a different brand than the set I have on?
tvanhorn54 is offline
Old 04-28-2013, 02:56 PM   #20
ToreadorFocus
ToreadorFocus's Avatar
Fan#: 100350
What I Drive: 2006 Dark Toreador Red ZX3
FF Reputation: 1 ToreadorFocus Good Standing Member
i flipped the spring upside down (that goes another inch) and i cut off 2 coils
if u end up cutting i recommend getting a rear sway bar
ToreadorFocus is offline
